What is the difference between service parts and production parts?
P
pinpin - 2009
Dear Covers, please teach me the difference with examples, THANK YOU...:thanks::thanx:
Stijloor
PinPin,
Production parts are used to build new automobiles.
Service parts are produced for aftermarket purposes and are used by repair centers, dealerships, etc.
Stijloor.
P
pinpin - 2009
Dear Stijloor,
Manufacturers that reconditioned parts that have been used from vehicles qualify to apply for TS certification?
If a manufacturer making service parts (and supply to normal private car repair/service workhops that not belong to real car manufacturer) that were not authorised by any car manufacturers, can this manufacturer apply for TS certification?
I heard that the manufacturer must make parts that are to supply to a car manufacturer that is a member of IATF or subscribed (what this mean?) to TS Standard, can then apply for TS certification, is it correct?
THANK YOU ! :thanks::thanx:
pinpin:magic:
Stijloor
Dear Stijloor,
No, not unless their customer requires it. I see that as very unlikely.
No, not very likely.
Yes, subscribers to ISO/TS 16949:2002, require their suppliers to be certified to this standard.
IATF (Vehicle Manufacturers) Members are:
  • BMW Group
  • Chrysler LLC
  • Daimler AG,
  • Fiat Group Automobiles
  • Ford Motor Company
  • General Motors Corporation (including Opel Vauxhall)
  • PSA Peugeot-Citroen
  • Renault
  • Volkswagen AG
A "subscriber" may be a manufacturer of: Truck, bus and motorcycle.
An example of a "subscriber" could be Volvo Truck.
Hope this helps.
pinpin:magic:
You're very welcome.
Stijloor.
P
pinpin - 2009
Dear Stijloor,
That means a factory supplying to vehicle manufacturers that do not subscribe to TS cannot apply to TS certification ?
Toyota and Honda were not listed, that means being thier subcontractor cannot certify to TS?
pinpin:thanks::thanx::magic:
Stijloor
Dear Stijloor,
It starts with the customer. If you have an automotive customer that does not require ISO/TS (Honda, Toyota and others), why should an automotive supplier organization pursue ISO/TS certification?
Toyota and Honda were not listed, that means being their subcontractor cannot certify to TS?
They can if they have other automotive customers that would require ISO/TS certification. I have clients that supply to a wide variety of automotive customers. Some of their customers do not require ISO/TS. But because others do, they decided to become ISO/TS certified. Please keep in mind that ISO/TS certification is initiated with a requirement by the customer.
You're welcome!
Stijloor.
P
pinpin - 2009
Yes, you are right!:agree1:
THANK YOU STIJLOOR, A MILLION THANKS TO YOU !!!
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
U The difference between ?Aircraft Return to Service? and ?Aircraft Airworthiness" Federal Aviation Administration (FAA) Standards and Requirements 3
J Difference between Outsourced Process and Support Service? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Difference between Customer Complaint and Service Call as in ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 9
I How to understand the difference between 7.2.1,7.2.2 and 7.3.3 from 13485 ISO 13485:2016 - Medical Device Quality Management Systems 3
A The difference between ANOVA and Xbar-R studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
X Difference between the Figure J.6 and J.7 insulation examples IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
W Difference between Appliances and Parts according EASA EASA and JAA Aviation Standards and Requirements 0
A Difference between general PMCF and PMS EU Medical Device Regulations 3
FoGia Difference between "misuse" and "off-label use" EU Medical Device Regulations 12
placebo_master What is the difference between "Fitness for Purpose" and "Calibration/Verification"? General Measurement Device and Calibration Topics 6
C Need to understand difference between an actual Calibration vs. a Calibration check General Measurement Device and Calibration Topics 3
H API monogram 4F, The difference between PSL-1 & PSL-2 Oil and Gas Industry Standards and Regulations 5
G What's the difference between 1.32 and 1.33 Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 18
W What is the difference between TYPE B and TYPE BF? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Terminal Lugs sizes - Difference between 225/24 vs. 275/24 lugs Manufacturing and Related Processes 2
M Difference between "Production Trial Run" and "Run at Rate" IATF 16949 - Automotive Quality Systems Standard 8
D Difference between Test Method Validation and Gage R&R Qualification and Validation (including 21 CFR Part 11) 20
T Difference between a subcontractor and a supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
H Difference between Stainless Steel 316 ASTM F899 and ASTM A276 Other Medical Device Related Standards 3
A Exact terms for a plating failure and difference between rejection rate and failure rate Manufacturing and Related Processes 9
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
JoCam Difference between Approval and Registration - ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S Difference between EU-MDR Annex IX and the Annex-combo X&XI EU Medical Device Regulations 4
C IEC 60601-1-8, difference between table 4 and annex D IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
A What is the difference between Basic UDI-DI and UDI-DI? EU Medical Device Regulations 6
Q What is the difference between AS9100D 9.3.2.f and 9.3.3.a AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Aluminum - What is the difference between 6061-T6 and 6061-T651 (both per ASTM B211)? Manufacturing and Related Processes 4
P What is the exact difference between Risk and Opportunity in context of ISO 27001? IEC 27001 - Information Security Management Systems (ISMS) 7
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
O Air Flow - Which is the operational difference between LAF (vertical and horizontal) and RLAF? Manufacturing and Related Processes 2
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
TarKEpa The difference between SOP and Kaizen Standardization Lean in Manufacturing and Service Industries 2
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
S Difference between an Advisory Notice (ISO 13485) and a Field Safety Notice? ISO 13485:2016 - Medical Device Quality Management Systems 3
T Difference between "data analysis" and "management review" ISO 13485:2016 - Medical Device Quality Management Systems 4
qualprod What is the difference between 7.4.1 (2008) and 8.4.1 (2015)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S EASA Part 145 - The difference between non-certifying staff and Certifying staff Federal Aviation Administration (FAA) Standards and Requirements 2
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
