What is exactly the root cause?
qualprod
Hi everybody
I come with this issue, maybe it was questioned a lot of times, however have not found something
convincing for me, in the analysis I face doubts not easy to be solved in my understanding.
I´ll share a case hoping yor are able to help me.
in trying to find the root cause in a CA because of defective product delivered to the customer.
Considering, Man.Material, procedures,measurement, environment and machine.
After analyzing each, we found two causes.
1-Wrong instructions of product into the work order by the sales responible
2-Missed inspection at certain step of the production.
From here, I could think by a 5w in (1) why wrong... because didn´t know well the machines to choose the right machine , why.., because, didn´t have a training, why didn´t have training.., because, nobody was aware of his competency to develop this job or??.
for the (2), by using 5w, why, because worker, didn´t know the instructions (didn´t know he had to call the inspector at that step), why.. because was not fully trained in that production, why.... because nobody took care about the progress of his training. or??
Ok, I coud think, is enough with this cause (1), and from here to define action plans and finally to evaluate the effectiveness.
Could I say this is the only root cause (1) and the (2) not to be addressed, because if the (1) hasn´t been happened, the (2) would´have not been happened.
or could I suppose both are valid and for both I have to define action plans?
Or the point is, to find root causes of any problem happened in the reject of customer
Also in the final root case in both cases, I have some doubts.
I´m confused, please give your advice.
Is this an actual current issue you're facing, or a hypothetical situation? If it's an actual case, you need to provide enough information for us to be able to help you. What is the product and the nature of the defect(s)? Is this a recurring problem?
Tagin
Both of these point to a single area: 7.2 Competence
It looks as though management has not performed (or inadequately performed) 7.2 a-d for these job roles, or at least not adequately.
But in addition, your references to 'nobody' suggest that management has failed to assign responsibility (5.3) to someone to monitor 1) the training requirements for these roles and 2) whether employees have been trained to the requirements and 3) have demonstrated competence.
The more I think about 'root cause' these days, I think the idea of a single root cause is overly simplistic. The QMS is an organized, interconnected web of a system, and not a simple linear sequence of events.
A QMS is a system of linear processes. Processes often cross department boundaries, but that doesn't mean that the idea of a single cause is simplistic. The goal is to identify some feature or step in the process which if corrected would prevent the thing from happening again, and not to think of it as an amorphous blob without identifiable constituent parts.
Tagin
We disagree. At the least, I see a 9001 QMS as a cyclical PDCA, not linear. Within that, processes are themselves typically PDCA cycles in nature, if not in documentation. Nowhere did I say or imply that it was an amorphous blob without identifiable constituent parts.
If QMS processes were not linear, it wouldn't be possible to create a process flow diagram. In terms of control, QMS processes MUST be linear.
qualprod
Thanks Jim
Is somewhat recurring.
Is a real case.
The responsible who catches the customert needs, develops the work order, based on
type of machine ,its capacity, cost/hour, the handling of sheets, machine allowable dimensions to produce parts, etc.
He needs to understand perfectly all this data before releasing the work order to production.
This time, assigned other similar machine not the correct one, for this job.
Operators follow the instructions recommended in the work order, diemensions of product, tolerances,what machine have to be used
for printing, what type of process: cutting, punching, type of packaging, type of box, etc.
Due to this, the product resulted with some defects because was fabricated in that "similar machine".
The products is comprised of several steps, printing, cutting, bending, packing and delivery.
In each step product is verified against specifications, but after bending, the worker simply, didn´t follow
the instructions in the procedure of production, where is clearly stated "when product is finished in eachs step, have to call the Inspector
to verify quality of product.
Questioned why this happened, just told us, I was trained quickly, didn´t know in detail the procedures, so I thought that at this step
checking was not neccessary, I supposed will be checked in the next step.
Normally final checking is not done, because over the time has been enough this type of checkings.
Going to the original question, in this case: what is recommended to do?
Just to consider the first cause? considering that if first would not have happened, I wouldn´t have to worry for the second?
Who is authority to approve that root cause (1) is enough or have to be both?
lanley liao
In fact, these belong to the process-based of management, which so-called process approach. you shall find out the root cause from the gap of the management system. this involves three aspects: planning——implement——checking. and then identified which stages have been a problem. This problem, analyzed from material, procedures, measurement, environment, and machine. Generally speaking, modified the corresponding document rules and organized the training related to the department head and staff. FYI
Taking this and some of your previous posts, there seems to be a pattern of incompetence. In this case, it seems fairly obvious that there should be standardized routers for your various jobs, such that one person doesn't have to create one every time a job is run. The problem seems to go deeper than that, though.
Jen Kirley
Quality and Auditing Expert
I agree with Jim. This is too important to rely on a relatively recently trained employee to "understand perfectly." How will he understand the various machines' capabilities perfectly? Do you have a guideline? This seems to me to be about the planning process.
