I am herewith listing out the processes...
Product Development - supplier qualification and procurement - process validation - warehouse/material management - manufacturing&facility controls - quality control - quality assurance ;
Each of the above area are in-turn supported by individual procedures. (viz., QA includes, change control, incidents, complaints, ...)
Business development, Marketing, Distribution and others are not directly under purview of QMS but they are all compliant with relevant regulations.
I think,Following document enlists the equivalence of ISO & GMPs.
http://www.fda.gov/downloads/Drugs/GuidanceComplianceRegulatoryInformation/Guidances/ucm070337.pdf
V,
Thinking that your management system conforms to ISO 9001 because it complies with cGMP may be part of the problem. CAPA for example is completely at odds with Preventive Action in clause 8.5.3 of ISO 9001.
For your quality system to be fast and agile you need to develop, use and improve your company's process-based management system so conforms to ISO 9001 including your speed and agility criteria included in 4.1c and 4.1d.
Then, by your company's use, monitoring and optimization of its system. it will determine and fulfill requirements including compliance with the regulations.
Your plan (to move from a quality system built around the regulations to a management system that is designed to be fast and agile) must protect the integrity of the system as it is changed.
Tips:
Agree upon the speed and agility objectives with top management as part of the other company objectives.
You could then used these speed and agility criteria to drive incremental improvements of your system and its processes over the next decade.
Or, you could go for a faster change by making sure your management system is process-based and conforms to ISO 9001:
Work with top management to analyze and document what your company does with its customers, suppliers and regulators to convert the needs of customers into cash in the bank. This is the value stream or core process.
Determine the key processes (including the processes necessary to sustain the core process) and work with top management to assign subject matter experts as process owners (one per process).
Brief/train the process owners on the planned changes to fulfill the approved objectives including the speed and agility criteria.
With each process owner analyze and document process as it is (search the Cove for the
SIPOC approach).
Use and improve your updated process-based management system to fulfill the speed and agility criteria while preventing nonconformity and fulfilling the other requirements including compliance with the regs.
Please note that I would recommend using a process-based management system to secure the changes in your organization (system) that you want.
Good luck,
John
BTW, I do not see quality control and quality assurance as processes.
These days QC is part of process control (ASQC was several years late in dropping the C).
For more than a decade, QA is a result of working systematically to prevent nonconformity thereby delivering confidence that requirements
will be fulfilled.
In other words QA is a product delivered by the system not a fancy name for inspection.
