I was going through 8.4.2 of the AS9100D standard and found the following new requirements:
1) New requirement: Verification activities of externally provided processes, products and services shall be performed according to the risks identified by the organization. These shall include inspection or periodic testing, as applicable, when there is a high risk of nonconformities including counterfeit parts.
2) When external provider test reports are utilized to verify externally provided products, the organization shall implement a process to evaluate the data in the test reports to confirm that the product meets requirements. When a customer or organization has identified raw material as a significant operational risk (e.g. critical item), the organization shall implement a process to validate the accuracy of test reports.
3) When the organization delegates verification activities to the external provider, the scope and requirements for delegation shall be defined…..
My questions:
Point 1 and 2 above :
What is the difference between verification and validation of test reports? – Does it mean that verification is going through the test reports, UT, C of C etc and stamping them as verified? And does validation means that my organization should send out a sample of the material that has already been verified by its Raw material supplier to a lab for testing again?
Point 1 : What does periodic testing mean? Our raw material which comes in batches with heat lot number and are always accompanied by test reports, C of C tensile test, hardness test, UT reports.
Point 3: What is “ scope” in point 3 above?
What has changed in 8.4.2 from the old 7.4.3?
My questions:
