What happens when a company loses ISO 9001 recertification?
djdust34
Hello all,
My company received 2 majors during our annual review. I feel as though we have corrected the findings, but want to plan for the worst. What is the impact to the company of the audit goes poorly? What will we have to do? Will we automatically lose customer business? Can the follow-up audit results be challenged if we disagree?
Thank you in advance!
normzone
Generally all the company employees disappear - rumor has it that the secret program relocates them to an island, where they are used for dangerous experiments.
No, seriously, you'll probably be okay if you've corrected the issues.
The company will need to address the reasons the audit went poorly.
Please see the answer above. You may have to do it rather quickly.
No, first the customers would have to learn of the impacts of the audit. If you fix the problems that will be minimized.
Any audit can be challenged, but I wouldn't go there unless there was a very good reason to do so, such as the auditor being way off base.
Project Man
First, as an ISO 9001 company you work with other ISO certified companies. I would have someone you trust review it for you (Or you could hire a consultant). If after that you are still confident you've addressed the issues then you should feel confident.
Second, you hired the auditor. If it feels like they are trying to sink your ship without cause, call the company they work for and ask for a different auditor.
As far as potential impact: If a customer chose you solely because you were certified than you will probably lose them. Past that, it's all how you handle it.
dsanabria
Hello all,
Just out of curiosity what were the Majors written against or what does the auditor consider a Major.
Hello all,
Don't Panic - it takes a while and there is a process to remove your certificate.
For now - focus on correcting the issues to the satisfaction of the auditor - send the auditor a preview and ask if you are in the correct path and if there is additional information that is required. Most auditors will provide positive feedback (no consulting) as to meeting the requirements of the standard.
Hello all,
At this point the audit is over and the purpose of the visit is to close out the open items of the major findings.
Hello all,
The registrar will provide you with action items and the next step in getting back your certificate... but you are already drowning and you are not even close to the water... chill
Hello all,
That depends on positive communication with the customer and depends on the customer requirements... more than likely you won't loose client if the issues are corrected and a positive attitude is taken in meeting the requirements of the standard and the customers.
Hello all,
Yes you can appeal but if you work with the auditor - chances are that this step will not be required. However, if you choose to appeal, the auditor will provide information of how that is done or call the registrar and let them know that you would like to appeal the results of the NCR
rogerpenna
What happens if I lose my ISO certification for not doing the external audits?
We are not worried about losing clients. Our clients do not demand ISO. And ISO certificate are not approved to be used as some advantage at public contract biddings. (which are our companie's main source of income)
What I want to know is what is the problem of simply doing it again next year? Will it be much lenghtier than if it was just a re-certification?
John C. Abnet
Teacher, sensei, kennari
This begs the question "why" is your organization ISO 9001 certified? What is top management hoping to achieve with the ISO 9001 certification? Is the certification simply to "fly the flag" or is there benefit intended to be gained (as there should indeed be).
What does "top management" say about the risk of having the certification pulled? Is top management not horrified and intent on ensuring the resources necessary to correct the problem?
To answer your question: If your organization loses its ISO 9001 certification, it will need to start from scratch. Stage 1 audit, Stage 2 audit, initial certification costs, etc...
Not a good place to be.
Hope this helps.
Be well.
rogerpenna
1 - the ISO standard helped us achieve reduction in costs and lessen our risks in several areas. We saw it important to organize the company as it grew based on some outdate and disorganized practices. That is the benefit to be gained.
2 - Fly the flag... we do it only for pride. Again, it's completely irrelevant to our customers, because we work 99.9% with government biddings, where you can´t even use ISO as an "advantage". It's usually lowest price + certificates of non debt, certificates that X and Y service in Z and W quantities were already performed by the company, etc.
3 - Over 10 years ago, a brazilian standard for Housing (specially highrises) Quality Construction was created in Brazil. PBQP-H. Having it became a necessity or a helper to get credit lines from a State Bank usually involved with development projects.
The standard was based on ISO 9001 with some extra stuff added in. The standard was later extended to Civil Infrastructure, and there were federal projects to allow Governments (federal, state or municipal level) to require or accept (as extra factors) a PBQP-H certificate in public biddings.
So having an ISO and then getting our PBQP-H certificate was also eyeing that possibility, which would increase our chances in public biddings.
However, due to lobbying and judicial decisions based on Public Biddings Law, PBQP-H was NEVER accepted for public biddings. There are zero public biddings we have ever participated that require it. So without that real use, it ended up being only number 1 and 2.
They like the certification for reasons 1 and 2. The risk of having the certification pulled is more about the financial cost of re-doing it again from step 1.
Which will mean that if Top Management think the cost of stopping some departments to do the external audits amid a crucial time (election year, our income is through the roof and nobody has time to spare) is worse than the cost of re-doing the certification, they would opt for re-doing the certification. Plus the pandemic problem and the fact we can´t do online audits at job sites, because they are often remote and with poor internet connection.
John C. Abnet
Based on this response @rogerpenna , then I am at a complete loss as to why Top Management would have allowed the status of the ISO 9001 implementation (the effectiveness of the QMS) fall into such a state as being at risk of having the certification pulled.
Comment "1"...
1 - the ISO standard helped us achieve reduction in costs and lessen our risks in several areas ....
...is contradictory to your later comment...
"Which will mean that if Top Management think the cost of stopping some departments to do the external audits amid a crucial time (election year, our income is through the roof and nobody has time to spare) is worse than the cost of re-doing the certification."
