What is Normal Theory?
sathis
Involved - Posts
What is Normal Theory? - Comes in SPC Topic.
I have seen Central limit Theorem .
Sathish
Tim Folkerts
Without knowing the exact context, I would assume they simply mean theory based on the normal distribution.
Not everything follows a normal distribution, but it is a good approximation to many real-life situations. Furthermore, the mathematics of the normal distribution are well known, so much of statistical analysis is based on the assumption that the data follow the normal distribution.
bobdoering
Stop X-bar/R Madness!!
Normal process: in control with chance variation
In order for a process to be normal, it should be able to be:
1. Set at the mean
2. Will continue to randomly vary about the mean without any operator intervention!
A process in control is in the ideal state 100% conforming and predictable
1. must remain stable over time
2. must operate in a stable and consistent manner
3. must be set at the proper level
4. the natural process spread must not exceed the product’s specified tolerance (capability)
A great example of a normal process is cutting the grass. You set the mower deck to a particular height. As is typical for a quality profession, one would measure each blade of grass after cutting, and you would find most near the mean height (height of the deck setting) – with some a little longer and some a little shorter. Most “natural” variations, such as operations influenced by humans or nature (environmental) that are not unilateral are normally distributed.
I am sure others can give deeper academic explanation, but this is a good overview, I think...:tg:
However, not all processes are normal – and treating them as such generates incorrect decisions. Precision machining is just such an example. It is non-normal, continuous uniform distribution – which means the central limit theory does not apply. For more information on this, see: Statistical process control for precision machining :cool:
Darius
Also for a variable to be "normal" (Gaussian) ones, there must not be a dependance on time (for example dependance on delays of production line).
bobdoering
True, good catch! :agree1: By definition it must be random and independent variables!
before we move too far afield can you give us more specifics about your question?
From your post I'm assuming that you are aware that the central limit theorum says that sample averages will tend to approximate a Normal distribution provided that certain conditions inherent in the theorem are met.
Are you asking about specifics of what the Normal Distribution is?
Steve Prevette
Deming Disciple
I should point out, since the original question was in the context of SPC, that normality of data is NOT required for use of SPC. Dr. Shewhart established SPC principles based upon the Tchbychev Inequality, and tested the SPC theory for the normal distribution, and for two non-normal (uniform and triangular) distributions.
bobdoering
Yes, on pages 136 through 137 of "Economic Control of Quality of Manufactured Product", Dr Shewhart analyzed a variety of distributions, and on page 182, he described experiments that described both a triangular and rectangular (uniform) distribution.
So, I agree, you might say that normality is NOT required for use of SPC.
I am kind of sensitive to lumping the "uniform distribution" into that statement. Closer observation of Dr. Shewhart's example of a uniform distribution, it is clear he established a discrete uniform distribution, which is an independent function, and therefore supports Central Limit Theory and Tchbychev Inequality. We must not confuse this with the continuous uniform distribution found in precision machining, which is a dependent function - and not the uniform distribution of Dr. Shewhart's experiment, and not supported by Central Limit Theory and Tchbychev Inequality. But, statistics can be used control the process - they just need to be correctly geared to that distribution (as in NOT Xbar-R). Then it works very nicely.
Tim Folkerts
:topic:
Not to beat a dead horse, but the Central Limit Theorem does indeed apply to both the discreet and continuous uniform distribution.
"the re-averaged sum of a sufficiently large number of identically distributed independent random variables each with finite mean and variance will be approximately normally distributed"
is a reasonable statement of the theorem (from Wikipedia).
When the variables are not chosen randomly, then, not surprisingly, the result can and does sometimes fail. In particular, in quality we often sample the output systematically - for example items 1, 11, 21, 31, ... If the process itself is random, then the central limit will still work here. If the process is something like precision machining, the central limit theorem will fail - not because the central limit theorem itself does not apply, but because the sample chosen was not random.
A random sample chosen from a uniform distribution will follow the central limit theorem. It is not the uniform distribution itself that leads to the failure, it is that the uniform distribution was generated in a systematic way AND the sample was chosen in a systematic way.
Tim F
BradM
Interesting. Let's assume I am not sampling random. The more sampling that I do, the pool of samples will begin to represent the population. And as the # of samples gets closer to the population, the distribution will more represent a normal distribution, would it not?