It is reasonable to limit machines to processing determined materials requiring particular tolerances. Their performance capabilities can be understood over time and known performance. Machine #1 is capable of handling to tolerance of X for ABC material(s), and Machine #2 is capable of processing to a tolerance of Y for XYZ material(s). Forming a matrix of this data would help you avoid having to re-learn all of this whenever the planner eventually leaves (and we all leave sometime, for one reason or another) and could support both accuracy and production planning for a minimum of process "bottle necks." This type of document would ideally be protected against loss and unauthorized change, though it does not need to be controlled in the same way as a procedure - signatures for updates, revision numbers etc.
I also agree with Lanley, it seems sensible to have a step in the planning process for an experienced person to check the planning. A signature and date spot on the work order would help define this process step and help ensure it is being done - as long as someone at some point is overseeing that, to ensure all responsible persons are providing their required inputs.
P MSA - what exactly mean "system" and master sample Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
Watchcat FDA will not tolerate fraud…meaning what, exactly? Other US Medical Device Regulations 8
I When exactly was "competence" added to the ISO-9001 standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
I When exactly can a corrective action be closed? Nonconformance and Corrective Action 3
E PPAP Checking aids, what to do exactly? APQP and PPAP 5
L What exactly does Configuration Management in ISO 9001, Clause 7.5.3 means? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Exactly which are the records needed by ISO9001? or is it my decision? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Crusader Who is "Top Management" exactly in ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
A What exactly is Facility Management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
L Control Plan vs. Inspection Plan - What exactly is the difference FMEA and Control Plans 5
S What exactly is retesting? Is re-analysis and retesting the same? Document Control Systems, Procedures, Forms and Templates 5
K What exactly is Digital Product Definition? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A Definition Contract Review - What exactly is "Contract Review"? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
ScottK What exactly is a "Process of Record" and what goes into it? Document Control Systems, Procedures, Forms and Templates 5
J Who exactly needs "ISO Training" in a company? Training - Internal, External, Online and Distance Learning 8
R Definition What is exactly meaning of word between "Supplier" and "Vendor" ? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
R What exactly would a Stage I Assessment consist of for ISO9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Precontrol - What if two points are exactly on the limit? Statistical Analysis Tools, Techniques and SPC 6
H Confirmation of software - Exactly what the last paragraph of 7.6 is asking for? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
L ISO 14001 4.4.4 d) - What exactly are the documents and records required by ISO 14001 ISO 14001:2015 Specific Discussions 3
J What exactly does 4.2.3.1 "Engineering Specifications" in ISO/TS 16949 mean? IATF 16949 - Automotive Quality Systems Standard 22
Q Control methods - What exactly are 'control methods' in a Control Plan APQP and PPAP 6
Crusader Where do I exactly implement TS 16949 - minimum? Only 2% of business is OEM IATF 16949 - Automotive Quality Systems Standard 12
A What exactly has to be included in a TS 16949 records matrix IATF 16949 - Automotive Quality Systems Standard 4
Marc Six Sigma is now said to be a set of tools - What, exactly, are they? Six Sigma 24
D Automotive manufacturing process - Our process isn't exactly like APQP APQP and PPAP 5
S What does OEM exactly mean? What does "equipment" include? IATF 16949 - Automotive Quality Systems Standard 2
R NIST - Primary Standard - Traceable to what? What exactly does that imply? General Measurement Device and Calibration Topics 10
T Not responsible for product design - Exactly which parts of 7.3 do not apply? Design and Development of Products and Processes 3
F Definition Retention Zone - What exactly are you calling zones of retention? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
D APQP - No two companies conduct their APQP/PPAP activities exactly alike APQP and PPAP 2
M Exactly how high in the organization is it necessary to have training records? Records and Data - Quality, Legal and Other Evidence 4
D Can anyone enlighten me as to what exactly Cm / Cmk are? Statistical Analysis Tools, Techniques and SPC 1
D What exactly is needed on the subcontractor list for evaluating subcontractors QS-9000 - American Automotive Manufacturers Standard 4
M Test failure Root cause not found Customer Complaints 10
Tagin You're Gonna Need a Bigger Root Cause Coffee Break and Water Cooler Discussions 12
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
qualprod D5 of 8D clarification, how to verify root cause Problem Solving, Root Cause Fault and Failure Analysis 26
T Tactics for Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 4
W Misinterpretation of requirement acceptable as root cause? Problem Solving, Root Cause Fault and Failure Analysis 19
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
D Root Cause for Missed Audits Misc. Quality Assurance and Business Systems Related Topics 1
qualprod Always one root cause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
G Working on a Root Cause Problem Solving, Root Cause Fault and Failure Analysis 11
I Root Cause Analysis when someone simply stops performing a task? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
C Neglect or legitimate deferral? Is excessive workload or lack of resources in a department or a team a valid root cause for a non-conformance? Problem Solving, Root Cause Fault and Failure Analysis 12
E CAR (Corrective Action Report) with questionable Root Cause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
