What constitutes 'design'? We remanufacture products to OEM specifications.
I
Ingeniero1
We remanufacture products to OEM specifications. When completed, we calibrate and test the products to the same specifications as the OEM published specifications, and we offer the same warranty period or, in most cases, twice the length of said warranty period.
In our Quality Manual, we have stated as follows, (accepted by our registrar, BTW):
“7.3 Design and Development
Our organization is exempt from this clause. We are not involved in the design and development of products, as these activities are outside of the organization’s scope.”
As a rule, we use mostly the parts from salvaged products. We clean them, paint them, have them plated, etc. Occasionally, we make a part from raw material if the salvaged part is FUBAR. These normally are brackets, mounting flanges, and similar machined parts. We measure an original that we know to be correct, make a drawing, and duplicate the part. We do not design anything from scratch.
Definitely, this is not development; but does making a drawing to manufacture a replacement part constitute ‘design’ or could it be perceived as such by an auditor?
Thanks!
Alex
ccochran
Alex,
This sounds like engineering drawing to me, not design. You never know how an auditor might view something, though. You might have to perform some education on the auditor (i.e., knock him upside the head).
Craig
Craig Cochran
Center for International Standards & Quality
Georgia Institute of Technology
liuyy
Alex,
Sure you design something.But your design process is simple.So the design procedure would be simple whether documented or not.
Liuyy
celso klitzke
Thanks!
Alex
We have the same problem. But our registrar (DNV) and all auditors that visited us talked the same : "When you make a product using an existing part as your model, you HAVE DESIGN AND DEVELOPMENT". It can be very simple, but you HAVE.
Well, they say it´s simple, we think it´s stupid.
Celso
I
Ingeniero1
ccochran,
Yes, perhaps more of an 'engineering' or even an 'inspection' drawing. As a matter of fact, we also make drawings NOT to make a part, but simply for the operators to check the salvaged parts against, and determine whether they are usable. (I can see how this can really be a grey area subject to different interpretations.)
liuyy,
Wouldn't 'that' procedure fall under 7.3?
Celso,
So, did you have to meet clause 7.3 or parts of it?
Thanks!
Alex
Al Rosen
How do you account for characteristics you can't measure? Material, heat treat etc.
I
Ingeniero1
Al,
Over the past 50 years or so, the company has 'gathered' a tremendous amount of parts and information. I have been here for a little over a year, but I have never seen or have even heard of any occasion where there was a part that we did not have one like it at one time or another.
Usually, it is a question of providing more products than we have ready-to-use parts for. Say that we need to ship five XYZ products - we may have salvaged enough parts to make 20 such products, except for perhaps one specific part, of which we may be down to the last few. In such a case, we may fix one of the parts that had been rejected and was not part of the ready-to-use stock, or we may have to make one from scratch based on another like-part that we have and is known to be correct.
In every case, we have identified the materials, heat-treat required, etc. In many cases, we are able to get this information directly from the OEM. We don't get drawings, other than if these are readily available to anyone, but we do get a lot of 'verbal' information. Funny, the relationships we have with the OEMs range from some that consider us as their independent repair-station and even tell their customers about us, to others that won't give us the time of day and do everything they can to destroy any product that may be remanufactured.
Oops - I'm way too long...
Celso – That’s what was afraid of – but we can do it.
Alex
ccochran
Alex,
Good luck with your "design" process. I honestly do not believe what you're doing constitutes design. By definition, design means the product and its specifications and performance requirements do not exist yet. In your case, the product and all its specifications, functional attributes, and performance requirements already exist. All you're doing is making a drawing of something that already exists. The discipline that applies is document control, not design.
In my way of thinking, here are guidelines for design:
• If you are producing a unique good or service for which your customer has not provided specifications, then you're probably doing design and development.
• If your customer has only given you vague performance requirements and asked you to come up with a good or service that will meet those requirements, then you're probably doing design and development.
• If your product is driven by your organization’s powers of pure creativity and innovation, then you're probably doing design and development.
• If one or more of your products is protected by patents, then you're doing design.
I'd love to hear more perspectives on this.
Craig
liuyy
Ingeniero1 said:
ccochran,
liuyy,
Celso,
Thanks!