U Theory and Practice Behind Expecting a Distribution for my Data (specially the normal Statistical Analysis Tools, Techniques and SPC 48
adir88 Tools for Normal and Fault Conditions ISO 14971 - Medical Device Risk Management 9
Q What is the Normal Flow in an ERP for Manufacturing? Manufacturing and Related Processes 0
A Touch current in single fault conditions test and earth leakage current in normal conditions test, are they really different tests? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
R Non Normal Data in a historically normal process Capability, Accuracy and Stability - Processes, Machines, etc. 6
N Apply control limits to a non-normal distribution Statistical Analysis Tools, Techniques and SPC 13
J Is a stable process also normal at the same time? Manufacturing and Related Processes 7
S Jewelry vs. Normal Laboratory Balances - Accuracy and calibration General Measurement Device and Calibration Topics 2
R Non-normal Distribution Selection where the system is constantly being corrected Capability, Accuracy and Stability - Processes, Machines, etc. 11
J Is My AS9100 certification Auditor Normal? Registrars and Notified Bodies 9
Y Process Capability for Non-Normal Data - Philosophical Questions Capability, Accuracy and Stability - Processes, Machines, etc. 6
D Interpreting Normal vs Weibull Capabilities Capability, Accuracy and Stability - Processes, Machines, etc. 4
P Should Data be Normal before Computing Baselines? Statistical Analysis Tools, Techniques and SPC 4
Q Is it normal practice to lubricate Ring Gages before use? General Measurement Device and Calibration Topics 17
A Not all characteristics follow a Normal Distribution - How do you do SPC Chart Capability, Accuracy and Stability - Processes, Machines, etc. 5
A Is normal for FORD EU ask for the PSW every year APQP and PPAP 5
V Process Capability for parameters with non-normal distribution. Capability, Accuracy and Stability - Processes, Machines, etc. 16
P Non-normal Data Cpk Statistical Analysis Tools, Techniques and SPC 5
S Non-Normal Data - Measurement for "straightness" with a 0.001" max tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 10
D Calculating Cpk on Non-Normal Data Distribution Capability, Accuracy and Stability - Processes, Machines, etc. 10
J Non-Normal Distribution Data - Tolerance Intervals and Minitab Using Minitab Software 7
J Can Normal Probability Paper and GPC be created with Excel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M t-test with Non Normal Data Statistical Analysis Tools, Techniques and SPC 16
T Normal Distribution Test for Cpk (Minitab) Six Sigma 6
K Computing Cpk with out determining if my data is normal Capability, Accuracy and Stability - Processes, Machines, etc. 7
L Should Internal Audit CAPAs be kept separate from "normal" CAPAs? ISO 13485:2016 - Medical Device Quality Management Systems 6
A Handling Normal Capacitor Production Fallout AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
K Non-Normal Data Analysis Literature, Websites, Books for Learning Quality Tools, Improvement and Analysis 2
M Is it possible to get Natural Tolerance (Tn) with Non Normal Distribution? Statistical Analysis Tools, Techniques and SPC 9
B Is this Data a Normal Distribution? Statistical Analysis Tools, Techniques and SPC 10
L "Half Normal Plot vs Normal Probability Plot" of Effects Using Minitab Software 1
R Drawing a Normal Plot of the Effects for Multilevel Factorial Design Using Minitab Software 3
B Test of Means or Medians for Non Normal Populations? Using Minitab Software 6
B Is it normal for a procedure to begin with a conditional directive? (if statement) Document Control Systems, Procedures, Forms and Templates 30
S Relationship between Normal Distribution and AQL AQL - Acceptable Quality Level 13
R Transforming or not Transforming - Dealing with Non-Normal Data Statistical Analysis Tools, Techniques and SPC 10
O Which role plays Inverse cdf of a Standard Normal Distribution in Formula for Z-Bench Using Minitab Software 8
optomist1 Non-Normal Data F test and T test Capability, Accuracy and Stability - Processes, Machines, etc. 19
2 Medical Device Hazard Risks - Normal Use Risks vs. Faulty Use Risks ISO 14971 - Medical Device Risk Management 4
P Approved Suppliers - ISO 13485 Normal Supplier Qualification Process Requirements ISO 13485:2016 - Medical Device Quality Management Systems 9
S "Normal" vs. "Between/Within" Capability Analysis Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Which Normality Test more acceptable to FDA; Also, Non-Normal Threshold? Qualification and Validation (including 21 CFR Part 11) 5
T Is Cpk Analysis only for Data that came from Normal Distribution? Capability, Accuracy and Stability - Processes, Machines, etc. 7
M Non-Normal Data & Minitab Statistical Analysis Tools, Techniques and SPC 17
N Measurement Uncertainty - When is Normal and when is Triangular Distribution used? Measurement Uncertainty (MU) 3
M Truncated Normal Distribution: Characteristics and Use Statistical Analysis Tools, Techniques and SPC 25
