What is the best method for checking the flatness of a flexible part?
Stymie
Good morning thought I’d throw this out there for every one to chew on.
Proud Liberal
Need a little more information. What tolerance are you trying to check? Also, explain more about the actual part (material, geometry).
Finally, what is the application? Often times, a designer will specify flatness but really has something else in mind. BTW, true flatness is one of the more difficult to actually measure although there are several good approximations that will do the job.
Stymie
Sorry for being vague. The part in question is best described as a extruded rubber about 1.5mm thick, 6mm wide and 29mm long. Flatness of .1mm has been called out on the thickness. As far as the application I’m not sure.The customer’s drawing doesn’t deal with Free- State Variation. If I’m correct the part can’t be restrained in any way to alter its Free-State condition. That is where my problem lies.
[This message has been edited by Stymie (edited 12 December 2000).]
Steven Truchon
Flatness is a geometry that is in reference to itself, thus dependant on itself. If the item in question cannot support itself in a geometrically stable state, then the initial reference cannot be established. Enter restraint conditions. Is restraint feasible? No? What about Datum Targets? No?
If the part cannot be supported to establish the primary plane and then measure deviation from that plane, due to flexibility based on gravity then I submit:
1) You most likely cannot measure flatness on this part. Even the most sophisticated optical technology would fail in reliability because the surface form would be dependant on the form of the part support .
2) Your customer will also not be able to measure flatness on this part as it is defined in geometry.
Have you contacted your customer with this problem? Sometimes a customer will have a method they use, whether correct or incorrect in the ideal sense. If they do, you can match their method, you'll be on the same page and you live happily ever-after.
Short of all that, as much as I despise hearing these words;
If they cant check it, they cant reject it!.
Seriously, I would contact them for clarification. Maybe the part used to be aluminum or..., and they never took that control off the print. Just a thought.
Regards,
Steve
artstauff
Too measure flatness of the tolerance you have specified can be accomplished by a 3 axis video inspection system with Z axis scales and a focus repeatability method. The Flexbar / Optiflex system can provide this capability. While the System is in excess of $20,000.00, some comercial calibration labs, including ours, will perform contract inspection for you. There is a little more to it than just throwing the part on the stage and measuring in the Z axis, you need also a fine leveling plate to fully establish a referance plane, otherwize you are really only measuring parrallelism.
S What is the best method to bond urethane foam to urethane foam? Manufacturing and Related Processes 4
P Best Method of Cleaning of Thread Ring Gages Calibration Frequency (Interval) 5
A Best Method of Auditing an Installation Process at a client job-site ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Best Method of Labeling Shelf Life Containers of Urethanes and Plastics Manufacturing and Related Processes 5
C Best Method for Calibrating Multimeters General Measurement Device and Calibration Topics 8
S Best method for Demonstrating Employee Motivation (6.2.2.4) Compliance IATF 16949 - Automotive Quality Systems Standard 2
S Best wire size for 'three wire method' to measure pitch dia. of asymmetrical thread General Measurement Device and Calibration Topics 2
C 8D Report format and the best and most effective method of report preparation Nonconformance and Corrective Action 1
T What is the Best Method for Wire Insertion? Effective Process Manufacturing and Related Processes 7
M Heat Treat Data - Best method for determining the capability of a carburizing process Statistical Analysis Tools, Techniques and SPC 3
ScottK Disposing of old hard drives - Best method to destroy data? After Work and Weekend Discussion Topics 17
M What is the best method to audit AS9100 clause 7.2.1 and 7.2.2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D Best Gage R&R (GR&R - GRR) Method for Product Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T Best Method and Equipment for Measuring Porosity of Customer Supplied Castings Manufacturing and Related Processes 12
R Is ANOVA Gage R&R the best method? Reproducibility issues (no inspector effect)? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
T Management review - how do you do your meeting? to get best response and involvement? and outputs Quality Manager and Management Related Issues 20
K Best automation presentation software Manufacturing and Related Processes 0
K Best Internal Auditor Training Internal Auditing 18
M When is the Best Time to Initiate PFMEA? ISO 13485:2016 - Medical Device Quality Management Systems 11
S Local (country) registration of medical devices - Who does it in best case? Other Medical Device Regulations World-Wide 2
A Class 2b medical device - best pathway to obtain CE mark? (2022, MDR 2017/745) CE Marking (Conformité Européene) / CB Scheme 2
J Best Practices for Choosing In-process Inspection Dimensions & SPC Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Seeking reference guides/ documentation /tips on verification best practices Other Medical Device Related Standards 6
D Ultra low freezer thermometers, best practices? ISO 13485:2016 - Medical Device Quality Management Systems 8
S Question: Best alternatives to audits for ensuring compliance Quality Tools, Improvement and Analysis 5
PQ Systems Best Practices In Gage Management Using GAGEpack Software 0
Q Best off presentation of process flows Process Maps, Process Mapping and Turtle Diagrams 16
Q Best country to import medical devices into Europe Other Medical Device and Orthopedic Related Topics 0
M Best accreditation body for AS9100D Lead facility auditor? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P DFMEA - Machinery Design Best Practices FMEA and Control Plans 0
G Best way to calc uncert for measuring microscope without duplicating repeatability? Measurement Uncertainty (MU) 2
William55401 Distributed By Product - Best Practices for Configuration Management and Purchasing Controls ISO 13485:2016 - Medical Device Quality Management Systems 0
P Best european location to set up for a virtual medical device manufacturer? EU Medical Device Regulations 4
optomist1 Best Optical Comparators General Measurement Device and Calibration Topics 9
qualprod Best practice to ensure inputting of data in production Lean in Manufacturing and Service Industries 19
M Best profilometer for the money General Measurement Device and Calibration Topics 22
P Best Global Option to become an OBL/PLM/Virtual medical device brand in 2020 Other Medical Device Regulations World-Wide 4
J ISO 13485 System 'soft start' - How to best reflect this in initial audits, management review minutes and other records? ISO 13485:2016 - Medical Device Quality Management Systems 3
Watchcat Best Regulatory Oversight for Off-Shore Device Manufacturing? Other Medical Device Regulations World-Wide 1
E Best way to keep up with pharmaceutical quality knowledge and current affairs Service Industry Specific Topics 1
K Best Measurement Systems Demos in California? General Measurement Device and Calibration Topics 1
qualprod Best approach to get a real value as average? Statistical Analysis Tools, Techniques and SPC 6
CPhelan Best metrics for monitoring low volume (<1000) parts per vendors Supply Chain Security Management Systems 1
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
I What kind of wine best complements the Friday that you close out your external audit findings? Opinions are welcome. Coffee Break and Water Cooler Discussions 12
I Non-Conformance vs OFI -- your best descriptions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 61
A What are Practical data center best practices IEC 27001 - Information Security Management Systems (ISMS) 1
G Best Practices for IT auditing - Is a session-id necessary for a complete audit trail? IEC 27001 - Information Security Management Systems (ISMS) 0
S Best software for customer support/complaints? Customer Complaints 0
