What Exclusions to the ISO 9001 standard are allowed? Clause 1.2
samsung
#21
Re: Exclusions to the ISO standard
Statutory requirements usually relates to the technical specifications such as minimum required compressive strength at 28 days, maximum chloride content, setting characteristics and some others. How you design your product, test, manufacture, validate and others are entirely up to your own.
Over most part of the whole world, manufacturers either follow the practices of the Cement and concrete associations of America or UK.
Thanks a lot for your input. It is correct that statutory requirements relates to tech.specs. only & do not require 'validation' as defined by 9001. However, 3 & 7 days Compressive Strengths (even 1 day strength is also determined) & all previous checks at all points of production right from mining of limestone, may be used as supporting (objective) evidence of the process having been duly validated as planned.
Just curious ... have you checked with other manufacturers on how they tackle this "statutory" specification since its statutory, all manufacturers would be bound by this requirements ?
I have so far not checked with any other manufacturer but a good idea to have a try. I will also check with Cement & Concrete Association of US & UK.
Best regards,
Big Jim
#22
:bigwave:I've come to the conclusion after studying our manual that I don't need to exclude anything. My shop process goes simply from order entry to shop to assy to test and on out the door. If field service is required that is covered as well. The only thing bothering me now is the statement:
"Where Premier chooses to outsource any process that affects product conformity with requirements, Premier ensures control over such processes. Controls of such outsourced processes are identified within our QMS.
note: Processes needed for the Quality Management System referred to above include processes for management activities, provision of resources, product realization and measurement"
The processes that are spoke of I think are procedural processes. This was worded to leave alot of gaps. Any thoughts?Help?:frust:
I really hate chasing after someone elses cheap work. sorry had to say it. just venting.:mad:
You are talking about two different things. Exclusions and Outsourcing. Exclusions are related to 1.2 and 4.2.2. As others have explained, you can take exclusion to things from element 7 only. You can only take exclusion if you don't do it and if you have no responsibility to do it in meeting customer requirements.
Outsourcing is addressed in the last part of 4.1 as you quoted. If you choose to outsource something, it has to be controlled and that control has to be part of your quality management system. Outsourcing is usually controlled in the purchasing process. You cannot claim exclusion for things that you outsource as you still need to control them.
JaneB
#23
unforntunatly yes. A consltant wrote it back in 1994 or so. Its a been a bear to update.
The advice to chuck it away and start again is very sound advice.
Trying to work on one based around that 94 version will drive you bonkers, and is not likely to be productive. Out with the Ark and let's get with the 21st Century!
JaneB
#24
You only need to put in an 'exclusion' clause if you want to exclude a particular clause. You can put the exclusion bit anywhere you want to. You can only exclude clauses from section 7, as stated.
To help you understand how to do it, there's a document you can get from ISO with a range of examples in it. It's not bad.
See the TC site, and get the document called Guidance on ISO 9001 Sub-clause 1.2 'Application'
If you read through the examples in the Appendix to that document, & look at the relevant clauses, this may help you to understand how it works.
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K ISO 9001 2015 Exclusions - Product Design is purchased. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R Exclusions to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Quality Manual Statements - ISO 9001:2008 Design and Development Exclusions Design and Development of Products and Processes 6
A ISO 9001 Certificate with EXCLUSIONS Statement Design and Development of Products and Processes 7
T Need Exclusions to be shown in ISO 9001 Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
C Permissible ISO 9001 Exclusions/Omissions for the Service Industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S ISO 9001 Clause 7 Exclusions and Justifications for a Business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
L ISO 9001 Registration of 1 Plant in a Company - Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Question about Design Exclusions - Clause 7.3 of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
W ISO 9001:2008 Clause 7.3 Design and Development Exclusions Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Guidance on ISO 9001 Clause 7.3 Design and Development Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
W ISO 9001 Clause 7.3 Design and Development Sub-Clause Exclusions Design and Development of Products and Processes 14
T Exclusions for IT services - ISO 9001 Clause 7.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R ISO 9001:2008 Permissible Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
A Permissible exclusions in ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Permissible Exclusions - ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 158
T Examples of Exclusions from ISO 9001 paragraphs 7.1 to 7.5 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
G Design vs. Repair / Refurbishment Modifications - ISO 9001 Design Exclusions Design and Development of Products and Processes 4
I ISO 9001:2000 Exclusions for our Scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
I ISO 9001 - Exclusions Doubts - Placement consultancy services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Questions About Exclusions in ISO 9001 - Clause 7.5 Production and Service provision Service Industry Specific Topics 22
R Where to Document Exclusions per ISO 13485 and ISO 9001 ISO 13485:2016 - Medical Device Quality Management Systems 2
B ISO 13485 exemption and/or exclusions ISO 13485:2016 - Medical Device Quality Management Systems 5
M Exclusions clause 7.3 - Our organization doesn?t design products - ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 6
A ISO 13485 Section 7.3 Design & Development Exclusions ISO 13485:2016 - Medical Device Quality Management Systems 7
D Quality System Manual - Exclusions from ISO 13485 Clause 7.5 ISO 13485:2016 - Medical Device Quality Management Systems 4
N ISO 9000:2000 in a service company- Documentation - Do we have to explain exclusions? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P ISO 13485 Exclusions - Production-related requirements - Section 7.5 ISO 13485:2016 - Medical Device Quality Management Systems 5
F AS9120B - Exclusions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B Exclusions or justification for non-applicability of IEC standards Reliability Analysis - Predictions, Testing and Standards 1
M Eligibility for certification to IATF 16949 - Exclusions IATF 16949 - Automotive Quality Systems Standard 1
C ISO13485 exclusions for design and automation company ISO 13485:2016 - Medical Device Quality Management Systems 2
M AS9100D - Updating Scope Exclusions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
C TS 16949 Exclusions outside of clause 7.3 IATF 16949 - Automotive Quality Systems Standard 6
I AS9100 - What QMS Exclusions are allowed? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S How to document "Exclusions" in the Quality Manual AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
M TS16949 Exclusions - Design & Development is carried out by our parent company IATF 16949 - Automotive Quality Systems Standard 14
B TS16949 - 7.3 Design and Development Exclusions for a Service Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
x-files [Exclusions] 7.3 Design and development vs. Thermal Powerplant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J ISO13485 Clause exclusions for a Medical Software Company ISO 13485:2016 - Medical Device Quality Management Systems 9
N Permissible Exclusions for QM ISO9001:2008 Audit and Consultancy Services Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J AS9101C - Scoring for Unjustifiable Non-Addressed Clauses (Exclusions) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
L Same Quality Manual - Different Exclusions (multisite) - 7.3 Design and Development ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
E Design authority for a plastic product for the HGV industry - Possible Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J MDD Class III Exclusions EU Medical Device Regulations 2
E Exclusions from clause 7.5 (Production and Service Provision) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Exclusions and Conflicting Quality Manuals between Plants and Divisons Quality Management System (QMS) Manuals 10
S Recruiting and Staffing Firm - Exclusions Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
T Exemptions and/or Exclusions from procedures Document Control Systems, Procedures, Forms and Templates 22
