What is the expectation for Biocompatibility Testing when switching Suppliers?
rwend07
What is the expectation for biocompatibility testing when switching suppliers? If you switch suppliers of a silicone component (Class VI --> Class VI) that was part of a biocomp test, would it be expected to re-do the testing to verify that the newly sourced component meets previous test results? This would seem like an extremely costly requirement if testing needed to be re-done for every change in material.
JeantheBigone
Because FDA generally wants to see testing on final finished product, my initial reaction is that if the manufacturing process is not identical, meaning the exact same raw material from the exact same source is used to produce the exact same component using the exact same equipment, you'll need new biocompatibility testing.
However, in making changes of any kind to a device,it's about performing a risk analysis. What does the original 10993-1 say? Was biocompatibility testing required and why? In other words, I would start with ISO 10993-1.
You may also wish to consult
http://www.fda.gov/ucm/groups/fdagov-public/@fdagov-meddev-gen/documents/document/ucm514771.pdf
rwend07
Thank you both for the responses. Interestingly, after re-reviewing the "When to submit 510(k)" guidance, it appears to point towards not needing to re-do the assessment if a risk analysis determines there is no new concern for biocompatibility. See C4 below:
"The answer to C4 may be no if a knowledgeable individual reviews the differences in chemical composition or physical properties and determines that the change is minor enough that there is no new concern about biocompatibility"
If there is no additive difference between the two suppliers and the material is Class VI at both, I would argue the new supplier does not raise any new concern about biocompatibility. Am I reading this wrong?
Marcelo
Please note that the document "Deciding When to Submit a 510(k) for a Change to an Existing Device"is focused on the need to submit a new 510k (as per the name), not if a new/revised biological evaluation is needed. The need for a new/revised biological evaluation is discussed on the three documents I mentioned.
JeantheBigone
I hope I didn't confuse anyone with the link to the Guidance Document for when to submit a new 510(k). My point was that if you want to be very cautious, you may wish to review that document and confirm that no new 510(k) is needed.
rwend07
I understood your use in including the document. I still feel like the statement I included implies that a risk assessment could conclude that no new biocompatibility testing would be needed for a 1:1 supplier change, and I haven't seen anything in 10993 or its FDA guidance that directly says that a change in supplier = new biocomp testing. For example, from the FDA guidance on 10993:
"Another common change that might impact biocompatibility is a change in resin supplier. For example, if the new resin supplier does not remove all processing solvents (some of which may be known toxic compounds, such as formaldehyde), the final manufactured device could cause unexpected toxicities (e.g., cytotoxicity, irritation, sensitization, genotoxicity) that were not seen with devices manufactured from the original resin."
Key word being "might". If both suppliers have a USP Class VI cert, wouldn't that imply that any toxic compounds left over after manufacture are equivalent and would not be expected to cause a change in toxicities? Also, couldn't you verify through a master file that there are not any differences in processing solvents that would cause new concerns for biocompatiblity?
Thanks again for both your help on this. I know that generally it has been standard to re-do biocomp testing, but I haven't seen a direct link to anything that says it is necessary even if there is a valid risk assessment that states there are no new questions of toxicities. Working with startups, re-doing biocompatibility testing can be 100% cost prohibitive to a simple 1:1 supply switch so it is quite frustrating that it is expected.
Marcelo
As I mentioned before, testing is an output of the biological evaluation process per ISO 10993. You might not need testing if you conclude that testing is not needed after applying the biological evaluation process together with the risk management process as per ISO 10993-1.
This is a questions that needs to be evaluated during the biological evaluation. Also, you don't "imply" things, you conclude after an analysis.
Because a lot of people don't understand/use erroneously the biological evaluation process of ISO 10993. People take a look at the table in Annex 1 and concludes that testing needs to be done. The current version of the standard was written explicitly to make it clear that the table is the output of the analysis, so you "might"need to test/retest depending on the analysis, not the other way around.
Ronen E
Problem Solver
Moderator
Good discussion!
Sorry for coming late to the party, but I think I can make the two ends meet...
The best / most qualified way to run the biological risk evaluation process as per 10993 (in non-trivial cases) is with the support of a qualified and experienced toxicologist. The accredited test houses always have them on board, so although not cheap I would recommend engaging with such a test house for that purpose. That doesn't necessarily mean any testing will have to be done. If indeed the analysis output will be no-testing, this route will cost just a fraction of the typical biocomp testing engagement.
I believe that the "knowledgeable individual" that the guidance referred to was that toxicologist...
The analysis may include examination of master files (if available - not so easy to get formulation info from suppliers) and other documentation, and/or "equivalence testing" which is aimed at showing that the materials from the 2 different sources are equivalent from a biological reaction perspective. Such testing is usually simpler, cheaper and quicker than the full-blast biocomp test set (if required).
To wrap up: I agree that the starting point is re-evaluating according to 10993 & FDA guidance. I also agree that it may well end up in a paper risk evaluation. The important bit is to get a qualified and experienced toxicologist involved in that evaluation, so as to give it validity and hopefully reduce actual re-testing to the minimum.
