What is Cc? Capability Study on Key Critical Dimensions
stevoc
Hi
Can anyone help please - I've been preparing some specification sheets for manufacture of parts for a medical device. On this are listed the requirements for in-process and outgoing controls and includes a capability study on key critical dimensions (Cpk>1.33). The client has reviewed these and asked that we also add a requirement that Cc<0.25.
Problem is that neither I or anyone else here knows what Cc is. I can find no mention in the Six Sigma Handbook and google hasn't returned anything.
Can anyone enlighten me please?
many thanks
Steve
Darius
Thanks Atul, so CC >> like Taguchi's loss function; to the target, the less variation of the mean against the target the better.
stevoc
Thanks for that - I'd managed to find that reference as well. I also found this definition:
"Cc is a capability index comparing the process average with the target and specification limits to assess the centring of the process. A value of 0.25 means the average is in the middle quarter of the spec. A value of 0.50 means the average is in the middle half of the spec. Unlike Cp and Cpk, smaller values of Cc are better. Ideally a Cc of 0.25 should be obtained. This in combination with a Cp of 2 results in Six Sigma Quality.
Cc can only be calculated in the event of two specification limits and target. Cc does not consider the process variation. Variation is evaluated using Cp and Cpk."
Also, the formula shown on that web page is incorrect - the denominator for the second half should be USL-target, not USL only.
There's also another formula:
Cc = 1.0 - (Cpk/Cp)
Having looked at our IPC data, I'm slightly alarmed that whereas before we achieved our quality targets (Cpk >= 1.33) by some way (generally Cpk is > 3.0) we now fail on the Cc requirement (Cc < 0.25)
Atul Khandekar
I was wondering if this is meant to be used for processes with asymmetric tolerances: Target not at the midpoint of specs ??
Darius
Just playing with the equations...
:nono:, agree that the manual say so, but it's "Ideally Cc < 0.25" (sort of sigma shift). As I say before to the target, the closer to Zero the best.
It should work, but insteed of the mean, it should use Median. The question is, what happen when the Target is the spec limit? (the equation goes to infinitum = 1/0):bonk::lol:
bobdoering
Stop X-bar/R Madness!!
One caveat - customers place capability requirements on print without knowing the underlying process. Cpk - and sometimes Cp - are not always applicable. If not, how you calculate this may be affected. Beware of the rubber stamp!
stevoc
Tell me about it!
We've been developing a series of medical devices for a pharma client. Until recently they've been unable to supply any quality related information and have said it's for us to determine - so we've been applying Cpk >= 1.33 to all critical to qaulity dimensions (in line with similar devices). We've actually been achieving 6 sigma in most instances (Cpk > 1.5, Cp > 2.0).
Now they've brought in quality people to fill the hole in their organisation, who have specified the Cc < 0.25 requirement. They can't give us any justification for it's use and it seems to be based on what they used in their previous employment.
The end result is that over 50% of our controlling dimensions now fail this requirement and removing/modifying from the specification is not proving easy!
