What do we need for a DMR? Importer of Record and Going Crazy!
SuperGirl
Hi, I am new to the Medical Device World and am the Quality and Regulatory Affairs Manager of the Small Medical Device Company. (I came from working in a QC Lab for a pharma company) We don't actually make any thing, but we are the importer of record of all of the products. Our Quality Consultant is very confussing and I'm kind of at a stand still. :bonk:The Consults say we need to have a device master record the list all of the spefication and references all the SOPs that go in to making the device as well as the testing, but when I attempt to get the infomation from our suppliers/contractos, they won't give up the information.
THE QUESTION: What do we need for a DMR?
Thanks! :thanx:
MIREGMGR
Re: Importer of Record and Going Crazy!
I assume that when you say you are the "importer of record", you mean two things:
1. You have been designated by the Manufacturer as their United States Agent.
2. You are the products' Initial Importer, and your company is FDA Registered in this role.
(See http://www.fda.gov/MedicalDevices/D...ce/ImportingandExportingDevices/ucm050126.htm.)
The Manufacturer of a medical device to be marketed within the US has full responsibility for that medical device's design and manufacture, whether the Manufacturer is located within the US or elsewhere. This includes having a 21CFR820 compliant quality system and maintaining a DMR and manufacturing records, among other things.
This responsibility cannot be offloaded to either the US Agent or the Initial Importer. Thus I don't understand why your consultant would suggest that your company, fulfilling those roles but not being the Manufacturer, would need to maintain a DMR.
You mention that there is some confusion between yourself and the consultant. Perhaps you need to sit down with them and attempt to get a clearer understanding of their advice in order to determine whether you've misunderstood it, or it is incorrect, or there are other elements of the situation beyond what is described here that change the nature of your role.
SuperGirl
:thanx::applause: First of THANK YOU!
Yes, we are registered with the FDA and for some of the companies we act as thier US Agent as well. However, most of our contractors are independently registered with the FDA.
MIREGMGR
OK, that introduces some confusion, at least for me. If your relationship with the actual manufacturer of a medical device is defined by both you and them as one in which they are a contract manufacturer, then your company is not an Initial Importer...it is the Manufacturer.
Which changes everything, and would explain why your consultant would want you to maintain a DMR, among other things.
Would you care to clarify?
SuperGirl
This is were I get confussed as well. We bring in Medical Devices, mostly Class I, from Manufactures over seas, then we sell them to either distrubtors or end users. When I first started everyone called the Manufacturering Companies Suppliers. But our consultant told us to call them contractors.
Let me clarify our process of determining what products we are going to bring in. If someone has an idea for a product, we see what companies already make them, request sames from a few places, get price quotes, then decide which is best and order. We do not make any specifications. :frust: Becasue we don't make any specification, I believe these are suppliers and therefore we don't need a DMR, but the consultant say we need a DMR for each of our products.
MIREGMGR
* Do the product labels identify the original maker as the Manufacturer? (or) Do they state your name accompanied by "Distributed By" or "Manufactured For"?
Are the original makers registered with the FDA as Manufacturers? Do they have 21CFR820-compliant quality systems?
Do the original makers perceive themselves to be the Manufacturer, per FDA regulatory definition, of the products that they sell to you to re-sell in the US?
Ideally, in order for you to be only a distributor of these products (whether or not you're the products' Initial Importer), all of these questions should be answerable with "yes", and you should have some sort of evidence to back up that answer.
* The fact that you do not explicitly create specifications is not determinative. Specification creation can be implicit, by means of purchasing an existing product for which the characteristics are known to you and identifiable by means of the product designator that you use to place the order.
* You mentioned that in some instances, a product maker has designated your company as their US Agent. Do you have that in writing?
If so, then you have clear evidence of being an Initial Importer for at least some of that company's products, and therefore a distributor.
* Of course, your situation may be something of a mish-mash, not clearly defined either way. If so, you should get it straightened out.
It's obvious that you want to be only a distributor. That cannot be the case unless the original makers agree that they are the Manufacturer. Every product marketed in the US must have a regulatorily responsible Manufacturer. If you import and resell that product, and the original maker doesn't agree that they're the Manufacturer, the FDA is likely to assume that you are the Manufacturer for purposes of your US sales.
In which case, you need those DMRs, among other things.
My suggestion (and I imagine your consultant's suggestion as well) would be that you not do business in this manner in the future without explicitly spelling out in your Purchase Order whether the company from which you are buying is expected by you to be a contract manufacturer, or the FDA responsible Manufacturer.
