What is a Process Approach Audit?
Y
yoosuf
Hi Covers,
Could anybody explain about PROCESS APPROACH AUDIT please.
I do not know exactly that I am posting this thread in the correct place.
Yoosuf
Big Jim
Re: PROCESS APPROACH AUDIT
In earlier days of the ISO 9001 program, audits were performed using a checklist that walked through all of the requirements of ISO 9001. This is referred to as an element based audit as it walks through the elements of the standard.
This approach lead to lots of problems. For one thing, some of the requirements are repeated, at least in part, so you audited some topics more than once.
One of the biggest issues, in my opinion, is that it forced companies and auditors to focus on the minutia, becoming overly detailed, and loosing the bigger picture. The analogy I like is that it forced you to look so hard at the leaves that you forgot that the leaves belonged to a tree and that tree was part of a forest.
Process based audits focus on the basic business processes of the company. Exactly what comprises a process varies from one company to another, but a typical set could be Sales, Planning, Design, Purchasing, Production, Quality, and Management Related.
The company identifies what their processes are and describe them in the description of the interaction of processes that is required to be a part of their quality manual.
An auditor determines what the processes are by finding that description (auditors are not permitted to make up their own). An auditor also determines which elements of ISO 9001 apply to each process. The auditor then creates an audit plan that entails auditing those processes. Instead of using a checklist, he uses an audit working document to record what he finds, good and bad.
I hope this explanation helps.
Y
yoosuf
Hi Covers,
Could you please tell me
1. Process approach audit
2. Process approach to auditing
Both are same or different?
Yoosuf
mallen92705
A good example of a process audit would be the audit that you would get from your Registrar auditor.
An example of how do perform a process audit on your own would be to take a finished invoice and audit backwards through the processes that went into getting the final product made and invoiced. (I believe this is refered to as a Reverse Audit)
The approach deals less with all the individual steps required per the procedure or work instruction, and more on the end result.
Hope these examples help to shed some light on the topic!
somashekar
Hi Covers,
Yoosuf
Try to get answers to these in every process area you audit ...
1. Where do you get the products and information for your activity from and why ?
2. Where do you give the products and information after your activity to and why ?
When the answers begin to show you good and logical linkages and use of the product and information is evidenced, you will know a good network of process interaction is effectively happening. During this you will also quickly know of any breaks in the links (and any not made links) and its lack of effectiveness thereoff in the process interactions. You will also see some duplication and non value added activities that can be cleaned up as a part of actions based on audit results. These answers will also make your audit task easy at other linked processes as you know what to enquire and look for there. If you are not the person auditing those processes, you can share your audit results with the other auditor who visit those processes.
So essentially in a process approach audit, the auditors internal discussions at several times also is an essential element.
P System Audit Approach - Application of VDA 6.3 - Process Auditing VDA Standards - Germany's Automotive Standards 2
A Can the Process Approach be used to audit Management Commitment and how? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
U Process based Audit Approach vs. Clause based Audit Approach Process Audits and Layered Process Audits 49
B Process Approach Audit Plan - What a Process Approach Audit Plan Looks Like Internal Auditing 19
T QSE basics and QMS process audit approach - What are the QSE basics? IATF 16949 - Automotive Quality Systems Standard 3
M Document Review Audit Findings - Design and Process Approach Design and Development of Products and Processes 2
R How to use the process approach to audit IMS General Auditing Discussions 6
J Internal Audit format - Idea of the process approach to the audit Internal Auditing 16
qualprod Shortening processes complying with process approach ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
tony s What is the automotive process approach for auditing? IATF 16949 - Automotive Quality Systems Standard 2
M APQC PCF (Process Classification Framework) and ISO 9001 - Processes Based Approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Does Japan accept the Bracketing Approach for Process Validation Japan Medical Device Regulations 1
A How do we implement a Process Approach ISO 13485:2016 - Existing GMP QMS Other ISO and International Standards and European Regulations 2
B How do you approach the "Safe Launch" Process APQP and PPAP 17
M Process Approach: Types & number of processes required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
WCHorn Quality Digest article on the Process Approach to ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W Help explaining the need for the Process Approach AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q Introducing Process based approach on Production Floor Manufacturing and Related Processes 6
K How Can I Implement the Process Approach in AS9100C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
G The future of the Process Approach to Auditing General Auditing Discussions 10
Q Process Approach & Continual Improvement Clauses and Evidence of its Effective Use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M PFMEA (Process FMEA) - What is the best approach? FMEA and Control Plans 14
Q Process or Departments - Document Content and Managing the Process Approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
I Process Approach Litmus Test - Procedure Titles ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
B Process Approach - Convert System of Documentation into System of Managed Processes Misc. Quality Assurance and Business Systems Related Topics 2
L Consultant not following Process Approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 34
J Why Process Approach? Why not Process Method? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Process Approach to Auditing Quality Management System Internal Auditing 12
Q ISO 13485, ISO 9001 QMS and FDA Requirements - Process vs. Compliance Approach? ISO 13485:2016 - Medical Device Quality Management Systems 4
Q Process Approach - Special Focus? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Marc Process Approach Challenge - Please Define what the 'Process Approach' is Misc. Quality Assurance and Business Systems Related Topics 48
I Poll: Should auditors promote the process approach? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 331
Howard Atkins Process Approach Requirement for Internal Audits in TS 16949 IATF 16949 - Automotive Quality Systems Standard 46
A Process approach to auditing ISO 9001:1994 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A A macro-process structure approach to auditing for ISO 9001:2000(8) General Auditing Discussions 19
K FMEA is the Best C.I approach for process improvement? Preventive Action and Continuous Improvement 3
A Systematic history of process approach Philosophy, Gurus, Innovation and Evolution 5
P Process Approach - Implementing ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 11
apestate Is the Process Approach optional? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Calculating Cpk for Tubing Wall Thickness - Extrusion Process - How to approach? Statistical Analysis Tools, Techniques and SPC 16
A Process Approach to Auditing Undocumented Processes at the System Level Internal Auditing 7
W What is meant by Process Approach Auditing and What questions should be asked? Process Audits and Layered Process Audits 11
Anerol C Process Approach Training Material ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
W Process approach - Auditor issued OFI (opportunity for improvement) on clause 8.2.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
O Training on ISO9001 Process Approach Training - Internal, External, Online and Distance Learning 13
P What is the Process Approach in Payroll? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Implementing the Process Based Approach - Reality check needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
H Process Approach - Apply it into the system procedure Document Control Systems, Procedures, Forms and Templates 0
M Supply and Delivery - How should I approach the work for a specific process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Process approach based internal auditing Internal Auditing 1
