What Documents have to be Controlled?
#11
Actually, none of those things mean document control..............they are 'superficial' indications of control.
The schedule has to be approved, distributed or made available to those who need it, changes reviewed, approved and made available, removed when obsolete etc. Doing this electronically makes life soooo much easier!
That doesn't mean stamping it, or giving it a number. If you have a schedule changing that frequently, you will certainly have a challenge to make sure everyone knows 1) it's changed and 2) what changed.
BTW - why does it change so frequently? Is this an indication of (another) problem.........??
Likes: db
riograndeguy
#12
WARNING! Extensive use of smilies, cuz I just found em. Had to get it out of my system.
We're in the automotive business (2nd tier):mg:, if GM changes their piece requirements to their supplier (1st tier) either by increasing or decreasing that flows immediately to us:mad:. We do more of batch work (lbs as opposed to pieces).
example. customer A calls us:truce: and decreases by 15000 lbs on part number 111 and increases on part 222 both of which are due to ship 2 days from now. Our process is basically 2 steps, making a base part, and then deciding what finished parts are going to be made from that base part. So we've made our base part lbs to what the customer ordered last week:applause:, now they've changed their requirement:soap: we have to re-schedule the finished lbs on part 111 and part 222:frust:. In the meantime customer B has called:truce: and they've changed theirs as well:uhoh:. This happens frequently. Most of our customers are Mexico facilities.
We definitely bend over backwards to please our customers:horse: and allow them a very short lead-time (at the expense of an ever changing schedule) You're probably thinking kan-ban would be an answer:magic: but, most often the window of average ordered lbs is so large:bighug: it would be impossible to keep that amount available, in addition to requiring an expansive warehouse to keep "stock", which is a bad word:censor::singtome:.
riograndeguy
#14
I think what we'll do is, instead of leaving schedules at the machine, post 1 schedule on a board. All operators can check the board. That way there is only 1 schedule on the floor and the scheduler is the one to put it up and discard the old one.
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Controlled information versus defined documents / records ISO 13485:2016 - Medical Device Quality Management Systems 3
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
I R&D prototype documents need to be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D Controlled Documents & Note Making ISO 13485:2016 - Medical Device Quality Management Systems 4
Uriel Alejandro Including "Internal Rules" as Controlled Documents in a QMS Document Control Systems, Procedures, Forms and Templates 7
R How to Cross-Reference Controlled Documents Document Control Systems, Procedures, Forms and Templates 3
L Specific Question about Printing Controlled Documents. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Control of Records - Differences between Controlled Documents and Controlled Records Records and Data - Quality, Legal and Other Evidence 18
Q Modification in Controlled Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Employee Contracts : Controlled and Uncontrolled Documents Document Control Systems, Procedures, Forms and Templates 6
R Part Prints - Controlled and Uncontrolled Documents (e.g.: The Production Floor) Document Control Systems, Procedures, Forms and Templates 13
F ISO 9001:2008 Fundamentals: Basic Questions - Controlled Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
A Do controlled documents require a signature on every page as per 21 CFR 820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
x-files Documents required by the quality management system shall be controlled ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
A How are Electronic Editable Documents Controlled Document Control Systems, Procedures, Forms and Templates 7
K Printed documents can't be controlled Document Control Systems, Procedures, Forms and Templates 16
C Documents not controlled by the ECO (Engineering Change Order) process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Are SPC Charts Controlled Documents according to TS 16949? Quality Manager and Management Related Issues 4
G Document Control-AS9100 - Marking of Documents as Master Copy of Controlled Copy AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Document Control - Different documents which must be controlled not identified Document Control Systems, Procedures, Forms and Templates 11
R Controlled Documents vs. Signage Papers (ie, reminders, general information) Document Control Systems, Procedures, Forms and Templates 1
J Add Safety Policies/LOTO/etc. to Controlled Documents? ISO 13485:2016 - Medical Device Quality Management Systems 9
Q Documents uncontrolled when printed, if is not printed is controlled? Document Control Systems, Procedures, Forms and Templates 4
T Which controlled documents should be labeled "Confidential and Proprietary" Document Control Systems, Procedures, Forms and Templates 7
N Controlled Documents Distribution Query - Home Care Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
N Is this footer okay for our Controlled Documents? Document Control Systems, Procedures, Forms and Templates 14
B What to include on Controlled Documents that are managed Electronically? Document Control Systems, Procedures, Forms and Templates 2
H Document Control Defined? Determining what documents must be controlled ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
T Inheriting Another Company's Controlled Documents? Document Control Systems, Procedures, Forms and Templates 4
M AS9100 Clause 4.2.3 requirements - Documents required by the QMS shall be Controlled AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
A Are Job Descriptions and Organizational Charts Controlled Documents? ISO 13485:2016 - Medical Device Quality Management Systems 13
A Document Control File - Identifying all documents which need to be controlled Document Control Systems, Procedures, Forms and Templates 11
T Controlled Documents - Can a word document and excel spreadsheet be controlled? Document Control Systems, Procedures, Forms and Templates 5
J Lock-out / Tag-Out Procedures as Quality Controlled Documents? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
W Electronic Distribution of Controlled Documents: Validation required? Qualification and Validation (including 21 CFR Part 11) 5
E Wiki vs. Controlled Documents - Eliminating Conflicts Quality Manager and Management Related Issues 5
B Stamping Documents as "Controlled Copy" - Clause 4.2.3 Document Control Stamp Document Control Systems, Procedures, Forms and Templates 17
A Equipment List - Control or not to Control (Controlled Documents) Document Control Systems, Procedures, Forms and Templates 8
M Should Internal Audit Checklists be Controlled Documents? Document Control Systems, Procedures, Forms and Templates 9
A List of controlled documents for ISO9001:2008 Call / Contact Center ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Electronic Copies of previous versions of Controlled Documents in editable format Document Control Systems, Procedures, Forms and Templates 3
M All Internally Generated Documents ? Required to be Controlled or Not All? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
M Reissue of controlled documents - No changes identified Document Control Systems, Procedures, Forms and Templates 3
B Printed Copies of Controlled Documents Document Control Systems, Procedures, Forms and Templates 9
B "Controlled" stamp for Controlled Documents - Any alternatives? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
P Removal of Obsolete copies of Controlled Documents ISO 13485:2016 - Medical Device Quality Management Systems 8
S Distribution List of Controlled Documents Document Control Systems, Procedures, Forms and Templates 5
P Should Forms printed for daily use in the shop floor be controlled documents? Document Control Systems, Procedures, Forms and Templates 16
Manix Are Database Objects Controlled Documents and/or Records? Document Control Systems, Procedures, Forms and Templates 11
