What is the best Electronic Document Control Management System?
szohar
#32
Re: What is the best Document Control Management System?
FYI: We ended up scrapping the SharePoint system that a third-party vendor built for us (long story, not shareable, don't ask), and we built our own system in-house, and it is working out *very* well - that project plus a few other major efforts have kept me away from this forum for quite a while, albeit for very happy reasons. Please note that our success was predicated on a few pre-existing conditions that many organizations might not share:
1. We already run most of our operations using an internal software package that is task-based and primarily role-based, so adding a new module that needed role-based tasking for approvals did not require setting up a new task-management process from scratch. Our operating software has an unusually flexible architecture in general (compared to most other organizational task-based software I've worked with in my twenty-mumble years of IT experience), so it is significantly easier to add different functional modules than it would be in many organizations.
2. We had recently developed our own internal electronic signature process within that operational software for reasons unrelated to EDCMS, so we were able to take advantage of that new functionality as well. We did not have the electronic signature process in place at the time we started getting serious about setting up an EDCMS, which factored strongly into our initial decision to go with an external solution.
3. We have a skilled and dedicated IT development team, thought it is small. A lot of organizations our size looking for an EDCMS do not have dedicated IT development resources.
L
LLIMA
#33
Does anyone knos such kind of Electronic Document Control Management System (EDCMS) in open source?
regards
Laerte Lima
David Hartman
#34
My requirements include (thanks to Wes post from awhile ago).
- easy search and retrieval (documents opening in a viewer, not the native application, documents include drawings, 3d models, flow chart, power points, word and excel documents, pictures)
- audit trial on revision and status
- workflow for approval
- group printing of documents
- multiple security levels
- security level setting for each document
- access to documents for web users (suppliers, customer and employees while traveling).
- reporting feature showing "workflow" status of documents.
In one company I worked for we used the company's intranet with a protected/dedicated drive and limited access folders for work in process, released, and archived documents. The documents themselves were created in either Word or Excel (which may have included some flowcharts from RFFlow). Work in process documents were maintained in their native format, Released documents were in .pdf format - as were the archived documents. The approval workflow was defined by title on the documents themselves, and all approval routing was via Outlook using voting buttons (copies of the emails and voting results were maintained in a folder by the document coordinator). Revisions to documents were highlighted within the document itself where applicable and noted in the Revision History maintained at the end of each document. A Master Index was maintained in the released documents folder listing the applicable revision and/or approval date and listed each document as a hyperlink to the applicable released document. All new or revised documents emailed for review contained a "Draft" header and no revision/release date.
Dubai_capi
#36
what about oracle-based forms and applications, how do we control them? we some time request the IT to change a form.. we do have document control procedure but we didint include these oracle based forms since they are integrated in the oracle system and thought the document control doesnt apply to it? am i right?
pls help.. we use the oracle system for our accounting processes and we barely use manual forms..everything is computeriesd..
szohar
#37
Dubai_capi:
Your post brings up a few questions, actually.
The first question becomes, what documents do you control? Every organization has to make that determination based upon that organization's operations and scope.
As an example, I work for a medical non-profit. Documents that are used directly in medical processes, or that are used in IT applications that support our medical processes, must be tracked in our controlled document system. Other documents do not have to be within that system, but we do keep a few other documents in the system because they are in general use.
Look at each Oracle form. Look at your organization's rules for which documents must be controlled. If any Oracle forms meet the criteria for mandatory inclusion in the controlled document system, then they must be included.
If your organization keeps other documents in the controlled system that do not fall within the criteria for mandatory inclusion, then you need to determine whether any of your Oracle forms are comparable to those other documents, and whether there is a strong justification for controlling any of those Oracle forms.
Until you have figured that much out, the question of HOW you control such documents is irrelevant.
If you do determine that at least one Oracle-based form must be controlled, THEN you need to figure out how to do so, and that's when you ask the question of how to control Oracle-based forms. I know nothing about Oracle-based form control - maybe other folks in this forum can address that question.
As far as controlling Oracle applications, that's a different story. You may need to control them - in fact, you probably should - but application and software control is usually handled very differently than document control, and that's also an area outside my expertise. In fact, you may be better off asking that question in a completely separate discussion.
martincrow
#38
The basic Document Control Management System comes according to two criteria.
The first one is a software alone,which provide management of files in electronic format.
The second one is the Imaging System,which convert the paper document into the electronic format.
KIDDO
#39
We are an automotive manufacturing company with a total of (5) sites, some registered to ISO 9001:2008 and others TS-16949. We have been using Q-Pulse now for a few years and it is user friendly and easy to maintain. We have never had any issues with document/record control. It includes modules for CAPA, Audits, Training, Suppliers and Analysis.
