morning,
I work for a sheet metal fabrication company, we manufacture yellow goods, military, railway, refuse components, fruit machines, hospital beds, harvester equipment. We offer laser cutting, machining, brake press, resistance nut welding, power presses, manual welding, robot welding, wet and powder painting and full mechanical assembly.
We do not have any production lines but the listed work centres above, with parts moving through different work centres based on their routing through the company, which is controlled by the MRP system. We do not regularly manufacture the same part, we have contracts for parts and in some instances might only make 200 of one part and not see if again for a year, some times never again.
We have a customer who normally produces electrical components, but they have been using us to manufacture steel and aluminium boxes, plates and other fixings. They have set us a figure of 500 PPM. We delivered 3806 parts to them with 4 rejects, giving us a PPM of 4972. The rejects are subjective, they do not understand welding and want visually pleasing welds, but a good looking weld in aluminium is not always the strongest etc. They have also rejected parts on paint, which was quite subjective on their part. Other issues are resistance nuts snapping off, yet we torque check every 10 parts, calibrate the machine monthly, spc the tooling etc.
Firstly does anyone believe that 500PPM is the correct figure for a company of our type, secondly should we be more aggressive in our handling of rejects?
cheers in advance.
Andy
cheers in advance.
Andy
Welcome to the cove
