K
Re: What Defines “Flight hardware?”
Hi NQA Spec
The first thing I would do is get in touch with the FAA. They may refer you directly to the Experimental Aircraft Association (EAA) and / or help you directly. The equipment you have (I assume) designed and manufactured and wish to install in an experimental aircraft may need to undergo FAA approval under Part 21. This is because the experimental aircraft type you are planning to install it in carries an approval under an existing configuration. You are looking to change that configuration with your new system so may need to have the FAA approve the design change depending on the extent of the change. The kit manufacturer may be able to help here but the FAA will certainly confirm, it depends on the system you have changed and the risk this presents.
The FAA web site has a couple of AC's (Advisory Circulars) that you may find useful. It certainly makes references to the parts of Part 21 you may need to comply with. AC 20-27F describes the Certification of an Experimental Aircraft (of which you equipment will be installed) and AC 20-139 describes the commercial assistance the builder can utilise in the building of the EA. There's some other ones as well about certification of the builder and testing you need to undertake.
FDO is the best place to start for all of the above.
EAA web site is www.eaa.org FAA web site is www.faa.gov
Best of luck.
Hi NQA Spec
Best of luck.
