What defines the need for the ISO9001 Design & Development process?
ScottK
Not out of the crisis
By that I mean - can you draw a division between what needs to follow all the ISO steps and what can be done in the Chief Engineer's office at 7:00 at night on a piece of graph paper?
This is killing us. We just don't have the resources to make project out of every modification.
Can I define when the system needs to be used?
For example:
1) a distributor calls and asks to get a valve with SAE threads rather than the standard NPT. All we are changing is the threads - the working parts and all the materials remain exactly the same.
2) A customer calls and says - here's our idea, design us a valve that will do it.
Clearly case 2 would require a whole soup to nuts process... but what of case 1? If we follow the extended process it'll take days, where if we handle it more sensibly, the parts can be made and shipped in a day and we will still end up with the stuff needed in the QMS (drawings, specs, etc).
Can someone give me an example of how to draw the line that will pass and ISO auditor's muster?
Sidney Vianna
Post Responsibly
Re: What defines the need for the ISO9001 D&D process?
What you describe in example 1 is a design change. Subject of a sub-paragraph in clause 7.3 of ISO 9001.
7.3.7 Control of design and development changes
Design and development changes shall be identified and records maintained. The changes shall be reviewed, verified and validated, as appropriate, and approved before implementation. The review of design and development changes shall include evaluation of the effect of the changes on constituent parts and product already delivered.
Records of the results of the review of changes and any necessary actions shall be maintained (see 4.2.4).
ScottK
So even if a new part number results it can still be considered a design change?
Mustang
If it's a new item, then it needs to follow all of 7.0, Product Realization.
There is no easy way out... bottom line, changing threads changes functionality/appicability of that item. What if you shipped the new valve by mistake as the old one? Would it fit?
However, you don't have to reinvent the wheel from scratch, use what you have to start with.
If you have a system, it needs to be followed. That's the point of having one in the first place. You can't "draw the line" on when to use it, and when not to.
ScottK
But I can change the system.
Bob Bonville
Scott, when I first read your post it occured to me that you were talking pre eBOM. In other words before the design is locked into the Engineered Bill of Materials (aka "as designed").
I believe you are talking about design changes to an already designed and configured part. In this case you have to bite the bullet and process the change through your internal CCB.
Bob
I think a reasonable argument could be made that this is a configuration change, and not a design change. Scott is looking for a bright line, and if there is one the dividing line is drawn in terms of function, I think.
Sidney Vianna
Post Responsibly
As usual, you dissected the issue at hand in a paragraph, or less. In my opinion, a configuration change should be treated as a design change in the context of ISO 9001. The typical protocol of CCB's (Configuration Change Board) follows pretty much the requirements of ISO 9001 7.3.7.
Actually, a suggestion for the ISO 9001:2015 revision should be to revise that sub-paragraph of the Standard to state Design and Configuration changes.
JaneB
Yes. You most definitely can.
And should when necessary.
The real question then becomes: how can we meet the requirements without tying ourselves in knots and making things far too difficult (and therefore perhaps uneconomic)?
Putting a different thread on a valve is a change, and doesn't need a whole other interation of the design process.
I've also seen where an organization states that anything less than (for example) 10 hours of an engineer's work doesn't require the whole 9 yards of D & D planning etc.
M Labelling - Is there a guidance or regulations that specifically defines the 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S What defines Top Management after a Merger? Quality Management Review (9.3.1) Management Review Meetings and related Processes 1
C IEC EN 60601-1-8: What defines a visual alarm? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P What defines a campus? (Scope of ISO 14001 registration) ISO 14001:2015 Specific Discussions 4
H What defines a Quality Record ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
S Aerospace Standard - What document defines reliability concept AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
N What Defines Flight hardware? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 25
A NO2 Output - 4.5.1. How often to measure? Who defines an 'appropriate' period? Miscellaneous Environmental Standards and EMS Related Discussions 2
Marc IIA (Institute of Internal Auditors) Defines Internal Auditing Internal Auditing 25
S What defines a "change in process" QS-9000 - American Automotive Manufacturers Standard 5
J Need a contract monitoring Tool General Information Resources 0
P UDI-PI requirements on reusable surgical device, do we need serialisation? ISO 13485:2016 - Medical Device Quality Management Systems 0
W 17025 and NIST handbook relationship (need advice) ISO 17025 related Discussions 8
K Need procedure for D&D inputs? ISO 13485:2016 - Medical Device Quality Management Systems 4
S Need help on "Country of Origin" Medical Device and FDA Regulations and Standards News 0
Ed Panek Immediate need for 80601-2-56 Consulting expert. PM me for details Career and Occupation Discussions 0
Tagin You're Gonna Need a Bigger Root Cause Coffee Break and Water Cooler Discussions 12
M PSA Suppliers - CSR matrix and need the quality manual of PSA APQP and PPAP 2
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
I Do I need to sign off my annual audit calendar? Internal Auditing 2
P Do we need to retrospectively use the "MD" symbol (indicating device is a medical device) on labels, e.g. finished devices within expiration date? EU Medical Device Regulations 2
M Do I need separation in my circuit with a medical charger? IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
V Certified Auditor - Need of additional certification specific to industry ( GMPs) ASQ vs ECA vs others Professional Certifications and Degrees 1
D Low risk IVD study in the UK, do I need MHRA approval? UK Medical Device Regulations 1
J Do Software Subcontractors need to be ISO13485 compliant in the EU? EU Medical Device Regulations 3
K Do I need a "State of the art" plan? CE Marking (Conformité Européene) / CB Scheme 1
S Need advice for schooling Quality Manager and Management Related Issues 5
R What information do i need to get from the device manufacturer 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
S Need guidance on project ISO 13485:2016 - Medical Device Quality Management Systems 2
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
B Countries with no need for FSC (Free sales certificate) Other Medical Device Regulations World-Wide 0
R The term "Benefit Risk Ratio" in EU MDR, do I need to present benefit risk analysis as a RATIO Risk Management Principles and Generic Guidelines 4
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N IPC-A-630 - Is this free or do i really need to pay for it? Manufacturing and Related Processes 4
P Need a programmer for QVI's VMS software for optical inspection machine Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
silentmonkey How to decide what characteristics need to be verified during incoming inspection? ISO 13485:2016 - Medical Device Quality Management Systems 5
T Do I need a qualified compiler for class B software? IEC 62304 - Medical Device Software Life Cycle Processes 3
E 13485:2016, Sections 4.1.6, 7.5.6 and 7.6 - Validation of Software - Need some Advice please ISO 13485:2016 - Medical Device Quality Management Systems 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
