What is the average time needed for process documentation?
Mohashamoon
Compliance Specialist
I want to know the average time needed to write process manuals (which contains the policy, process maps, procedures, and all the step by step work instructions)?
Example, I'm going to write the Leasing Department Manual which contains the main policies which they should follow, the process maps for all their works, the procedures on how to get the policies done and all the step by step works they are doing. To do this, I'll have to shadow with the SMEs of this department and record everything then look for the best practices and control points, this ofc is going to be reviewed by different managers and they will request edits... Etc.
Any similar experience?
Regards,
Mohamed Shamoon
Mike S.
Happy to be Alive
I don't think any of us would have a better guesstimate than you. It's like me asking you how long it will take for me to drive home tonight.
ScottK
Not out of the crisis
from your description it looks like you are going to make process improvement recommendations along the way...
My advice is document the process as it is today (current state), publish that, then work on incremental improvements.
If you're trying to do improvements before the process is documented it will be a never ending project and you'll never publish.
Documenting current state give you a baseline to measure progress.
L.Soad
I wish i did that, i can 100% approve this.
Mohashamoon
I knoe but, I wanted to know if I'm being slow/fast... Etc. Wanted to check with someone who's been there and done that.
Thanks for your comment anyway.
ScottK
I have been there and done that.
A number of times.
It's been from a couple of weeks to a couple of months depending on the level of authority I had, how cooperative the stakeholders were, and what other projects I was juggling.
Recent memory - I completely re-did a customer complaint/return process in a fairly small company that averaged about 5 complaints a week. With relatively cooperative colleagues it took about 3 months from initial Kaizen process mapping to finished and improved process.
L.Soad
Whatever the answer is for your situation, you and everybody else will be dismayed to learn that it takes a lot longer than you hoped it would.
even more if you have «obstacles» like a «not so involved» top management, really busy coworkers, complicated processes to explain (with a lot of technicalities for exemple)...
Ajit Basrur
Regards,
Mohamed Shamoon
This could be a good start for you https://writingassist.com/pdfs/EstimatingWritingProjects.pdf
J Average Industry Defect rates Supplier Quality Assurance and other Supplier Issues 2
B How many nonconformances have you received on average during IATF audits? General Auditing Discussions 27
L Uncertainty calculation for an average Measurement Uncertainty (MU) 1
qualprod Best approach to get a real value as average? Statistical Analysis Tools, Techniques and SPC 6
S Average and standard deviation of Cumulative Data Statistical Analysis Tools, Techniques and SPC 5
F Calibration certificate content - Average Value and True Value ISO 17025 related Discussions 6
P Average access height into an industrial machine (average base plate height) Human Factors and Ergonomics in Engineering 2
P Average Peel Strength - Interpretation of BS EN 868-5:2018 and ASTM F0088/F0088M Other Medical Device Related Standards 2
qualprod Cycle times, value stream mapping, inventory, average values? Lean in Manufacturing and Service Industries 1
Proud Liberal How long does your company take to close an 8D on average? Problem Solving, Root Cause Fault and Failure Analysis 12
L How to interpret the average R bar Value shown in the R Chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
J0anne GCC Submissions - Average review time for SGH qualification files Other Medical Device Regulations World-Wide 11
K Average height of adults by sex by state Other Medical Device and Orthopedic Related Topics 10
M What is the difference between X Bar - R Charts and Average Chart? Statistical Analysis Tools, Techniques and SPC 7
M Average Run Length (Student Question) Statistical Analysis Tools, Techniques and SPC 3
F Statistical Comparison of Product: High Average vs. Low Range Capability, Accuracy and Stability - Processes, Machines, etc. 13
G Improve final GR&R value by taking average of more measurements? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
K Can I do an average measurement values for a sample? Statistical Analysis Tools, Techniques and SPC 1
M MSA 4 - Results of GR&R Study using Range & Average Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
T Counting the Average Times of Alarms in a Process using Minitab Using Minitab Software 5
Q How to determine the average baseline for the following data in SPC Quality Tools, Improvement and Analysis 3
D Rounding Numbers - Adding numbers in Excel - I want the average Excel .xls Spreadsheet Templates and Tools 3
T Bias & Linearity Study - How to calculate the P value for the Average Bias Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
G Product Returns are above average for Labeling Problems Quality Manager and Management Related Issues 4
R GR&R (Gage R&R) - Average Range Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B XbarR or EMWA (Expontionally Weighted Moving Average) or MA Chart - Which to Use Statistical Analysis Tools, Techniques and SPC 6
R What is the Sigma Level of the Average Company? Six Sigma 11
Stijloor Toyota drags down new-vehicle quality average World News 9
P ISO 27001 Controls - Industry average % IEC 27001 - Information Security Management Systems (ISMS) 3
Stijloor The ARMA (Autoregressive Moving Average) Chart Statistical Analysis Tools, Techniques and SPC 6
D Influence of the Coverage Factor - Worksheets based on the Average and Range Method Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
B To IMR or Moving Average chart now that's the question! Statistical Analysis Tools, Techniques and SPC 11
M Inferences from Distribution? (Average per hour/the average pay of the staff) Six Sigma 2
O Average Life Cycle Duration for a large number of medical equipment types Other Medical Device and Orthopedic Related Topics 2
Randy US Average Hourly Employee Cost Career and Occupation Discussions 3
K Calculating Control Limits in Average and Range Charts Statistical Analysis Tools, Techniques and SPC 3
C What does the average employee need to know about the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
B Control Chart - Minimum point & average insulation thickness for Automotive Wires Statistical Analysis Tools, Techniques and SPC 9
DanteCaspian 5S Workplace Average for those that score 5 S Lean in Manufacturing and Service Industries 5
T Monitoring a shift of the average in an SPC chart Statistical Analysis Tools, Techniques and SPC 11
T What is Average Run Length & Average Production Length when used in Control Charts? Statistical Analysis Tools, Techniques and SPC 4
C Is Parts/Process Average Testing SPC by Another Name? Statistical Analysis Tools, Techniques and SPC 3
D Average fill label - "e" Mark, probably a UK specific requirement. Manufacturing and Related Processes 8
D Queuing System - Calculating Average Arrival Rate λ Statistical Analysis Tools, Techniques and SPC 3
W Advice on the best way to approach a double moving average using Minitab 15 Using Minitab Software 3
K Average Salary for Quality Personnel? Career and Occupation Discussions 12
E Moving Range Average Calculation in Excel (in a single cell only). Excel .xls Spreadsheet Templates and Tools 9
S Average Cost of ISO 13485 Registration in US ISO 13485:2016 - Medical Device Quality Management Systems 10
D How to Measure a Diameter - Average or Maximum/Minimum? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 25