Side note: USP class VI (and that entire classification, for that matter) is outdated in the context of biological evaluation for medical devices. It was phased out when the FDA endorsed ISO 10993, years and years ago. I'm not sure why it stayed around for so long, but it seems to occasionally show up when medical devices design is being discussed.
Marcelo
Yes, it is a toxicologist. And you got the point, that's in fact a big part of the problem, because usually manufacturers do not have a toxicologist on board and do no contract one to do the biological evaluation.
Sidney Vianna IATF 16949 News Presentations from the latest IATF Stakeholder Event - Expectation that IATF 16949 certification should equate with product quality. Misguided? IATF 16949 - Automotive Quality Systems Standard 7
M FDA's expectation for validating OTS software updates Other US Medical Device Regulations 8
M Is there an expectation to meet harmonised standards of the Machinery Directive? EU Medical Device Regulations 7
S FDA expectation of Concessions - Changes to a DMR ISO 13485:2016 - Medical Device Quality Management Systems 10
A What is the expectation of Lean manufacturing plans in Visteon specific requirements Customer and Company Specific Requirements 0
Judy Abbott Biocompatibility requirements for submission to Chile Other Medical Device Related Standards 1
J Biocompatibility for endoscope external handle/grip US Food and Drug Administration (FDA) 3
S Validity of biocompatibility reports ISO 13485:2016 - Medical Device Quality Management Systems 4
O ISO10993 - Biocompatibility in medical vacuum systems (vacuum pumps) Medical Device and FDA Regulations and Standards News 2
E Biocompatibility testing of our applied part seems redundant Other Medical Device Related Standards 2
S Biocompatibility requirement for electrode adapters Other Medical Device Related Standards 1
S ASTM F86 x Biocompatibility Issues Medical Device and FDA Regulations and Standards News 1
Judy Abbott The impact of laser power on biocompatibility of the products Manufacturing and Related Processes 6
Watchcat Summary of De Novo Biocompatibility Information, 2015-2018 Other US Medical Device Regulations 0
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
F Biocompatibility evaluation for Hardware/Interface Components? Other Medical Device Related Standards 13
L Process changes and biocompatibility (ISO 10993-1) Other Medical Device Related Standards 1
Beliz Biocompatibility Testing for Laser Epilation Device EU Medical Device Regulations 2
L FDA Biocompatibility Requirements - Transitory Contact Other US Medical Device Regulations 1
K Biocompatibility Testing - Multile products of different sizes and shapes US Food and Drug Administration (FDA) 2
K Biocompatibility evaluation of gas pathways Medical Device and FDA Regulations and Standards News 5
K Diagnostic X-ray devices - Applicability of Biocompatibility Testing per ISO 10993-1 Manufacturing and Related Processes 7
Judy Abbott Activation of complement at 90 min - BSI requested for justifications to support the biocompatibility of the device EU Medical Device Regulations 2
Judy Abbott Can any one help me with an urgent BIOCOMPATIBILITY Impact assessment? Internal Auditing 9
S ISO 10993 Biocompatibility Evaluation - Electronic thermometer Other Medical Device Related Standards 3
shimonv Referring to previously submitted biocompatibility results in a new 510(k) submission Other US Medical Device Regulations 1
I ISO 10993 Biocompatibility Requirements - manufacturing process chemicals Other Medical Device Related Standards 8
R 510(k) Biocompatibility vs Cleaning Validation Other Medical Device Related Standards 4
K Biocompatibility classification for Lancet CE Marking (Conformité Européene) / CB Scheme 7
F Sample Size for Biocompatibility Tests Other Medical Device Related Standards 4
F Biocompatibility Device Categorization: Priming with Blood Other Medical Device Related Standards 1
W Biocompatibility Risk Analysis for Clinical Practitioner 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
F Biocompatibility on aged devices Other Medical Device Related Standards 4
Gamula Biocompatibility GLP conform tests outside China China Medical Device Regulations 1
K Biocompatibility Testing - Component Level or Assembled Medical Device? ISO 13485:2016 - Medical Device Quality Management Systems 7
I Biocompatibility Impact on Autoclaved Silicone Other Medical Device Related Standards 3
D Should Biocompatibility Tests be performed on Production Samples? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
C Biocompatibility Test for a Non Contact Medical Device US Food and Drug Administration (FDA) 11
R Biocompatibility - ISO 10993 and SVHC Requirements Other Medical Device Related Standards 4
planB Biocompatibility: Blue Book Memorandum #G95-1 superseded by new FDA guidance Other Medical Device Related Standards 1
S ISO 10993-1: External Communicating Device biocompatibility test requirements Other ISO and International Standards and European Regulations 4
M Biocompatibility - why are animal studies necessary? Other Medical Device and Orthopedic Related Topics 11
R Biocompatibility Test of Blue Gown vs Blue Drape 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R FDA Biocompatibility questions for Surgical Gown 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Biocompatibility requirements for a Class IIa medical device CE Marking (Conformité Européene) / CB Scheme 7
S Biocompatibility testing for nasal prongs made of medical grade silicone 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
J Biocompatibility tests in AAA LAC Laboratory ISO 13485:2016 - Medical Device Quality Management Systems 6
B Biocompatibility for Packaging Materials Other Medical Device Related Standards 3
