What constitutes a Medical Device Technical File "Family?"
Sheppi76
What constitutes a Technical File "Family?"
When grouping devices together to create a family of products for Technical Files, rather than have a Technical File for each individual device, what constitutes a family and how is it determined if a device falls within a family?
We are creating a Technical File for a new family of Devices. These devices are products used in the mouth, but do not go past the pharynx, and they are intended for transient use. They are Class IIa devices using Rule 5 in the MDD (under invasive devices). These devices are products that connect to High Volume Evacuator systems (an active device). The intent of the device is to remove fluid from the mouth. There is no change made to the fluid, and it there is no fluid being administered into the body with this.
Now, I have been informed that they are considering adding yet another device for this line of products, however I am unsure if I can have it within the same Technical Family. The new device is a product that would connect the devices that go into the mouth to the HVE system itself, basically like a hose extension.
I have figured this new “extension” device would be Class IIa following Rule 11, now that the device itself is no longer invasive. (My only concern here is that Rule 11 is listed under “Additional rules applicable to Active Devices”. The concern is I am not positive this would be considered an active device, as the definition of an active device states…”medical devices intended to transmit energy, substances, or other elements between an active medical device and the patient, without any significant change are not considered to be active medical devices.” Although this indicates this device would not be an active device, I’m not seeing any other rule that could fit this product better.)
So in this case, I am wondering am I able to include the extension device into the same family, or would this end on in a family (and therefore Technical Family) of its own.
:cfingers:
Burgmeister
Isn't this simply an accessory to the system? Apologies if I have misunderstood your situation.
MIREGMGR
I too would call an extension hose an accessory, in the absence of further information leading in some other regulatory direction.
Sheppi76
Yes, we do consider this hose to be an accessory to the device. However since accessories are "classfied within their own right separately from the device with which it is used" I am still just addressing this as a device rather than an accessory.
I aplogize for any confusion with my question, what I am inquiring about is if there is anything defined for "what" are the requirements for constituing a family. When putting devices together for one family do the devices in that family have to have be the same Class, follow same classifiaction rule, or do they just have to be used in conjuntion together, are they supposed be be similar products by design, etc?
My opinion is that they would be in the same family, with the justification that they hose is designed to be used in conjunction with the device that goes into the mouth, I am just curious to if this is a possible justification to be used, since most of the other items I mentioned are different.
MIREGMGR
The informal "family" definition used by the company for which I work is: a group of devices and accessories with the same classification and the same high-level intended use, and sometimes with the same internal brand or other distinction.
sreenu927
From my understanding - a group of devices with accessories will form as a system.
A group of medical devices can be considered as a "Family", if they have -
- same intended use
- belong to same class
- share same design history file (DHF)
- variations may be of colour, dimensions, etc..
Eg:
- Catheters of various lengths can be grouped as a "Family" and submit ONE Technical File.
- Condoms of various colours can be grouped as a "Family"
System: Knee implant that constitutes of a ball & socket joint, various screws, rods form as "System" which is used to meet a specific intended use.
Hope this clarifies!
Sreenu:2cents:
K What constitutes (is defined as) as a Medical Device? Other Medical Device and Orthopedic Related Topics 3
shimonv FDA released final guidance documents on what constitutes a significant change Other US Medical Device Regulations 2
P Requirements/guidance on what constitutes the Manufacturers "Address" EU Medical Device Regulations 7
S What constitutes an “expert” with respect to a NB auditor? EU Medical Device Regulations 1
Q What constitutes current technical data? Federal Aviation Administration (FAA) Standards and Requirements 2
S What constitutes Major and Minor changes in Software Software Quality Assurance 7
T What constitutes a Management Review? Informal Management Review Management Review Meetings and related Processes 10
R Supplier Quality - What constitutes a Reject? Supplier Quality Assurance and other Supplier Issues 12
K What constitutes QUALITY OBJECTIVES! I have problem with my auditor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
H What constitutes a PRR? Had a non conformance at customer but... Nonconformance and Corrective Action 4
R What Constitutes a Field-Failure? IATF 16949 - Automotive Quality Systems Standard 4
S Definition Controlled Document Definition - What constitutes a controlled document? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
S What Constitutes "Manufacturers Claims" about a product? ISO 13485:2016 - Medical Device Quality Management Systems 3
V What Constitutes a Document Change? Company Logo Revision Miscellaneous Environmental Standards and EMS Related Discussions 12
T Definition Procedure vs. Instruction - What constitutes a procedure? What are the differences? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 15
V What Constitutes Customer QA (Quality Assurance)? Customer and Company Specific Requirements 4
T Design Input vs. Design Output - What constitutes Design Input? Design and Development of Products and Processes 11
D What constitutes a "significant change" in software AND what does not Software Quality Assurance 7
S What Constitutes an Excellent Quality Manual? Quality Management System (QMS) Manuals 18
I What constitutes 'design'? We remanufacture products to OEM specifications. Design and Development of Products and Processes 15
F ISO 9001:2000 Clause 4.2.4 - Control of Quality Records - What constitutes a record? Records and Data - Quality, Legal and Other Evidence 42
A Brexit Mandate for EU Authorised Representative for non medical devices CE Marking (Conformité Européene) / CB Scheme 3
A Canadian Safety Labels for medical electrical equipment Canada Medical Device Regulations 0
A Applicability of Photobiological Safety Evaluation for LED used in medical devices Reliability Analysis - Predictions, Testing and Standards 1
M Medical device certificate in Australia - ARTG certificate Other Medical Device Regulations World-Wide 0
Q Software as a medical device vs software not sold as medical device: local regulations for sale? EU Medical Device Regulations 4
H Medical device Product Registration Registrars and Notified Bodies 2
T Google Fit Health datas and Medical devices Application Medical Information Technology, Medical Software and Health Informatics 0
A Can a power Supply be an accessory to a medical device, if it is an 'off-the-shelf' product. IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
B Procedure packs with non-medical devices EU Medical Device Regulations 1
A Medical device labelling Date of manufacture US Food and Drug Administration (FDA) 2
W Non Sterile Medical Device Environmental Tests Other Medical Device Related Standards 4
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
K 25-year lifetime of medical device - document storage period EU Medical Device Regulations 1
K Relabeling an existing medical device in the field? Other US Medical Device Regulations 6
A Reliable sources for following EU medical device regulatory EU Medical Device Regulations 0
T IVDR Medical device software CE Marking (Conformité Européene) / CB Scheme 8
A Customer Approval (Medical Devices) Document Control Systems, Procedures, Forms and Templates 4
J Requirements as a Distributor for Incoming Inspection of Purchased Finished Medical Device Medical Device Related Regulations 0
S Microwave medical waste disinfectant - A medical device or not? Other ISO and International Standards and European Regulations 3
S Registration of Medical Device in Hong Kong - labeling requirements Other Medical Device Regulations World-Wide 0
D Electrical Medical Devices class I EU Medical Device Regulations 0
J Are complaints applicable to development of medical devices? Customer Complaints 2
V Software as medical device (SaMD) replicated for multiple clients through APIs IEC 62304 - Medical Device Software Life Cycle Processes 5
M Is the output of a device a Medical Device? IEC 62304 - Medical Device Software Life Cycle Processes 5
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
M Do I need separation in my circuit with a medical charger? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