The later comment causes me to believe top management does not really believe/is not committed to comment "1".
Be well.
John Predmore
I didn't see anyone else mention this point. One common reason for a major non-conformity is the auditor believed your system had widespread deficiency(s). When resolving the 2 audit non-conformances, it is not enough to correct the few specific examples identified in the audit report - you should re-audit your system to uncover and correct all similar deficiencies which were not uncovered in the limited time-frame of the outside audit. Your root cause investigation must go beyond the specific examples cited - as an example, why was form 1234 missing an approval signature - to the more fundamental question - what is missing from your document control process that forms missing approval got processed and no one noticed, no one questioned the missing approval (just as an example for this comment). In this way, you show leadership in addressing a systemic deficiency, if that is indeed the reason for the major findings.
C Acquiring an IATF 16949 Certified Company - What happens at the next audit? IATF 16949 - Automotive Quality Systems Standard 4
B What happens to your ISO 9001 registration if you are acquired by a Company Without ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N What happens after the corrections have been made when audited? General Auditing Discussions 4
M What happens to certifications if the issuing certification body loses accreditation? Supplier Quality Assurance and other Supplier Issues 2
R What happens during a Stage 1 MDSAP audit? ISO 13485:2016 - Medical Device Quality Management Systems 4
A Brazil: Termination of business relations with BRH – what happens to registrations? Other Medical Device Regulations World-Wide 1
I How to handle pending FSN when incident happens? EU Medical Device Regulations 1
R In this type of Legal Manufacturer-CMO arrangement, what happens to the DHR? ISO 13485:2016 - Medical Device Quality Management Systems 1
T What happens in an ISO 9001:2008 Re-Certification Audit? General Auditing Discussions 11
Marc What happens when computers stop shrinking? After Work and Weekend Discussion Topics 3
A What happens if an External Audit NC (Nonconformance) is not closed in 90 days? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B What happens if we evaluate supplier as not approved and there are no anothers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
T Already ISO 9001 Certified - What happens when we get ISO 13485 registered? ISO 13485:2016 - Medical Device Quality Management Systems 11
Marc What happens when sleepwalkers go online After Work and Weekend Discussion Topics 3
R Control of Non-conforming Goods (Product) - Tracking what happens to the goods ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
P ISO14001 Certification - What happens if we have several minor audit findings Miscellaneous Environmental Standards and EMS Related Discussions 2
A Only One Automotive Customer - If we lose that customer, what happens to our cert? IATF 16949 - Automotive Quality Systems Standard 6
M What happens if a Major or Minor Nonconformance is found during Surveillance Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
L Looking for a universal(?) example to illustrate what happens when an error occurs Nonconformance and Corrective Action 4
B FMEA Evolution: What Happens to Recommended Actions? FMEA and Control Plans 7
F Cpk higher than Cp - Explain the relationship and why this happens? Capability, Accuracy and Stability - Processes, Machines, etc. 12
G What is Design&Development and what is product in a Research company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Any company who can provide hollow micrometer transferable patches for drug delivery? Other Medical Device and Orthopedic Related Topics 1
M Best ISO9001:2015 Auditing Company in Chicagoland? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
J US based company no longer selling in the EU: Clinical Evaluation Report and PMS requirements EU Medical Device Regulations 1
A PMS and reportable incidents for company that outsources manufacturing? ISO 13485:2016 - Medical Device Quality Management Systems 2
A Small Company Implementing ISO 13485 Timeline/Process/Steps Advice ISO 13485:2016 - Medical Device Quality Management Systems 5
C ISO Certified Company ERP implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Pros and cons to transition to AS9100 for non aerospace company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
L ISO13485:2016 and Subsidiary Company ISO 13485:2016 - Medical Device Quality Management Systems 4
M Does any one know if company is allowed to submit appeal for rejected registration file Other Medical Device Related Standards 0
T Company AS9100D External Audit Preparation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
E Device compatibility with other company's devices US Food and Drug Administration (FDA) 0
M An interesting question about import company Other Medical Device Regulations World-Wide 5
T ISO9001:2015 for Work-from-home company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 48
M Role of Quality Manager in a manufacturing company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
R How many process maps are adequate for a company for IATF 16949? Process Maps, Process Mapping and Turtle Diagrams 17
M Questions concerning QMS and/or company specific nonconformance Customer Complaints 2
Aliken Recommendation for the ISO 13485 certification company ISO 13485:2016 - Medical Device Quality Management Systems 7
C ISO Cert and Parent Company is not Certified ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
H Product Safety & Conformity Representative (PSCR) Training Company IATF 16949 - Automotive Quality Systems Standard 0
Q Training Machinists on Company Processes Training - Internal, External, Online and Distance Learning 6
C Regulatory Affairs in a start-up medical device company Career and Occupation Discussions 2
Q Approving distributors as suppliers for automotive company Supplier Quality Assurance and other Supplier Issues 1
P How to keep a ISO 9001:2015 certification when a company is sold ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
cgaro62 Does FDA apply to a non-medical 13485 certified custom manufacturing company? ISO 13485:2016 - Medical Device Quality Management Systems 11
M New Daughter company - ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T Accreditations as part of 9001 - Quality checks on your company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Javier Guan BlipSnip is it Legit Company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Seeking Consultant for Orthopedic Start Up company Other Medical Device and Orthopedic Related Topics 1