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
S Machine Setup for a CNC Machine Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
G Capability Study for Tapped Hole Reliability Analysis - Predictions, Testing and Standards 3
G Plotting capability study data - I have a bimodular data distribution Capability, Accuracy and Stability - Processes, Machines, etc. 4
V Generic requirements regarding capability study in automotive Capability, Accuracy and Stability - Processes, Machines, etc. 1
O Capability or Gage R&R Study for Leak Tester Reliability Analysis - Predictions, Testing and Standards 11
M IATF 16949 - Capability study on non critical dimensions? Statistical Analysis Tools, Techniques and SPC 4
L Excel Template for Cgk Study wanted (Capability Gauges Study) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
N Process Capability Study - Aggregate vs. Individual Processes Statistical Analysis Tools, Techniques and SPC 24
KyloDen Capability Study and Qualifying a Supplier Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Capability Study => Check %Study Variance and NDC? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B Conflict between department of MSA and Capability Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J How to determine a Capability Study for Low-Volume Suppliers Capability, Accuracy and Stability - Processes, Machines, etc. 3
L Capability Study for a Honing Machine Statistical Analysis Tools, Techniques and SPC 3
A Inspection Capability Study (Kappa Analysis / Attribute R&R) as Certification Req't Training - Internal, External, Online and Distance Learning 7
C Subgroup Size in Minitab for Capability Study Statistical Analysis Tools, Techniques and SPC 4
O One Cavity Mold Prototype Capability Study and PPAP Approval APQP and PPAP 1
G How to calculate Subgroup Size for Machine Capability Study Statistical Analysis Tools, Techniques and SPC 4
V How to calculate Machine Capability Study using Minitab Using Minitab Software 4
V JCI standard numbers of pieces required for Capability Study? APQP and PPAP 2
T Industry Standards for # of parts for Capability Study and Layout FAI's? APQP and PPAP 4
D AIAG 4th Edition Capability Study and Gage R&R Requirements Document Control Systems, Procedures, Forms and Templates 8
P Capability Study for a Specific Thickness of Rubber Sheeting Capability, Accuracy and Stability - Processes, Machines, etc. 6
Q When to use Cpk or Ppk for a Process Capability Study? Capability, Accuracy and Stability - Processes, Machines, etc. 14
O Capability Study on Continual Arbitrary Dimension Capability, Accuracy and Stability - Processes, Machines, etc. 11
J Attribute Data and Capability Study of Holes in Parts Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Process Capability Study which involves MMC (Maximum Material Condition) Capability, Accuracy and Stability - Processes, Machines, etc. 8
A Yearly MSA (Measurement System Analysis) & Capability Study - TS 16949 Requirements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Process Capability - Interview Case Study Capability, Accuracy and Stability - Processes, Machines, etc. 1
A Process Capability Study using Variables Data (weight of the product) Statistical Analysis Tools, Techniques and SPC 9
M Capability Study on a New Machining Process - Issues Capability, Accuracy and Stability - Processes, Machines, etc. 40
S Does anyone know what is involved in a HiPot capability study? Capability, Accuracy and Stability - Processes, Machines, etc. 2
A Process Capability study of CNC Machining Process Capability, Accuracy and Stability - Processes, Machines, etc. 3
Q Machine Capability Study - Cpk (Cmk) of an R/F testing machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B MSA (Gage R&R) vs. Capability Cpk Study - Helium Leak Check Station Statistical Analysis Tools, Techniques and SPC 2
T Machine GR&R (Gage R&R) - Capability Study Capability, Accuracy and Stability - Processes, Machines, etc. 5
M Cmk (Machine Capability) - Case study Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Visual Inspection - Capability Study on Attribute Data Capability, Accuracy and Stability - Processes, Machines, etc. 13
M Capability Study on Extruded Alumin(i)um - How would one define a "batch"? Capability, Accuracy and Stability - Processes, Machines, etc. 4
A Capability Study Template Capability, Accuracy and Stability - Processes, Machines, etc. 1
C Capability Study Required as a Condition to Adopt a Sampling Plan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
S Process Capability Study for Electrostatic Powder Coating Statistical Analysis Tools, Techniques and SPC 6
J Process Capability Sheet for a short term 30 piece study needed Statistical Analysis Tools, Techniques and SPC 1
B Capability Study for Radii of laser cut pockets - 0.030" radius Capability, Accuracy and Stability - Processes, Machines, etc. 15
V Machine short term capability study with Cmk index in automotive industry Capability, Accuracy and Stability - Processes, Machines, etc. 3
A How do you identify your heat treat capability study samples? Capability, Accuracy and Stability - Processes, Machines, etc. 3
E Capability study on true position callout. What would be the upper and lower spec? Statistical Analysis Tools, Techniques and SPC 7
K Format for presenting capability study results? Statistical Analysis Tools, Techniques and SPC 7
