What Control Chart should be used for Microbial Limit (NMT 100 cfu/m3)
jihyunpark
Dear All,
Kindly give me an advice what control chart i should use for testing date of microbiologic count limit (Specification is NMT 100 cfu/m3). Furthermore, please also give me a template of that chart if you have.
Thanks.
Darius
The problem with microbial counts is that in many cases the count is "CERO" (more that 70% of data points), or no detection and it can be some very near to "0", but if something happen, it can grow a lot.
:2cents:If this is the case I couldn't recommend SPC:nope: (unless u-chart as steve said), precontrol could be the tool.
If we can see the data (an example) can be enlighting to us, and direct our advices to your variable's behabiour.
It is impossible to advise you on exactly which chart you should use without seeing your data. I have numerous charts for microbial growth in my organization but they are not all the same chart type as the 'processes' are different. With different processes you get different behavior and so you must use differetn chart types.
G
glarson
I hope I'm not stepping on any toes.
I guess I'm too new. They won't let me post links.
I'll post this once without the links then again with, when my post count is greater 4. <ugh>
I came across this pdf a some time ago.
<link omitted>
I used the example in this pdf to create spc charts for a micro lab. Most of my charts' y axes started at 0. I used Shewhart individuals control charts, With one exception: no LCL. It was assumed that results less than the detection level was = 0. In a few cases that involved a large cfu range (like 50 - 10000 for example) I converted the data to a logarithmic scale. This was not ideal and the only big benefit may have been that the charts looked more aesthetically pleasing. In your case, though, I do not think you need to bother with logarithms.
I noticed that you have some results that are lower than your detection limit of 10. ??
If you do not have the calculations you can find them on wiki:
<link omitted>
I no longer have any examples to show, since I am no longer with the company that I created those charts for; most of my SPC work was in MS Access anyway.
GL
G
glarson
Now lets try it...
I came across this pdf a some time ago. http://www.fsis.usda.gov/PDF/FAQs_SPC_1.pdf
I used the example in this pdf to create spc charts for a micro lab. Most of my charts y axis started at 0. I used Shewhart individuals control charts, With one exception: no LCL. It was assumed that results less than the detection level was = 0. In a few cases that involved a large cfu range (like 50 - 10000 for example) I converted the data to a logarithmic scale. This was not ideal and the only big benefit may have been that the charts looked more aesthetically pleasing. In your case, though, I do not think you need to bother with logarithms.
http://en.wikipedia.org/wiki/Shewhart_individuals_control_chart
GL
Stijloor
<snip> I guess I'm too new. They won't let me post links.
Actually, "They" is Mr. Marc Smith, the owner and host of this site.
Yes, you are correct, that provision is implemented to prevent link spammers from contaminating our Forums. (The required post count is 5; certain forum posts do not count).
Hope this clarifies. ;)
Stijloor, Forum Moderator.
siju234
Dear all,
Can any body clarify my following doubts regarding microbiology lab?
1, What is the need of Air condition in microlab? whether the air condition should be on round the clock?
2,How we can identify classify the class of my microlab?
