What is the meaning of "k" in Cpk and Ppk? And Cpk vs. Ppk
Star18
Hi evrybody,
Is someone knows the meaning of "k" in the indexes Cpk and Ppk ?
Thanks in advance.
Rach.:bigwave:
Wes Bucey
Wayne makes an excellent point of citing an authoritative source for information about statistics used in Engineering and Quality.
All our readers should bookmark this excellent FREE handbook published by the National Institute of Standards and Testing. http://www.itl.nist.gov/div898/handbook/
If you are writing a formal paper or document (versus a comment here in the Cove) there is a protocol for making the citation in your footnotes or endnotes:
To reference the Handbook please use a citation of the form:
NIST/SEMATECH e-Handbook of Statistical Methods, http://www.itl.nist.gov/div898/handbook/, date.
(Links to specific pages can also be referenced this way, if suitable.)
Printer friendly versions of each chapter in the e-Handbook can be found
here.
Information on Getting the e-Handbook on CD can be found
here.
Feedback on the Handbook sent to
[email protected] is also much appreciated.
Wes Bucey
wmarhel said:
I'm not sure, but the CD used to be free of charge.
Still free PLUS it is copyright-free, which means (and it is encouraged by NIST) you can start with a master copy and make as many additional copies to distribute as you need.
This might make a good free premium to give to employees, customers, or clients (i.e. burn copies of a master CD and give them away.) Having accessed this both by dial-up and high-speed, I can tell you it makes a lot of sense to have a reference copy on disk or hard drive if you don't have high-speed internet access.
Mr.Nathan
What is the differents between cp and cpk?
Hi Guys,
Does anyone knows " What is the differents between cp and cpk? " As i know that both is use to monitor process capability and the formula is also different but anyway im still not very clear with it.
Cp = ?
Cpk = ?
thanks
Nathan
Marc
Cp vs. Cpk - What is the difference - A visual animation
The thread started with Cpk vs. Ppk which I don't think was directly answered in this thread yet, but for the Cp vs. Cpk post above:
Take a look at the visual animation here: Cp vs. Cpk visual animation
The essential difference is Cpk addresses centering on the specification spread / center point. Cp only addresses the tightness of the process (machine) its self.
k = a constant.
I did notice in the 'Similar Threads' listing at the bottom of the page. This is a very common question. I think a page with good links to major threads here in the forums is What is the difference between Cp, Cpk and Ppk?.
  • Cmk – Machine capability
  • Cpk – Process capability index
  • Cpm – Targeted capability index
  • Ppk – Performance capability index
  • Ppk – Preliminary process capability index (had to use it for Ford in
    the start up of new projects)
Are Cpk & Ppk acronyms? If so, what do they actually mean or represent?
From a link:
Since their introduction, there has been a lot of speculation as to meaning.
Cp has always been know as capability of the process since I became aware of it and it has been around for some time. My connection with Cpk came through the Ford "Continuous Process Control and Process Capability Improvement Manual" probably more than 20 years ago. In the Ford manual, a k value was used to represent the number of standard deviations between the Target and the x double bar. I would assume that the Cpk came literally from Cp with a k factor adjustment. In reference to the Pp and Ppk, the reference from the beginning has been to Process Performance as opposed to Process Capability.
Can anyone summarize when to use Cpk vs. Ppk - And why?
