What is Resolution Analysis?
L
Lexylou
Hi everyone....
I was reviewing our audit report again to prepare for a internal audit and came across this. Can anyone explain to me what a Resolution Analysis is?
During my last AS9100 audit the auditor noted in the Objective Evidence box that we "use resolution analysis".
This is related to 7.6 Does the organization determine the monitoring and measurement to be undertaken and the monitoring devices needed to provide evidence of conformity of product to determined requirements?
In the Guidance Notes it lists 3 examples (Interval Analysis, Resolution Analysis and Gage Repeatable & Reproducibilty)
Appreciate any help...thanks
Stijloor
Hi everyone....
I have seen it explained this way:
Resolution
The resolution of a test is the finest gradation on the measurement scale. A measurement system with insufficient resolution may hide variations that exist and invalidate analysis results. It is generally recommended that resolution is at least 1/10 of the lesser of specification tolerance and process variation.
Stijloor.
BSpitler
As it has already been stated, the resolution of a measurement device is roughly defined the smallest increment that the device is capable of distinguishing. But that is a statement, not an analysis.
The auditor may be referring to an analysis of the actual discrimination, or ability to distinguish differences, of the measurement system (number of distinct categories in Minitab). It is one output of a gage R&R study.
Hope this helps.
P Capability Analysis for Limited Resolution (thickness of sheets) Capability, Accuracy and Stability - Processes, Machines, etc. 6
T Resolution Analysis - Has anyone ever performed a Resolution Analysis? General Measurement Device and Calibration Topics 1
G 0.00005" tolerance on micrometer with 0.0005" resolution? General Measurement Device and Calibration Topics 4
G Problem Resolution Report Monitoring - Customer complaint or PRR as general motors use Customer Complaints 12
S Relationship between IEC 62304 problem resolution and ISO 13485 IEC 62304 - Medical Device Software Life Cycle Processes 8
T Customer rejected MDS - easiest resolution? RoHS, REACH, ELV, IMDS and Restricted Substances 1
Wes Bucey Conflict Resolution (without bloodshed) Misc. Quality Assurance and Business Systems Related Topics 1
F Resolution III Factorial Design for a Screening Experiment Six Sigma 2
O Make Layout Higher Resolution? Using Minitab Software 1
S FDA Warning Letter Remediation - Enforcement Resolution & Remediation Process US Food and Drug Administration (FDA) 3
B Total Resolution of an Measurement Instrument Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Steel Coil Scale Verification Resolution Calibration Frequency (Interval) 7
P Measurement Equipment - 10:1, 4:1 - Is it resolution or accuracy General Measurement Device and Calibration Topics 1
Jerry Eldred When Does Resolution of Measurement Standard Apply in Uncertainty Calculations General Measurement Device and Calibration Topics 14
P Resolution Requirements on Calibration Certificates General Measurement Device and Calibration Topics 8
B Treating Resolution - Rectangular or Triangular Distribution Measurement Uncertainty (MU) 6
D Resolution V Factorial Design with 5 factors (3 numerical and two text) Using Minitab Software 1
E Measuring Parts without Proper Tools - Measurement Device Resolution Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
K Micrometer Calibration - Resolution, Accuracy and Range General Measurement Device and Calibration Topics 16
R Definition PR&R - GM's Problem Reporting & Resolution System Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
P Not Enough Resolution for Gage R&R - 79" Panel Length Measurements Help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
J IAQG Resolution #67 - Extension of time frame for upgrade to ISO 9001:2008 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Gage Resolution vs. Tolerance Manufacturing and Related Processes 5
N ASME B89.1.13 question regarding Resolution and Maximum Permissible Error General Measurement Device and Calibration Topics 3
V Analog Pressure Gauge Calibration - smallest resolution practice General Measurement Device and Calibration Topics 12
somashekar New year resolution 2010 .. "No posts deleted by moderators" Coffee Break and Water Cooler Discussions 6
bobdoering Gage Resolution Required for SPC! Imported Legacy Blogs 1
C UUT resolution and reporting uncertainty for each reading Measurement Uncertainty (MU) 2
J Definition Accuracy and Resolution in a Measurement System: What are the differences? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 12
Hershal Congratulations L-A-B and PJLA - Signatory status - ILAC Resolution GA12.03 General Measurement Device and Calibration Topics 0
D The Origin of the 10:1 Resolution Ratio for Measurement Equipment General Measurement Device and Calibration Topics 17
C Can someone clarify "Resolution", "Discrimination" and "ndc"? General Measurement Device and Calibration Topics 4
C Are Customer Specifications Too 'Tight'? Gage Resolution and Gage R&R Issues Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
C Gage Resolution / Measurement Accuracy - Laser scan micrometer has a 6 digit display General Measurement Device and Calibration Topics 4
M Resolution question - Measuring a product on a CMM - the tolerance is .000/.001 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R Micrometer resolution for calibrating thread plug gages General Measurement Device and Calibration Topics 7
M Problem resolution for Common Causes.. Misc. Quality Assurance and Business Systems Related Topics 4
J TFRR - What is actually required to be TEST FAILURE RESOLUTION REPORT Various Other Specifications, Standards, and related Requirements 2
Marc Definition PRR - Problem Reporting and Resolution - Production Readiness Review Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
P Measurement Resolution of In-Process Automated Inspection System - Stamping House Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
N Confuse: Calibration using master equipment - Resolution - Micrometer General Measurement Device and Calibration Topics 7
E Cpk's, specifications and tiny sd's - Resolution of measurement equipment Capability, Accuracy and Stability - Processes, Machines, etc. 20
W Resolution and Sensitivity - What is measurement instrument or gage 'Sensitivity'? General Measurement Device and Calibration Topics 12
Marc Happy New Year - 2005 - What are your Resolution(s)? Coffee Break and Water Cooler Discussions 7
D Resolution, Discrimination, NDC and the Tower of Babel in Metrology General Measurement Device and Calibration Topics 5
apestate Calibrating .001" resolution Dial Calipers - Calibration and safeguarding procedure General Measurement Device and Calibration Topics 6
A Nonconformance Resolution - Is 8.3 applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
E What is the smallest graduation (resolution) available for a Dial Test Indicator? General Measurement Device and Calibration Topics 2
J Measurement Resolution - How far to carry the decimal place out Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