Thanks in Advance,
sijo joseph
INDIA
J What Control Chart should we use for factors without UCL? Statistical Analysis Tools, Techniques and SPC 22
B What type of Control Chart should I use for this Data Statistical Analysis Tools, Techniques and SPC 1
K What should be the best control chart? Cpk study for assembly length Capability, Accuracy and Stability - Processes, Machines, etc. 2
D What type of control chart should I use? Statistical Analysis Tools, Techniques and SPC 18
B Control chart and sample time Statistical Analysis Tools, Techniques and SPC 1
J Control chart for huge sample size Statistical Analysis Tools, Techniques and SPC 9
M What is "setup control chart"? Statistical Analysis Tools, Techniques and SPC 2
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
D Control chart applicable? Percentage of compliance with a standard Statistical Analysis Tools, Techniques and SPC 2
D Link between FMEA, flow chart and control plan FMEA and Control Plans 10
B How to do a control chart - Machining product that requires flatness control Capability, Accuracy and Stability - Processes, Machines, etc. 1
S Understanding control chart and measurement capability Statistical Analysis Tools, Techniques and SPC 2
F Appropriate Control Chart Statistical Analysis Tools, Techniques and SPC 5
S used excel formula calculated the ARL's with Rule1&Rule2 for Shewhart control chart Statistical Analysis Tools, Techniques and SPC 0
H How to define Root Cause when some points are out of control chart Statistical Analysis Tools, Techniques and SPC 6
L The ARL for an X bar Control Chart (n = 5) Statistical Analysis Tools, Techniques and SPC 5
L P-Chart Control Limit Calculation help Statistical Analysis Tools, Techniques and SPC 1
L A Complete Control Chart Decision Tree Statistical Analysis Tools, Techniques and SPC 5
S Variation Study on Mined Material - What do you call it (not a control chart) Statistical Analysis Tools, Techniques and SPC 7
G I-Chart and X bar Chart Control limits Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Regression Control Chart - Process Capability Statistical Analysis Tools, Techniques and SPC 18
J Control Chart Pattern Detection Statistical Analysis Tools, Techniques and SPC 3
R Control Chart Constants and Confidence Interval Statistical Analysis Tools, Techniques and SPC 7
P Specification and Tolerance in Stability Control Chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
I What is an "X-Rs" Control Chart? Statistical Analysis Tools, Techniques and SPC 4
I What is an Ideal Control Chart for Hospital Surgery Infections? FMEA and Control Plans 2
M Shewhart Control Chart for SPC In Excel - Explain the yellow and red marked column Statistical Analysis Tools, Techniques and SPC 2
K Advice on Calculating Control Chart Control Limits Statistical Analysis Tools, Techniques and SPC 13
J Statistical Significance and SPC Control Chart Reports Statistical Analysis Tools, Techniques and SPC 9
P SPC Data Collection and Control Chart Type question Statistical Analysis Tools, Techniques and SPC 4
R XBar & R Chart Spreadsheet to apply a Control Process Statistical Analysis Tools, Techniques and SPC 1
Chennaiite Control Chart for Non-Manufacturing Process Indicators - Is it worth? Statistical Analysis Tools, Techniques and SPC 1
O Is it an Assignable Cause only if the Control Chart says so? Statistical Analysis Tools, Techniques and SPC 16
C Control Chart Roadmap Template Document Control Systems, Procedures, Forms and Templates 0
T Shewhart Control Chart - ISO/TS 13530:2009(E), Page 22. General Measurement Device and Calibration Topics 3
M MSA (Measurement System Analysis) - Do we have control of all states in the chart? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
H Control Chart applications in Cement Industries Statistical Analysis Tools, Techniques and SPC 2
T Implementing SPC - Control Chart for Individual Measurements Statistical Analysis Tools, Techniques and SPC 9
R "Control" as used in 4.1 c) - Process Flow Charts (Process Sequence Chart) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
I Control Chart for Mortality Rate on Broiler Farms Statistical Analysis Tools, Techniques and SPC 4
G Control Chart Selection for Crimping Operations for RJ 45 Plugs Statistical Analysis Tools, Techniques and SPC 5
K When to create a new Control Chart? Quick question Statistical Analysis Tools, Techniques and SPC 4
T Control Chart - Salt Spray Test Hours - Powder Coated Parts Statistical Analysis Tools, Techniques and SPC 3
S Calculation of Upper and Lower Control Limits for Control Chart? Statistical Analysis Tools, Techniques and SPC 7
R Control Chart Metrics/KPI - Measuring Effectiveness of Control Charting System Statistical Analysis Tools, Techniques and SPC 4
L Measurement Uncertainty using Control Chart Measurement Uncertainty (MU) 2
R Calculation Mean for Control Chart -X Double Bar Statistical Analysis Tools, Techniques and SPC 13
B Color Individual Points on a Control Chart? Using Minitab Software 7
A Organization Chart Control and Quality Manual Integration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
S Pre-Control Chart for Single Side Tolerance Statistical Analysis Tools, Techniques and SPC 1
