What does Data Logger Accuracy = ? 0.25% of Full scale ? 1 Digit Mean?
K
KDASH
What does Data Logger Accuracy = ± 0.25% of Full scale ± 1 Digit Mean?
If a range of my data logger is upto 250°C and accuracy is ± 0.25% of FS ± 1 digit.
And a calibration certificate shows (showing only one reading)
Standard reading(°C)UUC reading (°C)error(°C)90.1190-0.11
then how will i check the readings are within accuracy limit or not??
Stijloor
Re: What does Data Logger Accuracy = ± 0.25% of Full scale ± 1 Digit Mean?
A Quick Bump!
Can someone help?
Thank you very much!!
BradM
If your full scale is around 250 C, then your tolerance is around .64C + 1 digit.
Are you stating that he only test point is 90.11C? That is the only test point listed?
Does it say certificate of Calibration or Conformance?
You may need to get it calibrated by a local competent lab.
sridharafep
Accuracy as a Percentage
The accuracy of an instrument is often stated as a percentage. For example, a voltmeter may be specified as 1% accurate. An important question is: 1% of what? Is it 1% of the reading or 1% of the "full-scale"?
Suppose you have a meter which reads voltages in the range of 0 to 100 volts. Then the full-scale value is 100 volts. Now suppose you use that meter to measure an unknown voltage, Vx, and it reads 50 volts.
If the accuracy of your meter is ±2% of the reading, then the actual voltage is somewhere between 49 volts and 51 volts since 2% of 50 volts is 1 volt.
On the other hand, if the accuracy is ±2% of full-scale (or f.s.) then the actual voltage is somewhere between 48 volts and 52 volts since 2% of 100 volts is 2 volts.
Accuracy is often given as percentage of full-scale, which means you should use the lowest scale you can to make the measurement. Suppose a 5% voltmeter has two ranges, 0-10 volts and 0 to 20 volts. If you want to measure a 9-volt battery then you should use the 10-volt scale since 5% of 10 volts is 0.5 volts while 5% of 20 volts is 1.0 volts.
Digital Meters: That Last Digit
Digital meters are often compared by the number of digits they can display. For example, a 2-digit meter can display values from 00 to 99 while a 3-digit meter can display values from 000 to 999.
Suppose you have a 2-digit voltmeter that reads 0 to 99 volts. Effectively it has a full-scale capability of 100 volts. Suppose you use it to measure a voltage with a value of 50.5 volts. What will the meter read? The only choices are 50 or 51, so either way there will be an error. That fact about digital meters is expressed by saying that all readings are plus or minus a count of one.
Digital Meters: Accuracy vs. Resolution
The fact that the reading on a digital meter is always uncertain by a count of 1, either up or down, defines the resolution of the meter. Resolution is the smallest change an instrument can measure (or "resolve"), so in a digital instrument it is the last bit: +/- a count of 1.
Like accuracy, resolution can be expressed as a percentage. A 2-digit meter has 1% resolution (1 count out of 99) while a 3-digit meter has 0.1% resolution (1 count out of 999). However, resolution is not accuracy. A 3-digit meter has 0.1% resolution buy may only have 0.5% f.s. accuracy. Read the specifications of the meter carefully: it is usually the case that the resolution is better than the accuracy.
Hershal
Metrologist-Auditor
BradM is correct. All I will add to that is take the calibrated baseball bat when you talk to the cal provider. :lol:
Point out that while you as the customer have a responsibility to provide the cal provider with what you need, they also have the responsibility to ask questions to clarify requirements. Hence, both have responsibility, but yours is to explain the need and usage and theirs to understand if/how they can provide what you need.
Sridharafep gave a good, detailed explanation. The +1 digit does typically refer to least significant digit and that is often due to rounding issues.
Hope this helps.
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
I 510k Performance Testing Studies (Raw Data) - What does the FDA expect 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
shimonv Does 510(k) submission need to include UDI Data Other US Medical Device Regulations 6
S Does anyone know what a healthcare GDSN data pool actually looks like? Hospitals, Clinics & other Health Care Providers 2
M Does anyone here have experience implementing PCI DSS (Data Security Standard) IEC 27001 - Information Security Management Systems (ISMS) 10
C Who does the Analysis of Nonconformances and other Data Analysis? Nonconformance and Corrective Action 23
E Does anyone have a P-chart template for operator data collection? Statistical Analysis Tools, Techniques and SPC 1
I 510k Approval - Does the FDA look for Clinical Data 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Plug Gage Calibration Report does not include actual data - ISO 9001:2000 section 7.6 General Measurement Device and Calibration Topics 3
J Fitting an Equation to a set of data? Does minitab have the capability? Using Minitab Software 4
D Ppk Sampling Method - Does data for Ppk have to been continuous? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
B Calibration Certificates - Does 17025 require that all 'As Found' data be recorded? ISO 17025 related Discussions 7
D ISO 9001 - Gigantic waste or Beneficial? Why does ISO 9001 exist? Got data/facts? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 235
G Gloss Fade - Does anyone have any data on the fade of gloss on wood? Manufacturing and Related Processes 1
D Does the data in a control chart have to be normally distributed? Statistical Analysis Tools, Techniques and SPC 63
H Does Powerway's APQP - PPAP fulfill TS16949 document and data control requirements? Customer and Company Specific Requirements 2
D Number of Distinct Data Categories:nDC: Where does the constant 1.41 come from? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
B Does FDA Registration QSR need to cover non-medical devices for contract repackager? US Food and Drug Administration (FDA) 0
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
H How does a gas turbine work on diesel fuel? Oil and Gas Industry Standards and Regulations 12
G What does performance specification include? US Food and Drug Administration (FDA) 1
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How long does it take to register a product with MHRA? UK Medical Device Regulations 3
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 4
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
A What does this sentence "this symbol shall be used in the orientation shown" mean in ISO 780:2015? Other Medical Device Related Standards 4
L Turkish Requirements - Does the Software need to be translated? CE Marking (Conformité Européene) / CB Scheme 2
