Informational What is PPAP (Production Part Approval Process)?
harley123
Hi all,
I have a customer who is requiring PPAP.
I am not sure what this is. They are the first to require this.
Can someone explain what this is?
I know what the letters stand for but what should be included in the process?
Is this an automotive customer? If so, they probably expect the PPAP process laid out in the PPAP manual available from AIAG.
However, there are many non-automotive customers that have either heard about PPAP, or have managers that have come from automotive that also request a PPAP from suppliers. These customers often have a much different concept of what a PPAP is. They often want part, but not all of the automotive PPAP. The only way to know for certain is to ask the customer in question what the specific requirements are.
ScottK
Not out of the crisis
I've worked with a number of Medical Device companies that have made their own version of PPAP. Especially Stryker - they called it SPPAP (supplier production part approval process)
I would first ask for a copy of their PPAP procedure and forms and see exactly what they expect and if they do expect you to use their forms.
Then research the links Marc provided.
From a practical perspective - If you have a complex part be prepared to put a lot of time into the process. I would work the labor and materials involved in this into the piece price, or as a one time charge. It's not something I would do for free unless there is a guarantee of a lot of sales negotiated.
You'll likely need to do Process Maps, Process Controls (possibly with FMEA), bubbled prints, FAI on just about every dimension and note on the prints, Capability Analysis on CTQs, full material certs... and then some
harley123
Thanks Scottk.
I will get with our customer. The information you gave me is what I am afraid of.
We do complete axle assemblies. Some have 40 or 50 components. It could take
along time to go through all of them.
TymTucker
For a large assy, with any luck they'll send you a level IV with only a few items specified - Part Submission Warrant, Control Plan, etc. Also be prepared to try to negotiate with over zealous demands. More than once I've asked if we really needed to run capability charts for 100 sets of wires 6 feet long with a 6" tolerance only to find the buyer just sent the form over with no real knowledge of the assy. (not the way it's supposed to work...)
Just remember, you have to do 100% of the PPAP regardless of level. The level only refers to how much must be sent to the customer. All of it must be retained on file.
TymTucker
True. In my case however, we build wiring harnesess in a very high-mix low volume business. If your company builds electric mousetraps and you want 100 wire leads for a one time order and request a PPAP because your engineer used to be in Automotive, that's a hard "No." It happens.
PiotrHab
Hello Miner,
what about level 4? Isn't it like you define what has to be submitted/retained and not defined requirements can be "skipped"?
For example, I received from the customer below requirements:
"PPAP Leve IV: Please submit below documents:
1. Design Record
7. Control Plan
9. Dimensional Results
14. Samples (5 pcs)
18. PSW"
My understanding was, that I need to submit above documents and nothing to retain...
Thank you in advance for reply
O PPAP'ed part manufacturer has discontinued production Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 7
Sidney Vianna AS9100 News PPAP in the Aerospace Sector - What is it? AS9145 - Requirements for Advanced Product Quality Planning and Production Part Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
K FAI (First Article Inspection) vs PPAP (Production Part Approval Process) APQP and PPAP 16
T Variable Dimensions / Part of Production / PPAP Dimensional Report Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
J PPAP (Production Part Approval Process) Requirements for Annual Revalidations APQP and PPAP 1
M PPAP (Production Part Approval Process) files for Ford APQP and PPAP 11
A What is PPAP (Production Part Approval Process) Why submit it and/with PSW APQP and PPAP 2
B Help for beginner - PPAP (Production Part Approval Process) APQP and PPAP 9
R Is Kappa Study Required during PPAP (Production Part Approval Process)? IATF 16949 - Automotive Quality Systems Standard 9
T Production Part Approval Process (PPAP) Presentation in ppt. format APQP and PPAP 3
F Who should Sign Supplier PPAP (Production Part Approval Process) documents? APQP and PPAP 13
H Who can require PPAP (Production Part Approval Process)? APQP and PPAP 7
S Tell Me All About PPAP (Production Part Approval Process) APQP and PPAP 7
J AIAG PPAP (Production Part Approval Process) Manual Fourth Edition Released APQP and PPAP 69
A PPAP (Production Part Approval Process) - Where can I buy the AIAG Manual? Preventive Action and Continuous Improvement 2
J PPAP (Production Part Approval Process) Submission Level Differences - Forms attached APQP and PPAP 17
W PPAP (Production Part Approval Process) - Clarify When submission is required APQP and PPAP 10
S "Update" the PPAP Package after Mass Production Commences APQP and PPAP 2
E What's the difference: AIAG-PPAP's "Significant Production Run" and "Run @ Rate"? APQP and PPAP 11
S Should PPAP Samples Come from a Production Run? APQP and PPAP 3
V Supplier?s PPAP - Production Process Control Plan Review, Evaluation and Approval? FMEA and Control Plans 5
O Significant Production Run - 2.1 in Section 2 of the PPAP Manual fourth edition APQP and PPAP 3
S PPAP - Production Run Quantities, Number of Subgroups and Subgroup Size APQP and PPAP 2
O Bulk Material PPAP - Design Matrix instead of a normal Design, Production FMEA APQP and PPAP 3
G Requirement to follow Control Plan for serial production in a PPAP run APQP and PPAP 4
S PPAP Production Sample Size APQP and PPAP 8
T Reworked components in PPAP production APQP and PPAP 22
I PPAP - Prototype vs. Production APQP and PPAP 6
P PPAP for Spare Parts - Low Volume - Occasional Production APQP and PPAP 5
C Re-PPAP My Parts? Production layout has changed APQP and PPAP 6
S PPAP Process Requirements-Significant Production Run APQP and PPAP 13
A Can a customer send a claim during PPAP? IATF 16949 - Automotive Quality Systems Standard 11
S PPAP machine VS tool Lean in Manufacturing and Service Industries 3
V Would the customer drawing change necessitate re-PPAP of the Product? APQP and PPAP 3
S Do we have to create a new PPAP to our customer if our Sub Contractor had to change? APQP and PPAP 10
Ashland78 PPAP required for repair of machine? IATF 16949 - Automotive Quality Systems Standard 5
M Is PPAP suitable for Inhouse parts? Manufacturing and Related Processes 4
K Level 1 PPAP Submission APQP and PPAP 12
M Aftermarket product PPAP approval IATF 16949 - Automotive Quality Systems Standard 1
S PPAP- (When to issue ECN,ECR & PCN ,PCR) APQP and PPAP 2
C PPAP requirements for consumer product APQP and PPAP 2
L PPAP for reagents, biologicals APQP and PPAP 0
M Signed PSW directly to End customer, Tier 1 wants their own PPAP IATF 16949 - Automotive Quality Systems Standard 6
A PPAP Alternate Equipment IATF 16949 - Automotive Quality Systems Standard 10
D What does a level 1 (PSW) PPAP actually promise? APQP and PPAP 19
R PPAP Requirements for Tool Repair or Refurbishment APQP and PPAP 5
abrego44 AIAG PPAP manual for service part APQP and PPAP 5
A PPAP question for audit APQP and PPAP 17
G PPAP for Chemical Products APQP and PPAP 4
T Re-PPAP after updating CMM program? Manufacturing and Related Processes 9
