What is a Customer Complaint? (ISO 9001:2015)
Alpine
Hi:bigwave:, I know this will seem like a silly question but here goes. I work for a company that designs, manufactures and then services a product. The product has a warranty period.
Is a customer complaint, any issue that comes in under warranty?
Or can they also be indirect i.e. issues that arise that come via the Technical Service team or the Service Managers?
One of the struggles I have had here is that there are multiple entry points when issues arise, and it makes it difficult to manage from a quality stand point. The quality team do not always get told of problems they just get fixed and it is very ad hoc when we do. Interested in people's thoughts on this.:thanx:
Hi..
You are just mentioning about a gap analysis in your process interactions.
Anything that your customer raises must be analysied if it is a complaint needing a correction / corrective action / or just a response to clear the air.
So it needs a process that will considers inputs (customer issue) from all sources and then the same gets addressed as the case may be and all gets recorded suitably.
Can you drive this process to happen within your organization and then test it (audit) for its suitability and effectiveness....
Alpine
Hi..
What I've been thinking is asking (I) "Is it a design related/technical issue?" or is it a (II) "error originating at the manufacturing plant" with (I) it is a warranty and goes via that process and with (II) it would be a complaint that would go via a different process. We track warranty by failure mode and various design changes and corrective actions occur as a result. With the manufacturing plant originating errors, it is very adhoc, so I'm thinking if we make the two types clear, we can also inject some discipline as to how plant originating errors are documented and also capture the actions that come from them. Does this make sense?
It certainly makes, if it addresses your situation (context) and you are able to train your people and make it work effectively for you. You always have the opportunity to fine tune as you progress..... Good luck
Alpine
Thanks again, I work mostly on my own, and one of the many things I love about this forum is the opportunity to bounce of people. It makes challenges seem that little bit easier.
qualprod
If is under warranty, it seems it is a no conformity.
But first, what you promised to your client? The complaint has to be based on which you offered to your client, additionally, the complaint is a signal of an unsatisfactory service in attentions or bad product .
Have a robust complaint system to manage the complaints, so that they can be treated properly
Sidney Vianna
Post Responsibly
is a customer complaint, any issue that comes in under warranty?
For a customer-centric organization, the issue SHOULD NOT BE if something is a complaint or feedback.
Any organization that has the potential for multiple customer contact streams HAS TO create a culture where customer feedback (positive and negative) is captured and processed, data is captured, aggregated and analyzed.
Over and over again we hear "how difficult" it is for organizations to have customers responding to satisfaction questionnaires. Don't waste any customer feedback. Cherish and seize them.
Alpine
I agree and I action and swiftly everything I here about. My issue is getting the business to understand we need to be consistent and log everything
Sidney Vianna
Post Responsibly
Be careful in adding more responsibilities to other people in the organization, when they are already too busy.
The customer feedback needs to be captured. By whom, is a different story. In my experience, the CRITICAL ASPECT is for whomever has a "touch point" with a customer, to be indoctrinated in the importance of channeling the customer feedback to an appropriate function/department/person.
What I am saying is: maybe the logging of the feedback should not be done by the same person receiving it.
V Difference between Customer Complaint and Service Call as in ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 9
C ISO 10002:2004 - Customer Satisfaction - Customer Complaint Procedure Customer Complaints 18
B IATF 16949 clause 10.2 - requirements following a customer complaint. IATF 16949 - Automotive Quality Systems Standard 9
L Customer Complaint Internal Auditing 3
M Reduce occurrence rating based on the PMS data and customer complaint data ISO 14971 - Medical Device Risk Management 2
J Customer Complaint & SCAR, false data Nonconformance and Corrective Action 14
J Customer Complaint Response 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S How to treat a customer complaint ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
PhilM Nonconformance report, Customer complaint investigations and RMAs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
G Problem Resolution Report Monitoring - Customer complaint or PRR as general motors use Customer Complaints 12
R Does an RMA = a Customer Complaint Customer Complaints 4
G Customer complaint over a Reference Dimension Manufacturing and Related Processes 9
E Is there an Automotive Customer Complaint Index? IATF 16949 - Automotive Quality Systems Standard 3
R In a software development company: Is every bug reported by the customer a complaint? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
E Corrective Action or Customer Complaint ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
T Decontamination responsibility on customer complaint investigation Customer Complaints 4
N Possibly worlds first customer service complaint Supply Chain Security Management Systems 0
M Should Potential Customer Complaint Outcome Define Registrar NC Rating? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J FDA definition of a complaint - Customer orders spare parts 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
P Customer Complaint Definition - Food Distributor Customer Complaints 5
R Customer Complaint - Samples vs. Removal - FDA Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Moncia Customer Complaint Procedure example needed Document Control Systems, Procedures, Forms and Templates 1
C Medical Device Malfunction - Customer Complaint - Response vs. Correction Other US Medical Device Regulations 3
T PPAP - Complaint from a Tier One customer concerning Product Dimension IATF 16949 - Automotive Quality Systems Standard 26
Q Customer Complaint Vs. Nonconformance - CAPA SYSTEM Customer Complaints 4
L Creating a xlsx Customer Complaint file to track Complaints Excel .xls Spreadsheet Templates and Tools 2
N Customer Complaint - Rapid Response Containment Procedure Customer Complaints 4
J Customer Complaint - PPAP - Issues not called out on the print APQP and PPAP 3
R Customer Complaint/Nonconforming Product Inquiry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Can anyone share a Customer Complaint procedure not requiring logging complaints ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Customer Complaint Preventive Action Assistance Preventive Action and Continuous Improvement 3
Q When to issue a Customer Complaint related to efficacy of a Medical Device? ISO 13485:2016 - Medical Device Quality Management Systems 3
S Do I need to initiate a Customer Complaint for Engineering Samples? Customer Complaints 4
A Customer Complaint - Incident Reporting Hardcopy Signoff Customer Complaints 8
B Analysis & Closure of a Customer Complaint Customer Complaints 6
C Customer Feedback, Satisfaction, Complaint Procedure and Measurement Customer Complaints 8
N Closed Customer Complaint Response Form Examples? Customer Complaints 3
J Damaged Parts in Customer Returns - Complaint Investigation? ISO 13485:2016 - Medical Device Quality Management Systems 9
D Is an NCR required in this Customer Complaint scenario? Nonconformance and Corrective Action 6
B Categorization of Customer Complaint: Making Customers feel they are Top Priority Customer Complaints 4
B Understanding the attached sample Pareto Chart for Customer Complaint Quality Tools, Improvement and Analysis 20
J Should I file a Customer Complaint as a Nonconforming Material Report or a CAP? Nonconformance and Corrective Action 5
R Help defining Eyewear Customer Complaint Categories Customer Complaints 5
K Audit NC - No evidence of a full 5 Why Analysis for the Customer Complaint Problem Solving, Root Cause Fault and Failure Analysis 8
somashekar What if a non EU customer makes a complaint to NB ? EU Medical Device Regulations 2
R Everest Customer Complaint System by Lynk Software US Food and Drug Administration (FDA) 1
T Is a Nonconformance Report required for every Customer Complaint? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
J Who should accept the samples of Customer Complaint products ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Data Flow diagram for a Customer Complaint System - Help wanted Customer Complaints 6
B Small Company Customer Complaint System ISO 13485:2016 - Medical Device Quality Management Systems 2
