What does the Gage R&R results tell about my Accept/Reject Decisions?
Tim54
Need some help in applying the gage R&R. Let's say I've conducted my gage R&R study and have the results and I know my EV, AV, and R&R percentages using the avg/range method. Now, how do I use/apply that to 'real world", i.e. what is the relationship of the results to the actual specification tolerance? for example, using the QI macros AIAG Ford test data:
my tolerance is 2
% using TV, EV = 9.0%, AV = 5.0%, R&R = 10.3%
% using tolerance, EV = 7.2%, AV = 4.0%, R&R = 8.3%
What is this telling me about the accept/reject decisions that I'm making for this theoretical product? thanks for your help.:confused:
Tim54
thanks for the response. I guess what I'm trying to understand, but didn't know how to express it is, how do you or can you factor in the gage r&r % to your regular inspection results, i.e. can you determine how much is the gage error causing us to reject good parts (alpha risk)or accept/release bad parts (beta risk). thanks
Use the Search > Advanced Forum Search option above.
Enter "Performance Curve" into the keyword field and restrict the search to the Gage R&R sub-forum. The search results will provide several threads and attachments that will provide the information for which you are looking.
Barbara B
The gage performance curve will give you the probability for accepting a good part. It is drawn for 1 single part with known value as you need the bias = measurement - known.value.
For a Gage R&R study there are two different risks for misclassification: joint probability and conditional probability. The first gives you two probabilities for the combination of "part is good & will be rejected" and "part is bad & will be accepted". The latter is calculated a little bit differently and gives you the two probabilities for "part will be rejected under the condition part is good" and "part will be accepted under the condition part is bad" (see attached screenshot from the Minitab help).
Both kinds of probabilities could be calculated in Minitab
Stat > Gage R&R (crossed) > Options
after filling in values for the specification limits and checking "Display probabilities of misclassification". Note: The method for the analysis has to be ANOVA. Xbar-R doesn't give you the chance for calculating risks of misclassification.
Best regards,
Barbara
a consideration beyond the statistical probabilities and calculations is the larger concept of what it means to run at or near a specification limit. Most specifications are nto engieered hard lines in the sand where all is happy when wthin the lines and all is horrible when you are outside the lines. Many times we are dealign with either stackup conditions, future deterioriation or variation due to environmental conditions. Because of this we are better off to focus our efforts away from the 'mathematical probabilties' of a false acceptance or false rejection from measurement error and towards improving our process so that we are not running at the limits.
If we really need to understand the false accept/reject rate for some reason (such as justifying work to improve the process or guardbanding of some type) my experience has shown me that emperical categorical studies of parts near the limits are far better at quantifying the rate in such a way that managers can believe the answer where the statistical approach tends to make their eyes glaze over...
C Gage R&R study definition - Results for GRR is .0005 - What does this number tell me? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A Does Torque Gage Need Validation? Reliability Analysis - Predictions, Testing and Standards 4
A Does an attribute study (Go/NoGo pin gage) need two studies (1 for each pin) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Does Validation = GR&R for a Go / No Go Gage IATF 16949 - Automotive Quality Systems Standard 3
S Does a CMM (Coordinate Measuring Machine) require Gage R & R study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
hogheavenfarm Does anyone know of a calibrated Fillet weld gage? General Measurement Device and Calibration Topics 12
P What does NO GO mean on a thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 23
C Does all gauges mean every gage? Manufacturing Engineering (Paragraph 7.6.2) IATF 16949 - Automotive Quality Systems Standard 10
Q An Engineer that does not understand gage R&R? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
C Gage R&R @ 10% - Does that mean you should cut your tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
P Plug Gage Calibration Report does not include actual data - ISO 9001:2000 section 7.6 General Measurement Device and Calibration Topics 3
J Unilateral Gage R&R (GR&R) - Minitab 13 - Does this study pass or fail and WHY? Using Minitab Software 17
P Gage R&R - What does the % tolerance says about my Gage Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
R What does the P/t ratio (Precision/Tolerance) =RR/(USL-LSL) say about my gage study? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S Why Does a Thread Plug No Go Gage Mean Fail? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
J AIAG MSA and Gage R&R - What does the Process Variation % R&R truly mean? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
J Gage R&R Software - Does anyone have experience using Mitutoyo's "MeasurLink"? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
D Does every company or employee owned gage have to be calibrated? General Measurement Device and Calibration Topics 2
A How does WIV (Within Part Variation) affect Gage R&R? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
0 To which part of 13485 does this refer? ISO 13485:2016 - Medical Device Quality Management Systems 3
lanley liao Does the customer`s trademark belong to customer-supplied property? Oil and Gas Industry Standards and Regulations 2
H How does a gas turbine work on diesel fuel? Oil and Gas Industry Standards and Regulations 12
G What does performance specification include? US Food and Drug Administration (FDA) 1
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
C Does an accessory need an IFU if it use is discussed in the Parent device IFU? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S How long does it take to register a product with MHRA? UK Medical Device Regulations 3
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
A Brexit When does the UK responsible person need to be in place? UK Medical Device Regulations 10
N Does anyone have experience of GB/T 34986-2017? China Medical Device Regulations 1
Z Does anyone have experience with EN ISO 17664 ? IEC 62366 - Medical Device Usability Engineering 9
F Does anyone have an ESD quality/cooler talk to share? Training - Internal, External, Online and Distance Learning 4
A What does this line from MDCG 2020-3 (MDR art. 120 substantial change) mean to you? EU Medical Device Regulations 4
T What does AS9100 mean when it says you must establish a process to do X? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 24
L Does a backdate form format can be changed if wrong revision is used? Document Control Systems, Procedures, Forms and Templates 8
B General Motors and Honda Alliance - What does this mean to suppliers? IATF 16949 - Automotive Quality Systems Standard 3
C ISO 13485 :2016 - CAPA - Does every CAPA need to be checked by regulations? ISO 13485:2016 - Medical Device Quality Management Systems 9
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N FDA UDI - Label vs. Labeling - Does the insert need to include UDI? Other US Medical Device Regulations 1
A Does anyone have a checklist of API Spec 650 13th Edition? Oil and Gas Industry Standards and Regulations 0
D Does Manufacture can submit CE mark application under MDD with NB for his New product after May 2020? EU Medical Device Regulations 3
A What does this sentence "this symbol shall be used in the orientation shown" mean in ISO 780:2015? Other Medical Device Related Standards 4
