What is considered the complete software medical device?
SSchoepel
Curious what different companies consider the final medical device for SaMD.
For medical software that runs in a client-server environment there is a client executable that runs in Windows and is given to the customer as the executable. The server software is a set of .war files (java executables). These executable files are designed and tested to run against recommended (free) server OS-level software that are defined in the manual (like Apache Tomcat).
As a convenience for install, Customer support creates a server image file with the medical device .war files and the free server software. Just installing the free supporting software would not allow the device to run and while recommended, that free software is not the only OS-level software that could run the .war files. The free software recommended and put into the server image file is not modified in any way from it's released version by those manufacturers.
Customer Support performs the installation and configuration which may or may not include set up of the free OS-level software that was not created or modified. Customers may have a server with all the software (except for the .war files) already.
Which would be considered the actual medical device on the server side (or is there another scenario):
1. the .war files that contain the things we designed and released for use with the client
2. the server image with the .war files and the free software OS-level files
Is there a guidance document from any source on this?
Thank you
yodon
Well rats... my brilliant initial response got lost in a vBulletin error (oddly, that seems interestingly appropriate). Trying again...
I do think this is an interesting question so thanks for posting and I'm hoping it will trigger a robust discussion. And I'll start.
My take would be that the scope of the SaMD system would exclude Apache Tomcat. Similar argument for not considering Windows a part of the client side application. Similar argument for not considering the browser a part of a web-based application.
That said, I would take plenty of precautions (proportionate to the risk associated with the system failing). If the risk is rather substantial and the Tomcat software could contribute to failure, I would consider limiting execution to a specific version / configuration; i.e., not allowing just any old Tomcat version / configuration. I would have pretty specific requirements for version and configuration. Regardless, I'd probably do a level of testing under any version that you want to claim the system can be used with. (Similar to checking out the client side application under a variety of Windows versions). I would also address this in my Risk File (probably looking a bit more closely at configuration options). Finally, I would suggest that a monitoring program (similar to what you would do for SOUP) be established to check out new releases of Tomcat and do testing to ensure compatibility.
SSchoepel
Thank you for the quick response. That's what I was hoping to hear and leaning toward but want to make sure that there isn't some assumption or guidance that the product is more than the actual set of files that contain the product features.
We do most of what you mentioned, so I'll be checking what we need to do to show it is fully considered and recorded.
I hadn't thought of monitoring the performance/status/configuration issues with just those free items themselves, only when there was some relation to how our product is running. I will have to ponder that with customer support.
BhupinderSinghPawa
For the client side, the Software System would constitute of the client executable and underlying Windows OS. The Windows OS to be treated as SOUP. The upgrades, patches and obsolescence of SOUP to be implemented. The Risk Management to consider failure or unexpected results from SOUP and the outstanding defects of SOUP. This is with EN 62304 compliance required for EU MDD. The software safety classification of the SOUP item to be done.
Similarly, for the server side SaMD, the software system by same principles consists of the server software (.war), Apache Tomcat server and the underlying OS (whether windows / Linux / Unix variants). The Apache and OS will be SOUP and to be addressed by SOUP requirements if you are following 62304.
Network security and access control also should be addressed.
yodon
Hmm... I would disagree with treating the OS as SOUP. Certainly, and to an extent commensurate with the risk of the software (failing), risks with the OS and known issues could be considered. But how would you, for example, specify functional and performance requirements of the OS? I also don't see it very practical to analyze changes to the OS. I think you'd be endlessly chasing your tail trying to do so.
If you do go down that rabbit hole, where do you stop? Are all the device drivers also SOUP? All the services running?
We've never called out the OS as SOUP and have never gotten any push-back. Our approach is to identify (and test against) specific OS versions (including patch levels sometimes). Depending on the safety classification, we may tighten the controls regarding which OSs the software can run under.
For SOUP, we pretty much draw the line at whatever is included in the binaries of the application; i.e., whatever we install. This typically always includes the libraries provided by the compiler / development tools.
SSchoepel
I would have to agree with Yodon that you would end up considering everything on any possible user's computer in risk and as SOUP. For products that are software-only it would be impossible to test against every configuration possible in an OS and every combination of drivers or third-party applications.
Considering the implications of the SaMD not working with the OS features on which the SaMD depends seems appropriate and has been considered and, of course, testing against the OSs/versions of OSs that the SaMD is supposed to run against.
