What if I find a defect after AQL (Inspection)? Pharmaceuticals
#11
Hello, Alan,
I am familiar with Trigger Alarm Systems, rather than AQL.
My question is: If my sampling lot size is 200, with acc as 7, rej as 8, found 8 defective units when I am at the 50 count, do I stop the inspection and reject the whole batch? And also if after taking a fresh sampling batch, another 200, should I use the same method?
Thank you,
More information is needed:
  • Is a static population being sampled?
  • Are you sampling a lot from a supplier, or material that will be further processed and/or sent to a customer?
  • What sort of criteria are being used in inspecting the samples?
  • How did you arrive at your sample size and acc/rej numbers?
  • Would you really accept 8 defectives?
Zero_yield
"You can observe a lot by just watching."
#12
If I'm understanding the question correctly, I would generally recommend continuing to test the 200 even if you've had 8 failures in the first 50.
Once you've failed the lot, I'm assuming someone is going to conduct an investigation (either internally or at your supplier, if it's a purchased part). The person conducting the investigation is going to need to define the problem and assess the risk and impact. If you haven't finished your sampling, it could be hard to impossible to understand the extent of the issue. If you stop inspection, you might miss the quantity of defects or the range of defect types.
For example, compare two scenarios: You test the other 150 and have 0 additional failures, and you test the other 150 and have 24 additional failures (i.e., about 8 for every 50). If 15%+ of the batch is defective, it points to a much bigger failure that needs immediate correction than being a hair over AQL.
If you don't finish your sampling, you also might miss another issue with the product. For example, let's say these are a molded plastic component you purchased from a vendor, and the inspection is cosmetically inspecting 50 samples from the beginning of the run, 50 samples from the end of the run, and 100 samples pulled randomly in-between. Let's say you've only checked 50 samples from the beginning / middle of the run and found excess flashing around the edges. If you don't check the parts from the end of the run, you might miss that there was discoloration, malformed parts, or embedded particulate that didn't show up until the end of the run.
Of course, this depends somewhat on the time / effort / expense of testing each unit. The company I work for has a 100% inspection for certain characteristics. The general rule of thumb is that if the first ~20% of a batch all fails, stop inspection and escalate to a nonconformance. It's just not worth the equipment and operator time to keep inspecting something we're reasonably certain is going to fail anyway.
Zero_yield
#14
Thank you very much for your quick response. I would say the rule of thumb applies here.
Just for some more context around it: That started as a decision between Manufacturing, Quality, and Engineering. It's ultimately a business decision - the product is being scrapped either way, so there's no customer/consumer risk. It's all producer/business risk. We're consciously accepting the cost if any of those parts might have passed to reduce the cost of inspecting units we suspect will fail anyway. That is how we've assessed minimizes the financial impact to the business for our particular process and product.
Since you're inspecting to an AQL level, you're definitely failing the inspection either way, so I can see the logic in stopping the inspection and scrapping the batch. Depending on the situation, you may want to get the right people in the room to discuss the financial impact and make the right decision for your particular business, process, and product.
J0anne How to find Certifying Bodies for US based & sold Medical Devices? US Medical Device Regulations 11
I Where to find MDR compliance device? EU Medical Device Regulations 6
John Predmore Informational Can you find the error in the spreadsheet? Misc. Quality Assurance and Business Systems Related Topics 3
Ajit Basrur Where to find a pagination requirement as "Page x of y"? ISO 13485:2016 - Medical Device Quality Management Systems 7
G How to find applicable standards for a new product? EU Medical Device Regulations 6
A How to find Info about updated Standards EU Medical Device Regulations 2
D Searching for attachments can't find it Forum News and General Information 3
C I need your help to find the action plan for these quality objectives Misc. Quality Assurance and Business Systems Related Topics 23
S Looking to find a pharmaceutical manufacturer that would be interested in buying or licensing a USDA 510k clearance General Information Resources 4
L How to find a good 510(k) submission training? Other US Medical Device Regulations 2
L How to find a good online CFDA submission training? China Medical Device Regulations 5
R How to find the proper the fieids of IVD distributers and develop the medical device markets in Thailand? Manufacturing and Related Processes 0
T ANOVA analysis to find F test. Using Minitab Software 3
MedicalDevicesCanada How to find a medical device contract manufacturer, MDSAP certified? Canada Medical Device Regulations 6
I How to find required testing for a specific device? Other US Medical Device Regulations 3
N How to find column number for the last non-empty column? Using Minitab Software 0
D Any recommendations on where to find experienced quality hires in Chicago area? Job Openings, Consulting and Employment Opportunities 2
M Find updates to REACH and Rohs regulations REACH and RoHS Conversations 1
N Where to find Regulations for Reprocessing and Reuse of Single-Use Devices Other Medical Device Related Standards 2
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
S How to find technical specification for facilities maintainance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Where can I find examples of PPAP? APQP and PPAP 6
J Where can I find the latest update to Reach and ROHS? REACH and RoHS Conversations 9
G Where to find Proficiency Test provider for photometrics (spectral %R, %T, photo density) General Measurement Device and Calibration Topics 9
C TL-9000 Certifying Body Issue - Auditor failed to find an issue for 10 years TL 9000 Telecommunications Standard and QuEST 16
R How to find out the UMDNS code for medical devices CE Marking (Conformité Européene) / CB Scheme 1
M Plating standards - Where to find information AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Where I can find an ISO 13485:2016 Audit Schedule example? ISO 13485:2016 - Medical Device Quality Management Systems 4
Proud Liberal DFMEA / PFMEA linkage - Where in the standards do I find it? FMEA and Control Plans 5
N Where I can find an Excel sample/template for recording Delivery Time and Cost Excel .xls Spreadsheet Templates and Tools 2
R Specification on flare testing extruded aluminum - Where to find Design and Development of Products and Processes 1
A AS9100 Rev:D in Spanish - where can I find a Spanish version? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
I Moving into Clinical Trials and need to find GMP Suppliers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
B Where can I find an English version of Japan's PMD Act? Other ISO and International Standards and European Regulations 2
S Where to Find DEV and DFE numbers on FDA Website Other Medical Device and Orthopedic Related Topics 3
P Calibration in the UK to ISO 17025..cant find anyone ISO 17025 related Discussions 8
N Where to find a Qualified FDA Supplier Auditor located in China China Medical Device Regulations 7
G Where I could find any project HSE plan templates Occupational Health & Safety Management Standards 4
A Where to find a Draft Copy of IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 23
M How to find the number of required data - Correlation with 4 variables Using Minitab Software 2
I Where to find VDA 6.3 Robust Production Process (rpp) PDF file ? VDA Standards - Germany's Automotive Standards 1
P Where to find the UMDNS code for CE Mark CE Marking (Conformité Européene) / CB Scheme 1
X Where to find UAE medical device registration regulation and guidelines Other Medical Device Regulations World-Wide 3
I Non-functional Corrective Action - Could Not Find some Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
P Where to find conformance statistics for ISO 15189 Other Medical Device Regulations World-Wide 1
J Where can I find a product's CE Mark Number? CE Marking (Conformité Européene) / CB Scheme 20
L Find Local Authorized Representative (LAR) for medical device EU Medical Device Regulations 5
H How to find a good ISO 9001 Implementation Consultant in Calgary, Canada? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Process Capability - Changing Limits to Improve Cpk or find Root Causes? Capability, Accuracy and Stability - Processes, Machines, etc. 8
R Where to find 21 CFR Part 820 Translated into Czech, Spanish, and German 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
