What is supposed to happen when a CA cannot be closed out or the root cause...
K
kbishop94
determined?
Example:
Customer Complaint: Contamination is found in the product we provide to them. (chemical, liquid petroleum based, processed and shipped out of our facility in 55g drums)
Investigation phase: It was determined and agreed upon by all parties (this was a lengthy RCA process involving multiple parties including (1) our organization (2) supplier of drums (3) customer and (4) supplier of raw the material.
During this investigation it is determined by all (and agreed upon) that the most likely source of contamination was coming from the drums. Chemical analysis of the contamination was also performed and backed up the theory that the source was indeed the drums.
Corrective Actions: Corrective actions were put in place to (1) check the drums, (2) clean the drums out (if necessary) and (3) filter the product before being transferred to the drums (as a precaution.)
Implementation: Revisions to SOPs and Work INstructions are made and implemented and process is audited to verify the effectiveness of the changes made. All is good.
Then, the contamination is back. Furthermore, it is revealed that it was probably there all along but it was just smaller particles that they prior observed. So what actions do we ,\should we, take from here? Re-open that CAR, or issue a new one? What if its revealed that the contamination has always been there and the customer just did not have the necessary equipment in place to find it? Could the CAR be redacted in this case?
Thanks for all suggestions and opinions here folks!!
Big Jim
I would open a new one and reference the old one.
Sometimes even with due diligence problems are not resolved on the first go around. You now have another opportunity to resolve it. That doesn't mean that you didn't learn from the effort so far. At minimum you have learned that what was already done either wasn't right or wasn't sufficient.
When a problem repeats, there is ALWAYS something about it that can help with the resolution. The circumstances were different. The conditions were different. Someone else observed it. Etc.
When you have a repeat it may be necessary to bring more resources to the resolution. Keep an open mind and brainstorm with the best individuals in the collective organizations.
In this case, having been through something like this, I suspect that the drum supplier is still having trouble with his coating process. That said, keep an open mind and see what turns up this time around.
The smaller particles could also be due to your own filtering process. You might see if the particles are smaller than your filter mesh and check the filters to see if they caught anything.
Run with what you have learned that is different and keep an open mind about other possibilities.
Crimpshrine13 PPAPs (How far down the tiers are we supposed to get PPAPs)? APQP and PPAP 19
B Confusion on the new FMEA guidebook - Are we supposed to replace our FMEAs? IATF 16949 - Automotive Quality Systems Standard 3
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
U Dock Audits - Isn't waiting to do an audit when the product is "supposed" to ship a little late? Manufacturing and Related Processes 12
S The days before International Standards - Has ISO done what it was supposed to? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T AS9102 FAI - What is a distributor of ball bearings supposed to do? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Who are supposed to be the auditees/auditors in a small organization? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
E GM's RED X - Supposed to be a simple tool to find Root Cause Problem Solving, Root Cause Fault and Failure Analysis 25
P Is the first piece inspection method supposed to be in the Control Plan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 18
K APQP - Is the APQP process supposed to include process changes? APQP and PPAP 2
H Operational planning and product and service provision when things happen so fast ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
P Scope Document - Does anyone happen to have an Example Scope Document (4.3)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
U What if UK leaves EU? What will happen to European Authorized representative in UK? EU Medical Device Regulations 22
R IEC 62133 to satisfy 60601-1 3rd edition - What happen to 60086-4 Other Medical Device Related Standards 18
J What will happen if you can't answer questions of recruiters? Career and Occupation Discussions 4
M FMEA for Drilling Process - What kind of failure can happen during drilling process? FMEA and Control Plans 8
AnaMariaVR2 Jason Fried: Why work doesn?t happen at work Career and Occupation Discussions 3
bio_subbu Never happen in life again??!!!! Coffee Break and Water Cooler Discussions 4
A Repeat Major NC - What can happen during External Audit by Registrar General Auditing Discussions 23
J Changes to AIAG's FMEA manual to happen in the 3rd quarter of 2007 FMEA and Control Plans 10
T ISO 14001 Registered and out of Compliance - What should happen? ISO 14001:2015 Specific Discussions 13
K What will happen if our QMS, which is QS-9000, certificate expires? IATF 16949 - Automotive Quality Systems Standard 4
B Will ISO 9001 be modified in 2008? What will happen to TS 16949? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
supadrai Possible to Submit a 510(k) if you have never, do not and cannot produce the device for which you're submitting the application? US Food and Drug Administration (FDA) 4
I Cannot Export multiple sections from Excel to PDF without losing pagination Excel .xls Spreadsheet Templates and Tools 23
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
BradM Cannot stay logged in Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 16
S Cannot create Rejects for TMV on a medical instrument with an LCD Other Medical Device and Orthopedic Related Topics 10
insect warfare Cannot determine what type of medical device this product is.... 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
K Anyone who audits 8.2.2 cannot audit other clauses of the standard? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 31
rob73 If NB's (notified bodies) cannot be trusted how can we? EU Medical Device Regulations 39
C Document Control using Wiki - Cannot Create all Documents as Wiki Pages Document Control Systems, Procedures, Forms and Templates 10
K Corrective Action cannot be completed within the agreed time frame Nonconformance and Corrective Action 7
X Cannot Verify until Customer uses Product - Clause 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
L Preventive Action should not / cannot be taken when rectifying a problem ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 94
W What can/cannot be placed on packaging/advertising relating to ISO/TS? Registrars and Notified Bodies 1
M 'Searched' virus? Cannot delete folder - HELP please After Work and Weekend Discussion Topics 33
A Changes to QRI (Quick Reference Instruction)? What I can or cannot change ISO 13485:2016 - Medical Device Quality Management Systems 2
T Control Chart on Paper vs. Software where trend cannot be seen (Alarm only) Statistical Analysis Tools, Techniques and SPC 8
J Is it true that the Quality Manual cannot be a Procedure? Quality Management System (QMS) Manuals 13
C What can I do if I cannot meet PPAP deadline? APQP and PPAP 4
D New thread ring cannot be threaded onto the truncated part of the master General Measurement Device and Calibration Topics 4
E MSA Manual says the sum of EV,AV,GRR, and PV cannot equal 100%? Why? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Disaster Recovery Plan - I cannot find references to same in ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 3
C What is the best practice to label small tools (small pins) which cannot be scribed? General Measurement Device and Calibration Topics 5
A Goals cannot be reached, don't adjust the goals, adjust the action steps Coffee Break and Water Cooler Discussions 8
Casana Auditor changing ISO 9001 AUDIT scope midstream - Cannot exclude all of 7.3 anymore General Auditing Discussions 26
V MINITAB and non-normal unilateral tolerance data - Cannot confirm Ppk values Using Minitab Software 15
M ISO 9001 Clause 7.6 Measuring Devices cannot be excluded!? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 48
R 17025 Calibration Requirements - External calibration service cannot calibrate ISO 17025 related Discussions 4