The delineation of drawing the line at what is included within the binaries of the SaMD seems appropriate.
S What is considered a "core algorithm"? (From an FDA guidance document) Medical Information Technology, Medical Software and Health Informatics 4
D CE Marked product considered a Drug in India Other Medical Device Regulations World-Wide 0
J Are DAM tools, Mobile application, clinical dashboard, etc. considered accessories to medical device or supportive functions? Manufacturing and Related Processes 4
S Is any dissatisfaction over a Medical Device considered as a complaint? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
I Is highlighting on a printed document considered a change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Are mortuary/autopsy tables considered to be medical devices EU Medical Device Regulations 7
K AS9100D Clause 7.5.2.a) - What is considered to be "documented information"? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
V Which batches should or could be considered for design validation and design verification? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
M Professional Use Medical Software French Labeling for Canada -- Not Considered Medical Device Canada Medical Device Regulations 2
S Tools and equipment provided by customer - Considered as external provider? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Risk Register - have we considered enough and is the format acceptable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E Are EEG electrodes considered as one applied part? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Can a Attribute Study be considered a Visual Inspection? Reliability Analysis - Predictions, Testing and Standards 6
M What is considered an "Audit Day" for OASIS AEA application? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 1
K What can be considered a "Post Delivery Activity" (ISO 9001:2015 Clause 8.5) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
C What is considered a "Critical" Raw Material? (Re: DNA Synthesis) Misc. Quality Assurance and Business Systems Related Topics 3
F Is Training Material Considered Labeling - FDA 21 CFR 801 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
C DFAR 252.225-7008 - Is aluminum, say T6061, considered specialty metal (i) steel? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
I What are considered next generation ITSM tools? IT (Information Technology) Service Management 1
J Can a Surge test fail to a test level and still considered as Compliant? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Y Which version of ISO 13485 would be considered for MDSAP certificate? Canada Medical Device Regulations 8
L AIs the R&R study a training evidence considered ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Chris Ford When is a device considered "sold to the general public?" Canada Medical Device Regulations 2
M Is Pain considered Harm in ISO 14971? ISO 14971 - Medical Device Risk Management 11
F Can be several measurement in a repl considered as nested factor in Minitab analysis Using Minitab Software 14
J Can some measurements be considered information only and not need calibration? General Measurement Device and Calibration Topics 7
M Is a computer used in hospitals considered a medical device? ISO 13485:2016 - Medical Device Quality Management Systems 17
S Are Polyethylene-folie gloves considered Medical Device ? EU Medical Device Regulations 4
T Has anyone considered what logic is? Coffee Break and Water Cooler Discussions 23
D Identification and Traceability 7.5.3 - What is considered Traceable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
JodiB Is Metals Analysis of Water Samples considered "sampling"? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
J Is painting considered a Special Process as defined by ISO 9001 7.5.2? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
E Extent of modification to be considered as Modified Adoption Other ISO and International Standards and European Regulations 1
R How much Protective Current Rating of Building Branch Circuit should be considered? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
O Is this considered Design and Development in ISO9001? Mushroom Farming ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V What are Basic Dimensions about and why are they considered basic? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Outsourcing Records Storage - Compliance Aspects to be considered during Audits Document Control Systems, Procedures, Forms and Templates 7
R Is foreseeable misuse considered as single fault condition? IEC 60601 - Medical Electrical Equipment Safety Standards Series 33
I Are KPIs (Key Performance Indicators) considered as Quality Objectives? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R Should Nurse Call Systems be considered as ME Equipment or System? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
sagai New Draft Guidance from FDA - Factors considered for Risk/Benefit Determination Other US Medical Device Regulations 4
sagai What is CD writing considered as - for Device-Only SW? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
B Is Ship Test considered Design Verification or Design Validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A Are Heart Rate Monitors used in Wellness Environments considered Medical Devices? EU Medical Device Regulations 13
M IEC EN 60601-1-8: Battery monitor considered an alarm? IEC 60601 - Medical Electrical Equipment Safety Standards Series 12
A Delivery Terminology - When is a product considered "Delivered" AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 7
ScottK Are Temporary Employees considered Employees from a Procedural Standpoint? Quality Manager and Management Related Issues 19
Q Health Canada - Licensed Devices now considered Drugs? Canada Medical Device Regulations 2
F Can a website be considered a Document of External Origin? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
