What is a reasonable Bioburden limit?
s.parakos
Our Sterilization validation report (gamma irradiation at 25kGy) contains the average bioburden on the samples tested, upon which the dose was set.
During regular bioburden monitoring the level obviously fluctuates. I was wondering if there is a rule of thumb which says what range is acceptable and at what level an investigation into the bioburden/dose setting should be triggered?
eg If 10 x the average bioburben is measured during monitoring an investigation is required.
thanks
Simon
Ajit Basrur
Did you have a look at ISO 11737-3 - Sterilization of Medical Devices - Microbiological methods, Part 3 - Guidance on evaluation and Interpretation of Bioburden Data ?
I dont have this standard but feel you could get some valuable info from this standard.
Also have a look at Bioburden Testing that I found very interesting.
chris1price
Hi
I'm not aware of any specific guidelines, other than average bioburden being below 1000cfu when using VDmax25. Bioburden will be a factor of the nature of the product and the process complexity.
I have always taken this to be a case for doing SPC and using Xbar/R charts to set limits and to look for process changes.
Chris
Ajit Basrur
Hi
Chris
Thats true Chris - even I have seen "average below 1000 cfu"
Q
Quality Priest
Hi
Chris
Agree SPC is the way forward for setting your limits, some of our devices have upper limits of 25cfu where as others are around the 400cfu mark before prompting an investigation / root cause analysis etc.
I generally review each devices limits on an annual basis to see if we can lower the upper limits general rule for us is Average +3 standard deviations :2cents:
brandomenon
I believe you still have to perform dose audits on a regular basis (quarterly or semi-annually depending on rational developed by your company). If you are getting acceptable results this helps to prove that the fluctuations are not negatively impacting the product.
I would also suggest looking into additional testing for worst case scenario. If you have characterized the bioburden (what kind of bugs do you have?), you should determine an upper limit of bioburden, and then repeat verification dose level processing on products that have been innoculated with the 'worst case' level of bioburden.
In doing this, if you get good results, you have the proof, as long as bioburden stays under 'worst case scenario' that your product is sterile.
If you use a contract irradiator, they should have validation experts who should be happy to let you pick their brain...
Richard88
Hi, I'm new to this site and could not identify a newer thread nor figure out how to create a new one so here goes....
The info here is quite old and the standard listed is no longer available, its been discontinued howerver ISO 11737-1 is its replacement, so I'm lead to believe.
My question for everyone is a sanity check. In order to set a bioburden control limit can one use their validation bioburden level first then move to some other means once data becomes availble through more bioburden testing? What does everyone think the best way to get your ultimate mean?
Doug Tropf
ISO 11737-1:2006 specifies the requirements to be met in the determination of bioburden.
K
Kees Fremery
thanks
Simon
There are two different items to consider. The Periodic Dose audit for which the criterium is for failing or passing: the verification experiment. Next to that you have the Bioburden testing which should be seen as a monitoring. Increase in Bioburden and passing the Dose Audit: congratulations, but make an analysis of the cause. Increase of Bioburden is a warning which shoulde be considered seriously. Exceeding 1000 cfu: perform a new Dose Audit on the next batch immediately.
For any experience assistance in this, feel free to contact me.
I have many years experience in Gamma sterilisation validation and Microbiological testing according to ISO 11137.
