What is meant by "Configuration Management"?
bambino Spin
I'm new to the AS9100 standard (but familiar with the ISO 9001 standard).
What exactly should we be managing the configuration of?
Thanks in advance for all the helpful answers!
BadgerMan
Re: "Configuration Management"?
There is a wealth of information here regarding configuration management processes and practices. Explore the search function using "configuration management" or "ISO 10007" and you will find many previous threads.
"Configuration Management" is a particularly unfathomable term. The person that thought of using it in the AS standard should have been drawn and quartered. Surely they could have found an easier more understandable term.
In clearer terms it is "revision level control". It entails what you need to do to ensure that what you build is what your customer wants, that is that the agreed configuration (revision level) matches the actual configuration (revision level).
bambino Spin
Do you have your own designs or product?
We generally manufacture customer designs, or we collaborate with a customer to create a new design. Sometimes the customer owns the design, provides the prints. Sometimes we create our own designs and prints.
bambino Spin
Thank you, Jim.
So, is it accurate to say that "configuration" is nearly synonymous with "revision"?
So this is very similar to document control?
alspread
Configuration management means a lot more if you make your own product and/or control the design.
For Example:
Let's say you manufacture automobiles. You make a 2011 Bambino Spin 5000. Everything is going fine. Sometime in the middle of the model year you decide to change the alternator for whatever reason. Some of your 2011 Bambino Spins have the type A alternator and some have the type B alternator and they are not interchangeable.
Five years from now someone needs a new alternator for their 2011 Bambino Spin. They go to the parts store and the clerk asks them for the VIN number. He needs the VIN number because all of the 2011 Bambino Spins with a VIN number greater than 'x' were equipped with a different alternator.
This is a very simplistic example of what configuration management is trying to control. Multiply this by a couple of zillion other changes up and down the supply chain and you get an idea of the importance of configuration management.
Good luck
R What is meant by Use of COMPONENTS WITH HIGH-INTEGRITY CHARACTERISTICS in ME EQUIPMENT (clause no 4.9) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S What's meant by ISO9001 clause 8.7 non conforming output? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
P Validation of Processes - What is meant by 7.5.6 (a) - Defined Criteria for Review ISO 13485:2016 - Medical Device Quality Management Systems 7
J APQP Requirements - What is meant by "among other items" IATF 16949 - Automotive Quality Systems Standard 2
M "Value", A product that really meant something to you Coffee Break and Water Cooler Discussions 15
T Are Control Plans "Summary Documents" not meant to replace Work Instructions? IATF 16949 - Automotive Quality Systems Standard 3
T What is meant by a Characteristic Classification within GR&R? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G What is meant by FAI (First Article Inspection) and how do we comply? AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
G AS9100 - Clarify what is meant by Statutory & Regulatory Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A DMR (Device Master Record): What is meant by these words - Software Specifications? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
P Non EASA Aircraft - What is meant by Non EASA Aircraft? EASA and JAA Aviation Standards and Requirements 4
K Subgroup Size - Understanding what is meant by Subgroup Size Six Sigma 13
S Does 7.4 apply to products or services meant for Environment or OHS management? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
H AS9102A - What is meant by 5.2.5, "... approved Special Process sources..." AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Chennaiite What is meant by 'Lesson Learned' in the context of Problem Solving Quality Tools, Improvement and Analysis 6
C What is meant by two throws, three throws etc, when applied to Compressors? Manufacturing and Related Processes 4
W What is meant by Process Approach Auditing and What questions should be asked? Process Audits and Layered Process Audits 11
J What is meant by number of "items"? Chrysler Layered Process Audit Question Process Audits and Layered Process Audits 10
G What is meant when a datum (feature) is called a "6 way"? GD&T help Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
R What is meant by "Test Specimens" per AS9100 Clause 7.4.2 f) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
R Purchasing Information - Trouble understanding what is meant by a), b),and c) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A TS 16949 Clause 7.4.3.2 Promotion of supplier monitoring - What is meant by promote? Supplier Quality Assurance and other Supplier Issues 6
F Scheduling Internal Audits - What is meant by 'based on status and importance'? Internal Auditing 35
M Para 4.6.3c - What is meant by the last part; ...number and issue of...? QS-9000 - American Automotive Manufacturers Standard 4
R Configuration Management - Identifying Documentation IEC 62304 - Medical Device Software Life Cycle Processes 3
H AS9100 D - 8.1.2 Configuration Management for Build-to-Print Service Provider AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Configuration Item definition question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
William55401 Distributed By Product - Best Practices for Configuration Management and Purchasing Controls ISO 13485:2016 - Medical Device Quality Management Systems 0
John Predmore Configuration Management as a process instead of a procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
G AS9100-8.1.2 Configuration Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
H EO Sterilization Validation - Sterility Testing and Load Configuration Other Medical Device Related Standards 3
R Configuration Management in AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
N Configuration Management - Physical Audit and Functional Audit for Software and Hardware General Auditing Discussions 4
T Change control and configuration management - When to create a new model/part number? Other Medical Device and Orthopedic Related Topics 0
P Configuration Management Software EASA and JAA Aviation Standards and Requirements 4
W Reproducibility on Different Machines of the same Configuration Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
C Per IEC 62304, are DHF documents Configuration Items? IEC 62304 - Medical Device Software Life Cycle Processes 8
P EASA STC (Supplemental Type Certificate) on a Pre-mod FAA STC Configuration EASA and JAA Aviation Standards and Requirements 1
F Class II 510(k) question for device with different EU - US configuration 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
J Configuration Manager's Duties - AS9110 or AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Q Configuration management clarification and example AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
M How to identify software configuration items in a BOM Quality Manager and Management Related Issues 3
A Risk Management and Configuration Management ISO 14971 - Medical Device Risk Management 3
K Example of ISO 10007 - Configuration Management Plan AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A AS9100. 7.1.3 Configuration Management. PCB production. ECN. Revision Control. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K Software Configuration Management Audit Questions Quality Assurance and Compliance Software Tools and Solutions 8
Q Configuration Management Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Wes Bucey Aerospace Configuration Management Webinar Book, Video, Blog and Web Site Reviews and Recommendations 3
Q Understanding Configuration Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
B How to define and implement Configuration Management Document Control Systems, Procedures, Forms and Templates 5
