What does a Process Capability Index of greater than 1 suggest?
G
goallout - 2009
Can anyone help me in answering this question.
"Assuming that you know its standard deviation, explain how the capability of a process to deliver product quality can be determined & explain what a Process Capability index of greater than 1 suggests."
I am stuck with how to answer this question in my course study as I have miss some of my class lessons
Jen Kirley
Quality and Auditing Expert
There some analogies in the iSixSigma web site. Ken K's is:
"The value itself can be thought of as the amount the process (car) can widen before hitting the nearest spec limit (garage door edge).
Cpk=1/2 means you've crunched nearest the door edge (ouch!)
Cpk=1 means you're just touching the nearest edge
Cpk=2 means your width can grow 2 times before touching
Cpk=3 means your width can grow 3 times before touching"
To explain, Ben says:
Consider a car and a garage. The garage defines the specification limits; the car defines the output of the process.
If the car is only a little bit smaller than the garage, you had better park it right in the middle of the garage (center of the specification) if you want to get all of the car in the garage.
If the car is wider than the garage, it does not matter if you have it centered; it will not fit.
If the car is a lot smaller than the garage (six sigma process), it doesn't matter if you park it exactly in the middle; it will fit and you have plenty of room on either side.
If you have a process that is in control and with little variation, you should be able to park the car easily within the garage and thus meet customer requirements. Cpk tells you the relationship between the size of the car, the size of the garage and how far away from the middle of the garage you parked the car.
Stijloor
Hello goallout,
This may be of help: "Cpk Vs. ppm Table."
Stijloor.
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
C Does a Chronically Unstable Process need a Capability Analysis? Statistical Analysis Tools, Techniques and SPC 10
S How does one calculate Cpm (Taguchi process capability) Statistical Analysis Tools, Techniques and SPC 16
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
N Small Company - Internal audit process - Who does the audit? Internal Auditing 16
Watchcat Does 820.30 include the manufacturing process? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Watchcat Does ISO 13485 7.3 include the manufacturing process? ISO 13485:2016 - Medical Device Quality Management Systems 14
M IATF 16949 - 8.5.6.1.1 Providing a list of process controls: Does this requirement add value to QMS? IATF 16949 - Automotive Quality Systems Standard 4
D Where does FMEA fit in your ISO 14971 Risk Management process? ISO 14971 - Medical Device Risk Management 13
A What does a good business practice Process Audit look like for AS9100D? Process Audits and Layered Process Audits 9
C Does Japan accept the Bracketing Approach for Process Validation Japan Medical Device Regulations 1
J Where does process validation fit within design & development? Design and Development of Products and Processes 7
N What does an effective design process look like? (shoots flare in the air) Design and Development of Products and Processes 2
M Does a process map satisfy 21 CFR 820.20(d) (Quality Plan)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
O Design and Development Process - Does one size fit all? ISO 13485:2016 - Medical Device Quality Management Systems 13
P Does anyone have a DFMEA process Interface Matrix .xls template FMEA and Control Plans 7
L Medical Device New Product Design & Development- How long does this process take you? Other Medical Device and Orthopedic Related Topics 1
J Does this look like a Process Audit? Process Audits and Layered Process Audits 6
C How does the EPA Establishment Registration Process Work? Various Other Specifications, Standards, and related Requirements 2
Marc Does ISO 9001 *require* that Internal Audits be Process Audits? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J What point does the Accreditation begin in the process? ISO 17025 ISO 17025 related Discussions 6
B ISO9001 Process Organisation Diagram - Does this make sense to you? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Does FMEA include Inspection Process? FMEA and Control Plans 11
F How does Process Mapping help to make a process more Transparent to the Customer? Process Maps, Process Mapping and Turtle Diagrams 2
X Audit Findings - The Process/Clause Matrix does not identify all the processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
Z Does this Process need an established Documented Procedure? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
R Does IVD 510k application always goes to pre-IDE and IDE process? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
D NADCAP Audit - No work in house - How does a NADCAP auditor audit the process? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
Q Does every Process Control listed in FMEA have to be listed in the Control Plan FMEA and Control Plans 4
D BMW Project - How does their APQP process work? IATF 16949 - Automotive Quality Systems Standard 6
G Is 100% Inspection a Control or does a Process need another type of control? FMEA and Control Plans 9
J Change Management System - Does ISO 9001 specify you need a process flow? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
H What process does 7.0 Product Realization refer to? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
B What does "Targeted process follows Normal distribution" mean? Statistical Analysis Tools, Techniques and SPC 9
D What does the entire process range mean? (MSA manual page 73) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
K Process monitoring, measuring and analyzing, does this means all company processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S TUV NCR No: 1 - Autoclaving: The process validation does not comply ISO 13485:2016 - Medical Device Quality Management Systems 8
J Does anyone have a procedure that covers Layered Process Audits Process Audits and Layered Process Audits 1
O PPAP Process Map - Does anyone map out the PPAP process for the Big Three? Process Maps, Process Mapping and Turtle Diagrams 2
J Does GM require an Inspection Standard in the APQP process? APQP and PPAP 3
Le Chiffre ISO 13485 Process Model Diagram - Does anyone have one? ISO 13485:2016 - Medical Device Quality Management Systems 9
T Does Delphi's requirement for layered process audits only apply to their products? Process Audits and Layered Process Audits 15
J Process Audit recommendation within ISO TS 16949? Does it exist like in VDA? Process Audits and Layered Process Audits 18
C Toyota Firewall Process - TPS - Does anyone know what this is? Details? FMEA and Control Plans 14
G Does The FDA oppose the use of Process Flow Charts? ISO 13485:2016 - Medical Device Quality Management Systems 8
L Does anyone have a completed AIAG Process Identification tool Manufacturing and Related Processes 4
S What does ?risks of the process? mean in process analysis? IATF 16949 - Automotive Quality Systems Standard 1
M APQP & PPAP - Does Toyota follow the APQP and PPAP process? Customer and Company Specific Requirements 5
B Process FMEA Scope - Does PFMEA cover Incoming (Receiving) Inspection & Dock Audit? FMEA and Control Plans 8
