What is considered a "core algorithm"? (From an FDA guidance document)
SSchoepel
The FDA guidance document on when to submit a software change include this definition:
“Core algorithm” changes are modifications made to an algorithm that directly impact or contribute to the device’s intended use. Examples include: alarm algorithms on a monitor, a motor control algorithm for an infusion pump, and a detection module and measurement engine algorithm for an IVD.
Internally there is some back and forth on what constitutes an algorithm in the product. So I'm coming here for regulatory opinion.
Our device is a PACS (picture archiving and communications system) that is use by radiology for displaying scans to look for lesions suspicious of cancer, segment those lesions (draw the contours of it in 2D and display and calculate information about it as a 3D object), and provide data used for diagnoses and treatment. The radiologist draws what is thought to be the longest axis of the lesion and our device finds the contours and builds the 3D structure of the lesion across the scan "slices." Some people refer to the code that finds the extent of the lesion in 2D and 3D as our algorithm. Sometimes it's even referred to as our core algorithm (but without knowledge of the definition above).
Our intended use statement includes this sentence: The product automatically and semi-automatically segments normal structures and abnormal structures (for example, nodules and lesions), and provides metrics for the structures. (And in our last submission we defined the code/algorithm that does this activity.)
Others look at the FDA definition and say that's only for "black box" type of code like artificial intelligence software (both static AI and AI that modulates based on input).
Does anyone have experience internally or with the FDA when they have defined what they consider to be a core algorithm?
yodon
Presume you're referring to the guidance for Deciding When to Submit a 510(k) for a Software Change to an Existing Device?
I don't believe that guidance is limited to AI / machine learning by any means (see the Discussion Paper for current thinking on that topic). The example cited for core algorithm change clearly indicates it's for any software application:
pziemlewicz
In short, if you were to change the way your system created 3D from 2D, that would be a change to your core algorithm. There may be others.
I've done work with CT scanners and may be able to provide additional insight if you want to PM a specific question.
SSchoepel
Yes, that's the one I'm referencing. And thank you, I did not think it was limited to the AI/machine learning parts of a product.
I'm fairly certain the guidance document came out a few years before the discussion paper. Do you have any idea the date of release of the discussion paper? It's not listed.
yodon
I think the discussion paper was pretty recent. The page with the link above says the content is current as of 1/28/2020 - that may well have been when it was posted.
GStough Objective Evidence - Are Interviews Still Considered as Objective Evidence? General Auditing Discussions 15
B A.I. diagnostic software is considered as medical device in FDA? US Food and Drug Administration (FDA) 6
Y Software updates considered servicing (7.5.4) ISO 13485:2016 - Medical Device Quality Management Systems 4
D CB and customer audits considered as internal audits? General Auditing Discussions 9
U NOC - What is considered a "design change" EU Medical Device Regulations 5
D CE Marked product considered a Drug in India Other Medical Device Regulations World-Wide 0
J Are DAM tools, Mobile application, clinical dashboard, etc. considered accessories to medical device or supportive functions? Manufacturing and Related Processes 4
S Is any dissatisfaction over a Medical Device considered as a complaint? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
I Is highlighting on a printed document considered a change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Are mortuary/autopsy tables considered to be medical devices EU Medical Device Regulations 7
K AS9100D Clause 7.5.2.a) - What is considered to be "documented information"? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
V Which batches should or could be considered for design validation and design verification? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
M Professional Use Medical Software French Labeling for Canada -- Not Considered Medical Device Canada Medical Device Regulations 2
S Tools and equipment provided by customer - Considered as external provider? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S What is considered the complete software medical device? Medical Information Technology, Medical Software and Health Informatics 6
D Risk Register - have we considered enough and is the format acceptable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E Are EEG electrodes considered as one applied part? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Can a Attribute Study be considered a Visual Inspection? Reliability Analysis - Predictions, Testing and Standards 6
M What is considered an "Audit Day" for OASIS AEA application? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
K What can be considered a "Post Delivery Activity" (ISO 9001:2015 Clause 8.5) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
C What is considered a "Critical" Raw Material? (Re: DNA Synthesis) Misc. Quality Assurance and Business Systems Related Topics 3
F Is Training Material Considered Labeling - FDA 21 CFR 801 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
C DFAR 252.225-7008 - Is aluminum, say T6061, considered specialty metal (i) steel? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
I What are considered next generation ITSM tools? IT (Information Technology) Service Management 1
J Can a Surge test fail to a test level and still considered as Compliant? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Y Which version of ISO 13485 would be considered for MDSAP certificate? Canada Medical Device Regulations 8
L AIs the R&R study a training evidence considered ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C When is a device considered "sold to the general public?" Canada Medical Device Regulations 2
M Is Pain considered Harm in ISO 14971? ISO 14971 - Medical Device Risk Management 11
F Can be several measurement in a repl considered as nested factor in Minitab analysis Using Minitab Software 14
J Can some measurements be considered information only and not need calibration? General Measurement Device and Calibration Topics 7
M Is a computer used in hospitals considered a medical device? ISO 13485:2016 - Medical Device Quality Management Systems 17
S Are Polyethylene-folie gloves considered Medical Device ? EU Medical Device Regulations 4
T Has anyone considered what logic is? Coffee Break and Water Cooler Discussions 23
D Identification and Traceability 7.5.3 - What is considered Traceable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J Is Metals Analysis of Water Samples considered "sampling"? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
J Is painting considered a Special Process as defined by ISO 9001 7.5.2? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
E Extent of modification to be considered as Modified Adoption Other ISO and International Standards and European Regulations 1
R How much Protective Current Rating of Building Branch Circuit should be considered? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
O Is this considered Design and Development in ISO9001? Mushroom Farming ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V What are Basic Dimensions about and why are they considered basic? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Outsourcing Records Storage - Compliance Aspects to be considered during Audits Document Control Systems, Procedures, Forms and Templates 7
R Is foreseeable misuse considered as single fault condition? IEC 60601 - Medical Electrical Equipment Safety Standards Series 33
I Are KPIs (Key Performance Indicators) considered as Quality Objectives? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R Should Nurse Call Systems be considered as ME Equipment or System? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
sagai New Draft Guidance from FDA - Factors considered for Risk/Benefit Determination Other US Medical Device Regulations 4
sagai What is CD writing considered as - for Device-Only SW? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B Is Ship Test considered Design Verification or Design Validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
