What is the degree of evidence needed to report a nonconfomity?
Stijloor
#11
Re: Degree of evidence
From ISO 9000:2005:
3.8.1
objective evidence
data supporting the existence or verity of something
NOTE Objective evidence may be obtained through observation, measurement, test (3.8.3), or other means.
Jim and Stijloor...:D
Our posts should be sufficient and objective evidence of a clear definition.
John Broomfield
#12
What is the degree of evidence needed to report a nonconfomity? For example, outdated documents available at points of use. Should it be 3 samples of the same kind? or 1 sample of outdated document found will suffice?
Ka Pilo,
Why not ask the people responsible for monitoring their processes per 8.2.3?
You may then discover how permissive the work environment is per 6.4.
You may discover that the procedures and their work instructions specify unnecessary details.
The employees and their leaders should be the first to decide the criteria for success and when correction or corrective action is required per 4.1c and 8.2.3.
Replacing the care of employees and their leaders with auditors making this decision for them, I suggest, is counter to quality.
Quality cannot come from auditing alone.
John
K
Ka Pilo
#13
Ka Pilo,
John
I think the definition of "objective evidence" provided by Jim and Stijloor is equally applicable to both auditors and auditees. It's clear that the objective evidence may be obtained through observation, measurement, test, or other means though the amount of relevant evidence which a reasonable mind "might" accept as adequate to justify a conclusion is subjective.
#14
If an obsolete document has been observed at a point of use, there is no question, or there shouldn't be, whether a nonconformity exists. The existence of the document is the only objective evidence necessary to support the contention. However, if the contention is that the entire document control system has broken down, you'll need more evidence than a single out-of-place obsolete document to support it.
An example of evidence that shouldn't be considered objective is a verbal assertion by an operator that until 20 minutes ago, an obsolete document was being used. This is not something directly observed by the auditor, and as such shouldn't be used as the basis of a nonconformity finding. It might be cause for further investigation.
In internal audits there should be no question of subjectivity, because "major" and "minor" classifications aren't helpful. Either a nonconformity exists or it doesn't, and the need for and extent of corrective action should be left to management.
Marcelo
#15
Being not directly observable does not mean that it's not traceable - verifiable. If you cannot observe something, but can verify the infromation (for example, in records), then you can use those as a basis for a NC.
#16
An anecdotal assertion might be, as I said, a basis for further investigation. That doesn't alter the fact that the assertion itself shouldn't be considered objective evidence. Before a nonconformity statement can stand up, it must be supported by evidence directly observed.
somashekar
#17
Would it mean that a NC statement can begin or end with " As stated by the responsible manager " being the evidence ... ?
Jen Kirley
Quality and Auditing Expert
#18
Would it mean that a NC statement can begin or end with " As stated by the responsible manager" being the evidence ... ?
When attending Lead Auditor training for TS 16949, an auditee's statements were certainly considered evidence and could be included as part of the NC description. We specifically practiced them.
That said, it is helpful to consider that the organization will very likely be interested in tangible evidence so I am disinclined to simply say "So-and-so said such-and-such" as a writeup because people can say anything. They may be mistaken from lack of insight, exaggerating, suffer momentary confusion and so on.
However, in event of a breakdown somewhere an investigation can, and should include testimony as part of the body of evidence.
:2cents:
Stijloor
#19
:2cents:
Yes, statements of fact are considered audit evidence:
From ISO 19011:
3.3
audit evidence
records, statements of fact or other information, which are relevant to the audit criteria (3.2) and verifiable
NOTE Audit evidence may be qualitative or quantitative.
Emphasis mine.
Stijloor.
Marcelo
#20
Not to be picky, Jim, but I do not think that you need to directly observe a finding to use it to report a NC.
The definition of audit evidence from 19011
audit evidence
clearly means that you can have anything as evidence as long as it's relevant to the audit and verifiable.
In fact, I woould say that that's exactly why records where created - so that a system can be audit even if if the auditor does not directly observe something. Records shows that things were done and you simply audit with this supposition.