SuperGirl
Thank you for all your wonderful help, and to everyone one here. Yes, we are only the Importer of Record/ Initial Importer for all of our devices. Everything is labeled "manufactured for".
C Do I need to show fasteners in my BOM's/DMR etc? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
E Need help establishing a DMR (Device Master Record) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
J Which supplies/suppliers need to be listed in DMR? ISO 13485:2016 - Medical Device Quality Management Systems 4
L Turkish Requirements - Does the Software need to be translated? CE Marking (Conformité Européene) / CB Scheme 2
J Need for a cleanroom in the manufacture of a medical device for a clinical trial EU Medical Device Regulations 4
S Need help with analysing a survey on minitab Using Minitab Software 1
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
P Electrosurgical Device User Need: Cord Flexibility -> Requirement Other Medical Device and Orthopedic Related Topics 4
P Do I need to get registered or have German entity to sell IVD products in Germany? CE Marking (Conformité Européene) / CB Scheme 2
J Documentation structure - Do I need Work Instructions? Document Control Systems, Procedures, Forms and Templates 23
G Need resources / tutorials about OPS (Operation) for ISO IT (Information Technology) Service Management 8
D Do non-IATF customers need to be included in audit scope? IATF 16949 - Automotive Quality Systems Standard 23
M Do you need an Applicable general safety and performance requirements Checklist? EU Medical Device Regulations 2
Y Does Solidworks (2D/3D drafting modules) need validation? Other Medical Device and Orthopedic Related Topics 5
M Do we need to create a new CER or can we just update the existing CER EU Medical Device Regulations 3
K A proposal for the model Quality Management - I need help for the project ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
B Record Management - Does the QMS need to control templates of records? Records and Data - Quality, Legal and Other Evidence 17
Q Need clarification on requirements.... Class i, gmp & 510(k) exempt Medical Device and FDA Regulations and Standards News 12
U Do we need clinical trial data for Class IIa medical device under MDR EU Medical Device Regulations 7
G Do we need to QA cert? We only plan to supply reagents Medical Device and FDA Regulations and Standards News 3
I MSA requirement for 5 Micrometers + CP changes need customer approval? IATF 16949 - Automotive Quality Systems Standard 2
R Evaluating the need for preventive action Preventive Action and Continuous Improvement 3
R Probability - Need a help to solve the below question Statistical Analysis Tools, Techniques and SPC 5
E In need of a new TGA sponsor - Small software company Other Medical Device Regulations World-Wide 4
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
B Need For BIS Standard Mark? Imported OEM's Power supply,Li-Ion Battery Other Medical Device Regulations World-Wide 0
F How many signatures do we need on calibration certificates? ISO 17025 related Discussions 8
B We need a QMS: file-based templates or software Other Medical Device Related Standards 23
M AQL table - I need to sample 1250pcs AQL - Acceptable Quality Level 3
atitheya Need of conducting medical trials in European Union EU Medical Device Regulations 2
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
D Does every piece of equipment used in a laboratory need to have an IQ protocol written and executed? ISO 13485:2016 - Medical Device Quality Management Systems 1
I IATF16949 Audit Preparation, Need "searchable" ANPQP 3.1 or latest IATF 16949 - Automotive Quality Systems Standard 1
A Does Class 1 Medical Device need to be certified to MDSAP? Canada Medical Device Regulations 5
S New to FAIR, need help in filling it out AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 8
S ISO 9001:2015 & ISO 14001:2015 - I need a format for Design & Development planning ISO 14001:2015 Specific Discussions 2
M Informational Some things the EU MDR 2017/745 does not tell you, but you may need to know to comply with it effectively – Part 1 Medical Device and FDA Regulations and Standards News 0
S NADCAP approval for Conventional Machining and Chemical processes - need assistance AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 10
S Do we need to validate Software used in Drug discovery and development process? Qualification and Validation (including 21 CFR Part 11) 2
W Tying the need for Demand Planning to a section of AS9100/9110 AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
R Do we need to treat local law as external origin documents? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 11
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Ashok sunder Need ISO 45001:2018 HIRA template Occupational Health & Safety Management Standards 9
QIE Electronic IFU - new project, need input Other Medical Device and Orthopedic Related Topics 0
G Defect codes and process codes need to be controlled AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
R Pls help --- Need expert advice on Video Measurement Measurement Uncertainty (MU) 0
M Informational FDA Panel: Too early to pull textured breast implants over cancer risk, need more data Medical Device and FDA Regulations and Standards News 0
I Training records and levels - When does training NOT need a record? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