G Trying to get a financially reasonable ISO Certification Body Registrars and Notified Bodies 7
M What is a reasonable MDSAP cost? ISO 13485:2016 - Medical Device Quality Management Systems 9
S Scheduling a Crisis Management Audit? Reasonable Request? Internal Auditing 2
D What is a reasonable consulting fee for preparation of a complete traditional 510k? Consultants and Consulting 11
C What is a reasonable level of QA Editorial Control? Quality Manager and Management Related Issues 20
5 Reasonable GRR result for a 0-1" micrometer with a total tolerance of .002" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
A CAPA - Reasonable Timeframes for Effectiveness Evaluation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
N What is a ?Reasonable? failure rate for an electronic device in the 1st year? Quality Tools, Improvement and Analysis 7
S Packaging Specification template and Reasonable dppm target for printed material? Document Control Systems, Procedures, Forms and Templates 1
F Travel Expenses for Assessors - Registrar states we pay "reasonable travel expenses" Registrars and Notified Bodies 27
Hershal Cutoff - Discussion regarding a reasonable break-even point for calibration General Measurement Device and Calibration Topics 3
G Reasonable time for ISO 9001:2000 implementation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Icy Mountain Reasonable calibration? 50 foot measuring tape and other basic M&TE General Measurement Device and Calibration Topics 25
M Six Sigma - Where to get a 'reasonable' certification? Training - Internal, External, Online and Distance Learning 3
D What is a reasonable time frame for a system to be 'mature enough' to audit? Miscellaneous Environmental Standards and EMS Related Discussions 11
F Definition Reasonable - Defining a Reasonable Amount of Time Close Out CPAR's Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
M Bioburden Frequency (sterile MD) Other Medical Device Related Standards 2
K When is Bioburden Testing Required? Other Medical Device Related Standards 4
A ISO 11135:2014, B.1.4, BI resistance x product bioburden ISO 13485:2016 - Medical Device Quality Management Systems 6
D Sterility and BioBurden Testing for Plastics ISO 13485:2016 - Medical Device Quality Management Systems 5
B Bioburden monitoring for surgical instrument provided non-sterile EU Medical Device Regulations 3
C Sterility and Bioburden Testing - LAL passed under 0.5EU/mL Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
B Radiation Sterilization Dose Audit: Bioburden frequency Other Medical Device Related Standards 1
F Bioburden Testing requirements for Non-Sterile Dental Products EU Medical Device Regulations 6
V Cleanliness/Bioburden for Non-Sterile Gas Path Medical Devices Other Medical Device Regulations World-Wide 7
K Bioburden 0 cfu for Dose Setting using the VDmax25 Other Medical Device Related Standards 9
N Must Bioburden Sampling Procedures be Documented? Other Medical Device Related Standards 5
R Simulated product for bioburden testing Other ISO and International Standards and European Regulations 2
C What is the most appropriate Bioburden Test Method for Surgical Gloves ISO 13485:2016 - Medical Device Quality Management Systems 10
M Bioburden numbers and ECA gloves 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
M Bioburden testing for Class 10000 (Grade C) clean room ISO 13485:2016 - Medical Device Quality Management Systems 1
O Bioburden Testing - Non Sterile Product / Tapes - ISO 11737-1 Other ISO and International Standards and European Regulations 9
P Serial Testing of Bioburden for Medical Devices Other Medical Device Related Standards 2
M Biological Monitoring Program Environmental Bioburden Test Method Needed ISO 13485:2016 - Medical Device Quality Management Systems 1
C What is an acceptable bioburden level or count when working in cleanroom ISO class7 ISO 13485:2016 - Medical Device Quality Management Systems 1
P Frequency of Bioburden Testing EU Medical Device Regulations 3
B BioBurden and EndoToxin Questions Other Medical Device Related Standards 6
M Sterility Testing vs Bioburden Testing - Differences Qualification and Validation (including 21 CFR Part 11) 7
S Bioburden Monitoring Sample Size Increase ISO 13485:2016 - Medical Device Quality Management Systems 4
I Bioburden and Endotoxin (LAL) Testing proposal help 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
I Bioburden Count Question - Bioburden is above the alert limit >1 CFU/component avg. 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
J Bioburden Monitoring - 'Off the Shelf' Bioburden/Microbiological Monitoring Software ISO 13485:2016 - Medical Device Quality Management Systems 4
L GB15980-2003 Bioburden Count Trend on Operator Hands Other ISO and International Standards and European Regulations 1
0 Guideline/Method for Raw Material Roll Stock Bioburden Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q Bioburden Requirements on Device used on Unbroken Skin Other Medical Device and Orthopedic Related Topics 4
A Microbial Limit (Bioburden)on dry nonwoven that used for making Hand sanitizing wipes ISO 13485:2016 - Medical Device Quality Management Systems 1
D Bioburden and Product Labels - VD Max studies on all the BOMs Other Medical Device and Orthopedic Related Topics 9
H Determining a New Product Bioburden Limit ISO 13485:2016 - Medical Device Quality Management Systems 11
L Validation of transfer materials - Bioburden of items from lab into cleanroom Other Medical Device and Orthopedic Related Topics 2
L Monitoring bioburden on clean room gloves Other Medical Device and Orthopedic Related Topics 1
