What is the easiest way to verify we have the correct customer supplied materials?
NikkiQSM
Hello Covers -
We recently ran into a problem. A customer of ours supplied materials for us to use to compound some plastic.
They supplied us with two types of an ingredient. We used both. But the product specification only stated one type to be used.
Right now we do not have a good process for verifying customer supplied materials. For the materials we purchase, we can compare the packing slips to the Purchase Order. But there is not purchase order for customer supplied materials.
What would be an easy method to verify the materials?
Thanks!~
silentrunning
Re: What is the easiest way to verify we have the correct customer supplied materials
Nikki, are you getting the material from a producer, distributor or is it coming straight from the customer with no traceability?
NikkiQSM
Straight from the customer with very limited documentation. Sometimes we get lucky and get a COA - but thats about it.
Ninja
Looking for Reality
I run into this as well...customers make some of the worst vendors...and you can't really find another source or issue a CAR. Can you imagine doing a supplier quality audit on your customer?
Sounds good on paper, but it doesn't really work with the real people.
We talk about this with upper management at the customer, preferably at the outset of such a relationship, and have them define the procedure to be used for verification. When they simply say "use your normal vendor procedures" we push back and ask which member of upper management should join us for audits...then the discussion tends to move more into realistic scenarios.
Most of the folks I've dealt with understand that they aren't perfect either.
Long and short, involve your customer...not your vendor...even if they are the same organization. Treating them like a vendor can have very bad effects on the customer relationship.
W
Wilderness Woody
Right now we do not have a good process for verifying customer supplied materials. ~
I would suggest that even with "customer supplied material", there still needs to be good documentation and planning. If your plan called for only ONE TYPE, then a flag should have been raised when TWO TYPES were supplied for use.
Process planning and documentation should be sufficiently defined to ensure the requirements are met. Incoming identification of materials is still important and there should be appropriate package identification, packing slips, C of A or C of C as needed. There is no excuse for skipping information like this... training your customer to be part of the team is always key! :agree1:
John Broomfield
Hello Covers -
Thanks!~
Nikki,
When forming the contract with each customer, ensure that the responsibilities for traceability and verification of customer supplied product are specified.
Update the contract review part of your selling process to ensure this is done.
Bring the sales team up to speed on the necessity of doing this proactively and seek their inputs to the procedure so they can continue to build and maintain excellent relationships with your customers.
John
T Customer rejected MDS - easiest resolution? RoHS, REACH, ELV, IMDS and Restricted Substances 1
K What is the easiest way to certificate new navigation equipment? by ETSO? EASA and JAA Aviation Standards and Requirements 2
T The world's easiest quiz Coffee Break and Water Cooler Discussions 15
qualprod D5 of 8D clarification, how to verify root cause Problem Solving, Root Cause Fault and Failure Analysis 24
C Where to draw the line for "sufficient evidence" to verify safety/performance of a device? CE Marking (Conformité Européene) / CB Scheme 2
K Verify Software Architecture - supporting interfaces between items IEC 62304 - Medical Device Software Life Cycle Processes 2
M How to verify profile gages provided by customer General Measurement Device and Calibration Topics 5
E Layouts : Can you "verify" things that are not visible (such as loctite present, internal dimensions) in a layout ? APQP and PPAP 2
K How to verify the Storage and Transport environmental condition for Medical Device Miscellaneous Environmental Standards and EMS Related Discussions 3
J How to verify the actual capacity of suppliers Supplier Quality Assurance and other Supplier Issues 3
V Regrinding Material - Verify whether a product contains any regrinding material Manufacturing and Related Processes 13
Q Using Caliper A to verify Caliper B - Verification of Calibration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Tie-wrap pull test to verify contact retention Manufacturing and Related Processes 6
D How to Calibrate and Verify a Heating Oven General Measurement Device and Calibration Topics 3
A How to Verify Supplier I-9 Forms for ITAR Requirements Other ISO and International Standards and European Regulations 2
O Creating a Tool to Track & Verify Mistake Proofing Devices Document Control Systems, Procedures, Forms and Templates 5
R IEC 62304 - 5.2.9 Verify Software Requirement IEC 62304 - Medical Device Software Life Cycle Processes 5
B Verify GB/T 16886 is the same as ISO 10993 US Food and Drug Administration (FDA) 5
A How to verify and validate the effectiveness of CAPA with regards to employees ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
R IEC 62304 Section 5.3.6 Verify Software Architecture IEC 62304 - Medical Device Software Life Cycle Processes 4
R LKV Value: Can not verify Reliasoft Case Study Reliability Analysis - Predictions, Testing and Standards 2
S Verify Software System Testing: Verify that results meet the Pass/Fail Criteria IEC 62304 - Medical Device Software Life Cycle Processes 1
L Gauge to test and verify a Set Square Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D What to verify on Test Setup for Environmental Testing General Measurement Device and Calibration Topics 7
A When to verify and when to validate Design Changes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D Since NIST # can not be used to verify Traceability - What an Auditor should do AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
C I need to verify the surface profile of a part - Sine plates General Measurement Device and Calibration Topics 4
W How to verify/calibrate a Neptune Water Meter General Measurement Device and Calibration Topics 4
optomist1 CMM Shortcomings - GD&T - Inability of CMMs to verify the MMC situation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C How to Calibrate and Verify Torque Multiplier Gages General Measurement Device and Calibration Topics 6
J How do I continually Verify Compliance to my Processes? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R A way to verify 7075 T0 Aluminum has been successfully Heat Treated to T6 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Ron Rompen Recommended Rockwell 30T Scale Hardness Tester to verify Incoming Product General Measurement Device and Calibration Topics 1
D How to verify a process that uses software to accomplish certain tasks? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
X Cannot Verify until Customer uses Product - Clause 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Surface Plate Calibration - How to verify the flatness of a granite surface plate General Measurement Device and Calibration Topics 1
E How Do You VERIFY Customer Property? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
R Verify Accuracy for Validation of CNC Starrett Vision System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
L Verify, Inc. Source Inspection experience? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
H Definition Inspect, Review, Verify and Witness - What are the definitions and differences? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
B How to inspect Mylars to verify dimensions, grid lines and grid points Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
D How do I verify the Cold Room temperature in Restaurant Kitchen Food Safety - ISO 22000, HACCP (21 CFR 120) 7
C Bridgeport Mill as a Gage - Verify gage dimensions using a Bridgeport Mill Measurement Uncertainty (MU) 4
A Test Method - DIN ISO 1133 for melt flow needed to verify supplier results Manufacturing and Related Processes 1
F How would you Verify Repeatability and Reproducibility of Measurement Systems? Quality Tools, Improvement and Analysis 5
S How to Calibrate or Verify Screw Pitch Gages General Measurement Device and Calibration Topics 16
J Work Instruction to Calibrate or Verify a Combination Square General Measurement Device and Calibration Topics 15
H Hygrometer Calibration - Best way to verify accuracy of a 'reference' Hygrometer? General Measurement Device and Calibration Topics 11
C How to verify the SAL (sterilie acceptable level) is 10-6 for ETO Sterilization ISO 13485:2016 - Medical Device Quality Management Systems 6
K Could someone verify the levels of quality management system standards Misc. Quality Assurance and Business Systems Related Topics 2
