What is a Control Plan at "Material Level"?
Rameshwar25
IATF 16949:2016, clause 8.5.1.1 text
"The organization shall develop control plans at the system, subsystem, component, and/or material level for the relevant manufacturing site and all product supplied, including those for processes producing bulk materials as well as parts."
Please explain what is control plan at material level.
Judging from this hierarchy, I would interpret it to mean at the raw material level to you as the organization, meaning the steel/copper/brass, plastic resins, rubber compounds, etc. that you may use. If you are strictly an assembly operation, this may not be applicable.
John Predmore
A control plan for purchased product is how you assure quality. At the material level, how do you assure quality of raw material? You may buy ½" diameter bars and I buy ½” diameter bars, but I buy from a catalogue and your requirements demand you specify hardness, surface finish, straightness, etc.
My control plan may be nothing more than check the packing slip against the purchase order and make sure I received the quantity and catalogue number that I ordered.
Your control plan may require metal certifications traceable back to the steel mill, maybe you have an incoming inspection department which does physical testing, maybe you pay for metallurgical analysis of grain structure. The degree and extent of incoming evaluation, documentation and control is how you or I assure the material meets our needs.
Rameshwar25
But, control plan at component level also contains details of raw material- size, material grade etc. There is no requirement for a separate control plan at material level if we make only part from bulk material.
I am more convinced reply of Mr Miner. My perception is now that control plan at material level is required for bulk material production. If we are making a part from purchased bulk material, we need not to make it.
Rameshwar25
Pl do not restrict control plan to only material inspection. It includes all steps from raw material receipt to packing and dispatch with more focus on manufacturing processes.
DuncanGibbons Manufacturing Plan vs Material Specification vs Control Plan Manufacturing and Related Processes 5
B QCP (Quality Control Plan) from client with EN 10204 type 3.1 Material Certificates Various Other Specifications, Standards, and related Requirements 2
K ISO 2859-5 (single run production) control plan issues FMEA and Control Plans 2
S Control plan - Multiple batches Manufacturing and Related Processes 2
Q Control Plan and the frequency of sampling FMEA and Control Plans 11
C Control Plan APQP and PPAP 7
S Control plan for "highly automated processes" FMEA and Control Plans 3
B 8.5.1.1 Control Plan - question audit NC IATF 16949 - Automotive Quality Systems Standard 5
B QM Plan vs Control Plan IATF 16949 - Automotive Quality Systems Standard 3
N AS 13004 Control Plan and AQL FMEA and Control Plans 1
J PFMEA/control plan question- PLEASE HELP ! IATF 16949 - Automotive Quality Systems Standard 8
Y FMEA link to Control Plan frequency and sample size FMEA and Control Plans 19
S Linking control chart with control plan Statistical Analysis Tools, Techniques and SPC 5
S Operation of possible rework in control plan FMEA and Control Plans 8
M Process & Product Characteristic in Control Plan FMEA and Control Plans 17
Sonja D AIAG VDA PFMEA and Control Plan training FMEA and Control Plans 9
A Control plan for IATF - example? FMEA and Control Plans 1
S Maintenence related action in Control plan FMEA and Control Plans 3
R Control Methods in Control Plan FMEA and Control Plans 5
L Looking for Control Plan and FMEA Stamping process FMEA and Control Plans 2
Jimmy123 IATF16949 Control Plan FMEA and Control Plans 1
A Prototype control plan FMEA and Control Plans 2
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 10
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
J Control Plan use on the manufacturing floor FMEA and Control Plans 4
D All Dimensions listed on control plan FMEA and Control Plans 10
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
D Supplied Product on Control Plan - Lot ranging in 40,000 pcs per product FMEA and Control Plans 3
M Is there any pre-defined Control plan format/template acc. VDA? VDA Standards - Germany's Automotive Standards 1
G Control Plan - Include the processes for each sub component? APQP and PPAP 2
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
D Link between FMEA, flow chart and control plan FMEA and Control Plans 10
M Dynamic Control Plan Draft - need review FMEA and Control Plans 2
Ashland78 IATF 16949 Control Plan Authorizations IATF 16949 - Automotive Quality Systems Standard 2
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 6
leftoverture Control Plan - Multiple Process Steps FMEA and Control Plans 8
W Purchased Part Control Plan (IATF 16949) FMEA and Control Plans 7
J VDA audit, control plan - My hair is almost gone now VDA Standards - Germany's Automotive Standards 5
Howard Atkins MSAs are now required on every feature of the control plan - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 13
Jeff Putman EQI Prelaunch Control Plan - Definition Customer and Company Specific Requirements 0
V How to Add Annual Revalidation requirements to Control Plan? FMEA and Control Plans 5
N Control plan references FMEA and Control Plans 6
L Simple Example for PFMEA / Control Plan Training Training - Internal, External, Online and Distance Learning 1
J Functional group / area responsible on a Control Plan IATF 16949 - Automotive Quality Systems Standard 1
T Should Testing be a separate operation in the Control Plan? FMEA and Control Plans 5