S Bend allowance formula to calculate per degree per radii Manufacturing and Related Processes 2
J Masters Degree - Advice about a decision I"m going to be making Career and Occupation Discussions 9
S Degree of control of distributors - PMS EU Medical Device Regulations 2
M Anyone know of an on-Line Bachelor's degree that work with Quality Career and Occupation Discussions 3
L KPI Project help - Business and Management Degree Benchmarking 4
M Education - Jobs Requiring a College Degree Career and Occupation Discussions 2
B Degree equivalent to a US Master Degree Career and Occupation Discussions 1
B German university degree Magister Career and Occupation Discussions 3
S Quality as a Career Path with a Management Degree Career and Occupation Discussions 8
C Master's Degree in Quality Management System Professional Certifications and Degrees 10
J Dual degree MSQA - CSU online program (MSQA) and continuing a Masters in Biotech Professional Certifications and Degrees 2
C Who offers Four Year Degree in Quality Management Professional Certifications and Degrees 8
D Correction and Degree of Error - Metrology Definitions and Differences General Measurement Device and Calibration Topics 1
kedarg6500 Bias Study-Finding degree of freedom-P 92 of MSA manual 4th Ed. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
F Any online quality related Associate Degree programs? Professional Certifications and Degrees 2
R Taguchi Design - Degree of freedom for l27 in 4 factors 3 level (Minitab) Using Minitab Software 15
M Quality Career Questions - Degree in Applied Mathematics Career and Occupation Discussions 4
Marc Can an online degree help advance your career? Career and Occupation Discussions 8
S Different statistical software = Difference in Degree of freedom?? Statistical Analysis Tools, Techniques and SPC 3
D Measuring a round edge - Looking for a 20 degree radius gauge General Measurement Device and Calibration Topics 8
C Bachelors Degree in Quality Assurance Science from California National University Professional Certifications and Degrees 4
K The 'Cohen's kappa' method to evaluate degree of consensus between visual operator Six Sigma 9
K Help me find an online degree in English from an accredited college. Training - Internal, External, Online and Distance Learning 2
Stijloor 360 Degree View of the Airbus A380 Flight Deck Travel - Hotels, Motels, Planes and Trains 3
V How is the degree of freedom (v) calculated from the d2* table Measurement Uncertainty (MU) 2
S ISO 9001:2000 Questionnaire Survey - Working on Masters degree ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
J The European Engineer professional title E.U ENG Degree by Feani Book, Video, Blog and Web Site Reviews and Recommendations 1
P How to convert angle measurement given in degree to degree/Minutes/Seconds? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P MSQA Online Degree - Does anyone know any other QA Online programs? Professional Certifications and Degrees 4
samer Quality Management online courses and degree - Master Degree - Is it valuable? Training - Internal, External, Online and Distance Learning 7
D Distance Education Question. (Online Degree) Training - Internal, External, Online and Distance Learning 5
T Nondegreed Quality Manager - Most companies want a QM with a 4 year degree Career and Occupation Discussions 32
T Online Master Degree in TQM - Any good university reviews or recommendations? Professional Certifications and Degrees 3
A IS a Master's degree a must in today's job market? Professional Certifications and Degrees 12
L Environmental Management (M.Sc degree) Career advice needed: Auditor Career and Occupation Discussions 6
G Steel 90 Degree Angle Block Calibration General Measurement Device and Calibration Topics 7
M ISO9000 certification in education - Higher end post graduate degree school ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Distance Learning where I would be able to obtain a 4 year degree in Quality? Training - Internal, External, Online and Distance Learning 7
D Capability, FMEA and PPAP - 4.9.2 - The meaning of "high degree of capability" Statistical Analysis Tools, Techniques and SPC 8
A 8.6 Release of products and services, 8.3 Design and development - evidence required ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C Where to draw the line for "sufficient evidence" to verify safety/performance of a device? CE Marking (Conformité Européene) / CB Scheme 2
D Device functionality over service life - Objective evidence required? Design and Development of Products and Processes 10
C MDCG 2020-06 Clinical evidence legacy devices EU Medical Device Regulations 3
Mr Roo ISO 9001 - 7.1.3 Infrastructure - questions concerning evidence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
M Informational Critical Thinking and the Process of Evidence-Based Practice Medical Device and FDA Regulations and Standards News 0
M Informational How to perform a clinical evaluation of medical devices – Part 2 – Level of clinical evidence and what sufficient clinical evidence means Medical Device and FDA Regulations and Standards News 9
M Informational US FDA paper – Epidemiological Evidence on the Adverse Health Effects Reports in Relation to Mercury from Dental Amalgam: Systematic Literature Review Medical Device and FDA Regulations and Standards News 0
S Level of Clinical Evidence - MDR EU Medical Device Regulations 3
qualprod Evidence of a talk or phone call in approvals? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
H Clinical evidence for Class II medical devices in EU and US EU Medical Device Regulations 6