I am in no way associated with Gael (the company who provides the software).
Good luck!
Kiddo
R The best brand of Electronic Height Gage Calibration and Metrology Software and Hardware 5
S Best way to control blueprints? Electronic or paper? Document Control Systems, Procedures, Forms and Templates 1
P DFMEA - Machinery Design Best Practices FMEA and Control Plans 0
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
William55401 Distributed By Product - Best Practices for Configuration Management and Purchasing Controls ISO 13485:2016 - Medical Device Quality Management Systems 0
P Best european location to set up for a virtual medical device manufacturer? EU Medical Device Regulations 4
optomist1 Best Optical Comparators General Measurement Device and Calibration Topics 9
qualprod Best practice to ensure inputting of data in production Lean in Manufacturing and Service Industries 19
M Best profilometer for the money General Measurement Device and Calibration Topics 22
P Best Global Option to become an OBL/PLM/Virtual medical device brand in 2020 Other Medical Device Regulations World-Wide 2
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
S What is the best method to bond urethane foam to urethane foam? Manufacturing and Related Processes 4
Watchcat Best Regulatory Oversight for Off-Shore Device Manufacturing? Other Medical Device Regulations World-Wide 1
E Best way to keep up with pharmaceutical quality knowledge and current affairs Service Industry Specific Topics 1
K Best Measurement Systems Demos in California? General Measurement Device and Calibration Topics 1
qualprod Best approach to get a real value as average? Statistical Analysis Tools, Techniques and SPC 6
CPhelan Best metrics for monitoring low volume (<1000) parts per vendors Supply Chain Security Management Systems 1
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
I What kind of wine best complements the Friday that you close out your external audit findings? Opinions are welcome. Coffee Break and Water Cooler Discussions 12
I Non-Conformance vs OFI -- your best descriptions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 61
A What are Practical data center best practices IEC 27001 - Information Security Management Systems (ISMS) 1
G Best Practices for IT auditing - Is a session-id necessary for a complete audit trail? IEC 27001 - Information Security Management Systems (ISMS) 0
S Best software for customer support/complaints? Customer Complaints 0
R Bill of Materials for a complex product - Industry best practice ISO 13485:2016 - Medical Device Quality Management Systems 2
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
D What is the best software used for the pharma compliance management? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M Informational MHRA launches consultation on how to best engage patients and the public Medical Device and FDA Regulations and Standards News 0
optomist1 Mobility Field Manufacturing Best - Worst Practices Manufacturing and Related Processes 5
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
N Best practices for capturing audit objective evidence in a practical manner? Internal Auditing 3
S How to Learn all aspects of ISO 27001:2013 | The best way to grab the knowledge on 27001:2013 (Step by Step) IEC 27001 - Information Security Management Systems (ISMS) 7
I Best visual description for SOPs? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
Z Best Practices - small volume medical device tube cutting (0.020" to 0.080" OD)? Manufacturing and Related Processes 3
M Over-labelling - Any requirements or best-practices? Other Medical Device Regulations World-Wide 0
M Informational DITTA White Paper on Cybersecurity: Best Practices in the Medical Technology Manufacturing Environment Medical Device and FDA Regulations and Standards News 0
M Informational BSI – MDR Documentation Submissions Best Practices Guidelines Medical Device and FDA Regulations and Standards News 0
K Which clause would best fit this Nonconformance? (Supplier Related) Internal Auditing 2
P How to have employees buy-in of quality procedures. Best practices? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Expiry date vs. Best Before Date - Reagents ISO 13485:2016 - Medical Device Quality Management Systems 9
C Will anyone please share training material for ISO:13485:2016 for best practices Training - Internal, External, Online and Distance Learning 0
E Best GD&T training - Your suggestions and recommendations please Training - Internal, External, Online and Distance Learning 3
M Best Practice for setting tolerances on a Drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M PCBA Drawing Best Practices IPC Class 3 ISO 13485:2016 - Medical Device Quality Management Systems 1
Ron Rompen Best Practices in CMM Correlation Studies General Measurement Device and Calibration Topics 3
B Best place is to purchase IEC 60417 labels that will pass markings test IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
P Best approach to tackle difficult certifications Career and Occupation Discussions 2
E Best Ways to Close a Project APQP and PPAP 3
S Opinions on the "Best" CMM for High Accuracy Machining General Measurement Device and Calibration Topics 9
C What is the best ISO 22000 template pack to purchase? Food Safety - ISO 22000, HACCP (21 CFR 120) 2