Watchcat FDA will not tolerate fraud…meaning what, exactly? Other US Medical Device Regulations 8
QIE FDA 21 CFR Part 11 "Meaning of Signature" Other US Medical Device Regulations 6
Mikishots Definition Defined - Definition and meaning of "defined" Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
H Meaning of Annex II, excluding point Clause 4 conformity CE Marking (Conformité Européene) / CB Scheme 4
T Supplier monitoring - The meaning of "8.4.2.4 " Customer disruptions IATF 16949 - Automotive Quality Systems Standard 1
E SPC for Dummies - The correct meaning of all the graphs Statistical Analysis Tools, Techniques and SPC 3
E Definition Integrity - The meaning of the word INTEGRITY in ISO 13485 Control of Records Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
E Definition QUALITY 4.0 - Somebody here could explain the meaning of Quality 4.0? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
F EU Definition of Labeling or the meaning of the MDD (Medical Devices) EU Medical Device Regulations 7
N What is the meaning of Suspended in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M OEE - The meaning of the single number Quality Tools, Improvement and Analysis 12
C Meaning of "direct diagnosis" (Annex IX, Rule 10) EU Medical Device Regulations 6
G What is the exact meaning of Single Fault condition? EU Medical Device Regulations 4
S ECR - meaning of "Control Item Affected: Yes or no" IATF 16949 - Automotive Quality Systems Standard 1
Ajit Basrur Do you know the meaning of these words ??? Coffee Break and Water Cooler Discussions 4
W UL standard for Lead wire - meaning of UL numbering, AWG#, no. of conductor, etc Various Other Specifications, Standards, and related Requirements 1
N Agile 9.3.1 Relationship Searches - Meaning of Message Manufacturing and Related Processes 1
S Scenario to illustrate the meaning of CAPA Nonconformance and Corrective Action 7
E AS9100 Section 7.6 - What is the meaning of "check method"? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
B AS 9100C sec 8.2.4 - " Recognized Statistical Principles" meaning AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M 7.6.2 Revisions following Engineering Changes - What is the right meaning? IATF 16949 - Automotive Quality Systems Standard 4
S Surface Profile of a Hole - The meaning of the tolerance in the provided drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M ISO 9001 - 7.5.5 - Meaning of Identification and how it helps Product Preservation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Stijloor The meaning of "Gibby." Coffee Break and Water Cooler Discussions 10
I ERP acronym has double meaning in our company Internal Auditing 6
M Suitability and Meaning of PED (Pre-Established Dispositions) to Quality Objectives IATF 16949 - Automotive Quality Systems Standard 2
A What's meaning of T series for a bolt or nut? Supplier Quality Assurance and other Supplier Issues 3
J Definition Performance - The Meaning of Performance in TS 16949 Clause 7.4.3.1 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
kedarg6500 What is the meaning of "define/defined" in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
M Design and Development: What is the right meaning? IATF 16949 - Automotive Quality Systems Standard 6
J What is the meaning of "Repair" as in TS 16949 Clause 6.4.2? IATF 16949 - Automotive Quality Systems Standard 3
J ISO 14155:2011 - The meaning of the term "Should" EU Medical Device Regulations 8
M The Statistical Meaning of "Muddy Middle" - Statistics Terminology Statistical Analysis Tools, Techniques and SPC 6
R What is the meaning of "Highest RATED Current" in Protective Earth Impedance Test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
S What's the meaning of "Quality Management System Requirements" in 7.4.2 (c)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Meaning of Business Management System in IRIS (International Rail Industry Standard)? Various Other Specifications, Standards, and related Requirements 4
S What's the meaning of 'methods' in 4.1(c) ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
S Meaning of n-1 in Standard Deviation Quality Tools, Improvement and Analysis 12
H What's the meaning of this paragraph from AS9100B: 'Page31----7.6 f)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
H What's the meaning of "a minimum 95% reliability target"? General Measurement Device and Calibration Topics 14
Q Definition FRACAS - What is the meaning of FRACAS Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
J What's the meaning of word "map" (Map these requirements with your implemented QMS)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
K Definition Correlation - The meaning of correlation and and its application in data analysis Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
P What is the meaning of your Elsmar Cove Forum User Name? Coffee Break and Water Cooler Discussions 58
B Definition Competence - What is the meaning of Competence? ISO 9001 Clause 6.2.2 Competence Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 13
P 8.2.3.1 - What is the meaning of this text? IATF 16949 - Automotive Quality Systems Standard 10
R The meaning of %StudyVar opposed to %Contribution Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
S CE Mark - What is the meaning of CE or CE0050(text inserted here) CE Marking (Conformité Européene) / CB Scheme 3
V Team feasibility commitment : meaning of efficient material handling techniques ? APQP and PPAP 1
D Supplier commitment acceptance of orders verified and managed - Meaning AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
