What is the difference between Process Variation and Tolerance?
jeopie
What is the difference between process variation and tolerance?
and what recommendation is there if a supplier submits a report and the process variation is in the 10-30% range but the tolerance is less than 10%?
Ron Rompen
Process variation is the observed difference from part-to-part which is caused by the limitations of the tooling, equipment, fixturing, etc.
Tolerance is the maximum allowed variation from the target dimension, which you are allowed per the customer print/specifications/requirements.
John Predmore
What Ron R said is true.
Any time you measure parts, the data you collect include a bit of imprecision due to measurement variation. If your measurement system does not have adequate repeatability, you can’t be sure of what you are seeing in your process.
Using a designed experiment and assuming the parts themselves do not change between measurements, it is possible to statistically decompose the total observed variation into component portions. It is common in a Gage Repeatability & Reproducibility study (GR&R) to summarize what percent of the total observed variation is attributed to the parts, the operators and the (measurement) equipment. By consensus, the appraisal percentage (the repeatability of the “gage” and the reproducibility of the operators) should be less than 30% of the total. Your supplier is in that range.
When your measuring device is used for inspection, sometimes measurement variation is quantified relative to the total tolerance rather than process variation from the study.
When you wrote the supplier’s report shows “tolerance less than 10%”, I think you meant to say the portion which is measurement variability is <10% of the total tolerance. That would be a great result.
bobdoering
Stop X-bar/R Madness!!
The correct answer is: It depends.
If the gage is used to determine if the part is "good" or "bad", then you look at the %Tolerance value. In this case, no action is required.
If the gage is used to determine if the process needs adjustment, then you look at the %Process Variation value. In this case, there may be an opportunity for improvement.
If the %Process Variation is a better value than %Tolerance, then a close look at the part values used to represent the process is needed. Generally a sound study will have the %process variation greater than the %Tolerance.
S What is the difference between Process Capability and Machine Capabilty Capability, Accuracy and Stability - Processes, Machines, etc. 13
T What is the difference between Supplier and Outsourced Process? Supplier Quality Assurance and other Supplier Issues 8
T Difference between the terms Function & Process when used in Construction Management Business Continuity & Resiliency Planning (BCRP) 12
B What is the difference between Process and Compliance Audit? Internal Auditing 21
J Difference between Outsourced Process and Support Service? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V What is the difference between a System and a Process? US Food and Drug Administration (FDA) 30
H What is the difference between Process Variation and Product Tolerance for GR&R? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
A What is the difference between Process Objectives & Criteria for Effectiveness? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
R What's the difference between Engineering (ECN) and Process (PCN) Change Notes? FMEA and Control Plans 4
M The Difference between Process Audits and Layered Audits General Auditing Discussions 5
N What is the difference between Process, Procedure and Work Instructions Document Control Systems, Procedures, Forms and Templates 2
D Difference between Process Verification vs. Process Validation in APQP? APQP and PPAP 4
H Clarify the Difference between Activity and Process - What is Data Analysis IATF 16949 - Automotive Quality Systems Standard 9
S Difference between SPC (process control) and SQC (quality control) Statistical Analysis Tools, Techniques and SPC 12
S What is the difference between the quality process and quality procedure? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
D TS 16949 - Is there a difference between a process and an activity? IATF 16949 - Automotive Quality Systems Standard 5
M What is the difference between process documents vs. Work Instructions? Document Control Systems, Procedures, Forms and Templates 2
R What's the difference between using PPM or Defect Rate in a process? Quality Tools, Improvement and Analysis 1
I How to understand the difference between 7.2.1,7.2.2 and 7.3.3 from 13485 ISO 13485:2016 - Medical Device Quality Management Systems 3
A The difference between ANOVA and Xbar-R studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
X Difference between the Figure J.6 and J.7 insulation examples IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
W Difference between Appliances and Parts according EASA EASA and JAA Aviation Standards and Requirements 0
A Difference between general PMCF and PMS EU Medical Device Regulations 3
FoGia Difference between "misuse" and "off-label use" EU Medical Device Regulations 12
placebo_master What is the difference between "Fitness for Purpose" and "Calibration/Verification"? General Measurement Device and Calibration Topics 6
C Need to understand difference between an actual Calibration vs. a Calibration check General Measurement Device and Calibration Topics 3
H API monogram 4F, The difference between PSL-1 & PSL-2 Oil and Gas Industry Standards and Regulations 5
G What's the difference between 1.32 and 1.33 Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 18
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
D Difference between Test Method Validation and Gage R&R Qualification and Validation (including 21 CFR Part 11) 20
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
