What is the formula I need to calculate Pp and Ppk?
#13
garbage in garbage out.
not all distributions are Normal, not all sampling for process capability is correctly done, not all processes are shown to be stable prior to calculating capability, knowledge of the formulas and their intent IS important in interpreting the resutls.
or as Hubert Blalock said: "The manipulation of statistical formulas is no substitute for knowing what one is doing"
#14
Re: Capability calculations need 30 to 100 samples for acceptable confidence band
I'm trying to sort out Cpk and Ppk too. So... if I am understanding this correctly, the calculations for Cpk and Ppk are identical.... just use a different sigma.
But that doesn't match my basic understanding ...Cpk is how well curve fits between the control limits and Ppk is how well the curve and limits line up with the specifications. How can the same calculation give two different things. :confused:
There are a lot of posts on this very topic here. I would suggest searching for them and then coming back for specific questions. : )
bobdoering
Stop X-bar/R Madness!!
#15
Garbage in - garbage out. It is just a number cruncher. If you do not have a thorough understanding of the source data, it can lead you down a thorny path.
For example: When you calculate a variance (and therefore a standard deviation) of a process, it really represents the total variance. Total variance is a composite of many variances, and they may be of differing distributions - normal, uniform, Weibull - all in differing levels of participation. Making valid decisions likely requires understanding these underlying distributions. The software will not know this, it is not that bright. The user has to ponder these things.
(Yikes...Bev beat me to it!)
Rebecca Bowes - 2010
#16
I am experiencing that now on the job....non-normal. We are going to take a larger sampling, we are thinking that we didn't get all of the population even though our initial sampling plan was thought to be good.
bobdoering
#17
Could be the distribution is truly non-normal! It could happen! Which means your entire population will be non-normal, so your sampling may have been correct.
What is the process?
#18
Blowmolding at this stage, then once that process is stable, the into maching/cutting, welding and then finally assembly. We need to get the blowmolding process stabalized as much as possible in the critical areas first. Yes, it maybe non-normal, but won't know until we actually measure more.
bobdoering
#20
Blowmolding at this stage, then once that process is stable, the into maching/cutting, welding and then finally assembly. We need to get the blowmolding process stabilized as much as possible in the critical areas first. Yes, it maybe non-normal, but won't know until we actually measure more.
I could see a blow molded dimension being non-normal - maybe a Weibull or such. Perhaps similar to a unilateral tolerance, but based on physical limitations (such as the part can be no larger than the mold, but it can shrink smaller...)
Just a thought...
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Need some help with a formula in Excel Please! Excel .xls Spreadsheet Templates and Tools 11
J 2 Reliability Problems - Have Answers, Need Formula Reliability Analysis - Predictions, Testing and Standards 7
C I need help verifying formula's in a database for LCL UCL Cp Cpk PPk Statistical Analysis Tools, Techniques and SPC 14
S Bend allowance formula to calculate per degree per radii Manufacturing and Related Processes 2
J Unbiasing Constant "d4" formula Statistical Analysis Tools, Techniques and SPC 4
S Formula for Calculating NoGo Major Diameter for UN gages Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A Excel OOT (Out of Tolerance) Formula Excel .xls Spreadsheet Templates and Tools 3
J CMM Accuracy Formula General Measurement Device and Calibration Topics 3
I Formula in the Annex of IEC 61000-4-3 - How is k=7 determined? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Z Inspection Form With Pass/Fail Formula Excel .xls Spreadsheet Templates and Tools 11
S used excel formula calculated the ARL's with Rule1&Rule2 for Shewhart control chart Statistical Analysis Tools, Techniques and SPC 0
L Signal-to-Noise (S/N) Ratio formula check Design and Development of Products and Processes 2
S Scrap % Calculation Formula Manufacturing and Related Processes 10
P IF formula - Excel 2003 Excel .xls Spreadsheet Templates and Tools 4
J Bias formula in MSA 4th Edition vs 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
N Formula that will calculate the NoGo Major Diameter of an M20 x 1.5 6H Thread gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R Formula to tie together - Confidence/Reliability Level AQL? LTPD? Reliability Analysis - Predictions, Testing and Standards 3
F How to Calculate the unbiased Standard Deviation in Excel using Minitab Formula Capability, Accuracy and Stability - Processes, Machines, etc. 6
M Dimension Report Formula .xlsx Editable Spreadsheet Form Excel .xls Spreadsheet Templates and Tools 24
M Should I use binomial or Poisson distribution formula? Statistical Analysis Tools, Techniques and SPC 6
F Excel I want to use the count I get in another formula Excel .xls Spreadsheet Templates and Tools 13
M Formula for Bell Shape in Excel Using Minitab Software 1
M What is the formula to create a bell curve? Excel .xls Spreadsheet Templates and Tools 8
P Does anyone have the GRR Formula? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Standard Deviation Estimation Formula - Student Question Statistical Analysis Tools, Techniques and SPC 4
B Formula Data Validation Set for Cp, Cpk, Pp & Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 1
B Attrition Rate and the formula to calculate Attrition Rate Quality Manager and Management Related Issues 1
D Demonstration Reliability Test Formula with allowance for 'x' Failures Reliability Analysis - Predictions, Testing and Standards 6
N Is there a formula to link words in Excel sheet to a graph? Excel .xls Spreadsheet Templates and Tools 5
N Linear Regression Formula with Four Variables to a Power Regression Formula Using Minitab Software 2
M MSA - According to the formula cg how much tolerance should be put in place? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
F SPC Newbie looking for Excel Spreadsheet formula for a sample size of 40 components Capability, Accuracy and Stability - Processes, Machines, etc. 8
A Bias Linearity Stability MSA Excel File with Formula Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J Repeatability Standard Deviation Formula in MSA 4th Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
M Formula for Prioritizing Engineering Change Requests (ECR)? Document Control Systems, Procedures, Forms and Templates 1
I AQL Formula in Excel - Calculating Sample Size based on an AQL Chart AQL - Acceptable Quality Level 8
D Formula for Calculating Warp Measurement of Corrugated Boxes General Measurement Device and Calibration Topics 1
Z KPI Formula Issue - "Change Requests Managed" = Changed/Total ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
O Which role plays Inverse cdf of a Standard Normal Distribution in Formula for Z-Bench Using Minitab Software 8
D Route Delivery Efficiency Formula - Miles driven, number of deliveries, and time(hrs) Benchmarking 3
S Formula used in Minitab 16 - "Pooled Standard Deviation" Statistical Analysis Tools, Techniques and SPC 2
X Microsoft Excel 2003 Formula Restrictions Excel .xls Spreadsheet Templates and Tools 9
T Gage R&R Sheet Formula error?! NDC less than 4 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Sample Size Calculation Formula for Process Capability Statistical Analysis Tools, Techniques and SPC 25
Q Accuracy: Is there a specific formula to compute Measurement Device Accuracy? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Rameshwar25 Manual Formula for p-value Calculation for MSA Analysis Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
D Ring Gauges P.D Formula using "Ball Rounded Teeth" General Measurement Device and Calibration Topics 13
R Formula for calculating Money Value equivalent to 1% FPY (First Pass Yield) Six Sigma 5
B Problem with Reliability and Availability Formula Reliability Analysis - Predictions, Testing and Standards 8