Alex
Alex,
7.3 is for design and development of product,i.e to specify its specification(intended uses,functions and performances etc.).Engineering or inspection drawing may be considered as 7.1c) and 7.5.
liuyy
T Design Input vs. Design Output - What constitutes Design Input? Design and Development of Products and Processes 11
shimonv FDA released final guidance documents on what constitutes a significant change Other US Medical Device Regulations 2
P Requirements/guidance on what constitutes the Manufacturers "Address" EU Medical Device Regulations 7
S What constitutes an “expert” with respect to a NB auditor? EU Medical Device Regulations 1
Q What constitutes current technical data? Federal Aviation Administration (FAA) Standards and Requirements 2
S What constitutes Major and Minor changes in Software Software Quality Assurance 7
T What constitutes a Management Review? Informal Management Review Management Review Meetings and related Processes 10
S What constitutes a Medical Device Technical File "Family?" EU Medical Device Regulations 6
K What constitutes (is defined as) as a Medical Device? Other Medical Device and Orthopedic Related Topics 3
R Supplier Quality - What constitutes a Reject? Supplier Quality Assurance and other Supplier Issues 12
K What constitutes QUALITY OBJECTIVES! I have problem with my auditor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
H What constitutes a PRR? Had a non conformance at customer but... Nonconformance and Corrective Action 4
R What Constitutes a Field-Failure? IATF 16949 - Automotive Quality Systems Standard 4
S Definition Controlled Document Definition - What constitutes a controlled document? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
S What Constitutes "Manufacturers Claims" about a product? ISO 13485:2016 - Medical Device Quality Management Systems 3
V What Constitutes a Document Change? Company Logo Revision Miscellaneous Environmental Standards and EMS Related Discussions 12
T Definition Procedure vs. Instruction - What constitutes a procedure? What are the differences? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 15
V What Constitutes Customer QA (Quality Assurance)? Customer and Company Specific Requirements 4
D What constitutes a "significant change" in software AND what does not Software Quality Assurance 7
S What Constitutes an Excellent Quality Manual? Quality Management System (QMS) Manuals 18
F ISO 9001:2000 Clause 4.2.4 - Control of Quality Records - What constitutes a record? Records and Data - Quality, Legal and Other Evidence 42
DuncanGibbons Section 8.3 relevant for design organisations AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
P DFMEA - Machinery Design Best Practices FMEA and Control Plans 0
R Is a FAIR required on parts that we design? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
U API Spec Q1 - 5.6.1.2 C (3) - Design software Oil and Gas Industry Standards and Regulations 3
A 8.6 Release of products and services, 8.3 Design and development - evidence required ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
J Significant change related to design and intended use EU Medical Device Regulations 3
S Traceability of requirements to design and risk Design and Development of Products and Processes 3
U NOC - What is considered a "design change" EU Medical Device Regulations 5
Q PPT used as Design Review ISO 13485:2016 - Medical Device Quality Management Systems 3
D Design Verification Sample Size vs Repeats Statistical Analysis Tools, Techniques and SPC 9
A Design and development procedure for API Spec Q2 Oil and Gas Industry Standards and Regulations 6
D Design controls - Inputs, outputs, V&V, DHF, DMR ISO 13485:2016 - Medical Device Quality Management Systems 10
LostLouie Manufacturer divorced from Design process, is he justified in design process deficiencies? ISO 13485:2016 - Medical Device Quality Management Systems 9
R DFA & DFM - Examples for Design for assembly and design for manufacturability Lean in Manufacturing and Service Industries 2
D Using Laboratory Notebooks in R&D and Design and Development ISO 13485:2016 - Medical Device Quality Management Systems 3
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 6
K Joint approval between OEM and Manufacturer on Design Documents ISO 13485:2016 - Medical Device Quality Management Systems 4
M API 4F/7K/8C Design Package Validation Oil and Gas Industry Standards and Regulations 2
A Design History File - Not ready to share the design drawings or Bill of Material US Food and Drug Administration (FDA) 2
W Need for current design or process control FMEA and Control Plans 2
D Test summary report example for design validation wanted - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
DuncanGibbons Understanding the applicability of Design of Experiments to the IQ OQ PQ qualification approach Qualification and Validation (including 21 CFR Part 11) 5
S Requirement to Conduct New Shelf-life Testing? (re-do testing for design change) EU Medical Device Regulations 3
A Sample Agreement available for Outsourcing Medical Device Design activity? ISO 13485:2016 - Medical Device Quality Management Systems 1
