What is Average Run Length & Average Production Length when used in Control Charts?
tahashamim
As I am trying to understand Average Run Length, Average Production Length term came in a book and did not give any details. Does any one have detail material or even an introductory level information on it besides a definition?
Thanks in advance,
Taha.
W
wmarhel
Re: Average Production Length
Thanks in advance,
Taha.
Without knowing the book, or the context in which the term was used makes it a little tough. I would look at "Average Run Length" as being a function of time: minutes, hours, days, etc. This would then be the average amount of time that a particular part is in production. If you always started a part on a Monday and ended on a Friday, then your average run length would be five days.
This term could also apply to a process type of product such as wire or steel coils. For this example if you had production runs of 100ft., 200ft and 300ft.; your average run length would 200ft. So context is critical.
Wayne
harry
I am having the same question marks as Wayne above. The context is very important. Are you asking this question in the same 'context' as the other question you asked in another thread:
2- Is the average run length performance of a control chart a more meaningful measure of performance than the type I and type II error probabilities? What information does ARL convey that the statistical error probabilities do not?
tahashamim
Sorry for the confusion. Yes, Average Production Length and Average Run Length - both in the context in using control charts.
So as they say ARL = 1/p = for a process in which mean has not shifted, ARL = 370 sample - a false alarm may come after the 370th sample.
They the author mentioned that ARL is not so good as this has a wide standard deviation and one should use Average Production Length. Interestingly, the author said APL will also have wide standard deviation as it is linked with ARL...
So I thought regardless of APL link with ARL, it has a good information because it can give us number of units produced potentially that has mean shifted... Hence I was looking for more details on APL such as its formula and its application if possible.
If it is still not clear, I can scan a page in which author mentioned it hoping this is not against copy right.
thanks,
taha
Steve Prevette
Deming Disciple
Re: What is Average Run Length & Average Production Length when used in Control Chart
See my response in your question about Operating Characteristics curves.
M Average Run Length (Student Question) Statistical Analysis Tools, Techniques and SPC 3
B How many nonconformances have you received on average during IATF audits? General Auditing Discussions 24
L Uncertainty calculation for an average Measurement Uncertainty (MU) 1
qualprod Best approach to get a real value as average? Statistical Analysis Tools, Techniques and SPC 6
M What is the average time needed for process documentation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Average and standard deviation of Cumulative Data Statistical Analysis Tools, Techniques and SPC 5
F Calibration certificate content - Average Value and True Value ISO 17025 related Discussions 6
P Average access height into an industrial machine (average base plate height) Human Factors and Ergonomics in Engineering 2
P Average Peel Strength - Interpretation of BS EN 868-5:2018 and ASTM F0088/F0088M Other Medical Device Related Standards 2
qualprod Cycle times, value stream mapping, inventory, average values? Lean in Manufacturing and Service Industries 1
Proud Liberal How long does your company take to close an 8D on average? Problem Solving, Root Cause Fault and Failure Analysis 12
L How to interpret the average R bar Value shown in the R Chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
J0anne GCC Submissions - Average review time for SGH qualification files Other Medical Device Regulations World-Wide 11
K Average height of adults by sex by state Other Medical Device and Orthopedic Related Topics 10
M What is the difference between X Bar - R Charts and Average Chart? Statistical Analysis Tools, Techniques and SPC 7
F Statistical Comparison of Product: High Average vs. Low Range Capability, Accuracy and Stability - Processes, Machines, etc. 13
G Improve final GR&R value by taking average of more measurements? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
K Can I do an average measurement values for a sample? Statistical Analysis Tools, Techniques and SPC 1
M MSA 4 - Results of GR&R Study using Range & Average Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T Counting the Average Times of Alarms in a Process using Minitab Using Minitab Software 5
Q How to determine the average baseline for the following data in SPC Quality Tools, Improvement and Analysis 3
D Rounding Numbers - Adding numbers in Excel - I want the average Excel .xls Spreadsheet Templates and Tools 3
T Bias & Linearity Study - How to calculate the P value for the Average Bias Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
G Product Returns are above average for Labeling Problems Quality Manager and Management Related Issues 4
R GR&R (Gage R&R) - Average Range Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B XbarR or EMWA (Expontionally Weighted Moving Average) or MA Chart - Which to Use Statistical Analysis Tools, Techniques and SPC 6
R What is the Sigma Level of the Average Company? Six Sigma 11
Stijloor Toyota drags down new-vehicle quality average World News 9
P ISO 27001 Controls - Industry average % IEC 27001 - Information Security Management Systems (ISMS) 3
Stijloor The ARMA (Autoregressive Moving Average) Chart Statistical Analysis Tools, Techniques and SPC 6
D Influence of the Coverage Factor - Worksheets based on the Average and Range Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B To IMR or Moving Average chart now that's the question! Statistical Analysis Tools, Techniques and SPC 11
M Inferences from Distribution? (Average per hour/the average pay of the staff) Six Sigma 2
O Average Life Cycle Duration for a large number of medical equipment types Other Medical Device and Orthopedic Related Topics 2
Randy US Average Hourly Employee Cost Career and Occupation Discussions 3
K Calculating Control Limits in Average and Range Charts Statistical Analysis Tools, Techniques and SPC 3
C What does the average employee need to know about the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
B Control Chart - Minimum point & average insulation thickness for Automotive Wires Statistical Analysis Tools, Techniques and SPC 9
DanteCaspian 5S Workplace Average for those that score 5 S Lean in Manufacturing and Service Industries 5
T Monitoring a shift of the average in an SPC chart Statistical Analysis Tools, Techniques and SPC 11
C Is Parts/Process Average Testing SPC by Another Name? Statistical Analysis Tools, Techniques and SPC 3
D Average fill label - "e" Mark, probably a UK specific requirement. Manufacturing and Related Processes 8
D Queuing System - Calculating Average Arrival Rate λ Statistical Analysis Tools, Techniques and SPC 3
W Advice on the best way to approach a double moving average using Minitab 15 Using Minitab Software 3
K Average Salary for Quality Personnel? Career and Occupation Discussions 12
E Moving Range Average Calculation in Excel (in a single cell only). Excel .xls Spreadsheet Templates and Tools 9
S Average Cost of ISO 13485 Registration in US ISO 13485:2016 - Medical Device Quality Management Systems 10
D How to Measure a Diameter - Average or Maximum/Minimum? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 25
D When to Create a New Baseline Average for a Process Statistical Analysis Tools, Techniques and SPC 2
