What is the meaning of "k" in Cpk and Ppk? And Cpk vs. Ppk
antoine.dias
#11
Re: Cp vs. Cpk - What is the difference - A visual animation
Marc said:
  • Cmk – Machine capability
  • Cpk – Process capability index
  • Cpm – Targeted capability index
  • Ppk – Performance capability index
  • Ppk – Preliminary process capability index (had to use it for Ford in
    the start up of new projects)
Are Cpk & Ppk acronyms? If so, what do they actually mean or represent?
From a link:
Can anyone summarize when to use Cpk vs. Ppk - And why?
Cpk is used as a capability index using the variation in the sample with the formula of R(bar)/d2.
Ppk is used as a performance index using the standard variation formula calculated over the set of measured individual measurements (not the variation in the sample)
Best regards,
Antoine
sushant_kulkarni
#12
Re: What is the differents between cp and cpk?
Process range. First, it is customary to establish the ± 3 sigma limits around the nominal specifications. Actually, the sigma limits should be the same as the ones used to bring the process under control using Shewhart control charts (see Quality Control). These limits denote the range of the process (i.e., process range). If we use the ± 3 sigma limits then, based on the normal distribution, we can estimate that approximately 99% of all piston rings fall within these limits.
Specification limits LSL, USL. Usually, engineering requirements dictate a range of acceptable values. In our example, it may have been determined that acceptable values for the piston ring diameters would be 74.0 ± .02 millimeters. Thus, the lower specification limit (LSL) for our process is 74.0 - 0.02 = 73.98; the upper specification limit (USL) is 74.0 + 0.02 = 74.02. The difference between USL and LSL is called the specification range.
Potential capability (Cp). This is the simplest and most straightforward indicator of process capability. It is defined as the ratio of the specification range to the process range; using ± 3 sigma limits we can express this index as:
Cp = (USL-LSL)/(6*Sigma)
Put into words, this ratio expresses the proportion of the range of the normal curve that falls within the engineering specification limits (provided that the mean is on target, that is, that the process is centered, see below).
Bhote (1988) reports that prior to the widespread use of statistical quality control techniques (prior to 1980), the normal quality of US manufacturing processes was approximately Cp = .67. This means that the two 33/2 percent tail areas of the normal curve fall outside specification limits. As of 1988, only about 30% of US processes are at or below this level of quality (see Bhote, 1988, p. 51). Ideally, of course, we would like this index to be greater than 1, that is, we would like to achieve a process capability so that no (or almost no) items fall outside specification limits. Interestingly, in the early 1980's the Japanese manufacturing industry adopted as their standard Cp = 1.33! The process capability required to manufacture high-tech products is usually even higher than this; Minolta has established a Cp index of 2.0 as their minimum standard (Bhote, 1988, p. 53), and as the standard for its suppliers. Note that high process capability usually implies lower, not higher costs, taking into account the costs due to poor quality. We will return to this point shortly.
Capability ratio (Cr). This index is equivalent to Cp; specifically, it is computed as 1/Cp (the inverse of Cp).
Lower/upper potential capability: Cpl, Cpu. A major shortcoming of the Cp (and Cr) index is that it may yield erroneous information if the process is not on target, that is, if it is not centered. We can express non-centering via the following quantities. First, upper and lower potential capability indices can be computed to reflect the deviation of the observed process mean from the LSL and USL.. Assuming ± 3 sigma limits as the process range, we compute:
Cpl = (Mean - LSL)/3*Sigma
Cpu = (USL - Mean)/3*Sigma
Obviously, if these values are not identical to each other, then the process is not centered.
Non-centering correction (K). We can correct Cp for the effects of non-centering. Specifically, we can compute:
K=abs(D - Mean)/(1/2*(USL - LSL))
where
D = (USL+LSL)/2.
This correction factor expresses the non-centering (target specification minus mean) relative to the specification range.
Demonstrated excellence (Cpk). Finally, we can adjust Cp for the effect of non-centering by computing:
Cpk = (1-k)*Cp :)
If the process is perfectly centered, then k is equal to zero, and Cpk is equal to Cp. However, as the process drifts from the target specification, k increases and Cpk becomes smaller than Cp.
artichoke
#13
Control limits are not probability limits. They do not give a probability of events falling outside limits.
"Capability" means the capability of a process to meet specifications. This can only occur if a process is in statistical control. Capability indexes do not in themselves provide this information. A process that is out of control may fail to meet specifications, not matter where spec limits have been set.
We never know the true distribution of data. There is no justification for assuming normality.
There is no problem with this for well controlled processes.
It is possible to have Cpk less than 1.0 and still have all data within spec. Capability ratios can be quite misleading. They should always be used in conjunction with control charts and histograms. Those looking for numbers to present to management might better consider MSD, Mean Square Deviation About Target. This gives a measure of how a stable process is performing relative to "on target with minimum variance".
dknox4
#14
Cp = the ratio of the process spread to the specification tolerence.
Cpk = the lowest ratio of the above when the process spread is centered on the specification mid-point.
Cpk is always lower or, at best equal, to the Cp because of the centering. Rarely does the mean of the process fall exactly on the mean of the spec.
Stijloor
#15
The origins of k actually go back to the 1970s in Japan. The Japanese are credited with developing the the Cp, Cpl, Cpu, Cpk, and k indexes of process capability.
So what is k? It is an index of process centering, defined as follows, where M is the middle of the tolerance, mu is the process average, USL is the upper spec limit, and LSL is the lower spec limit:
k = |M - mu| / [(USL - LSL) / 2]
k is then used as follows to compute Cpk.
Cpk = Cp (1 - k)
When the process average is centered at the middle of the tolerance, M = mu, and therefore, M - mu = 0. With k = 0, Cpk will equal Cp.
Cpk = Cp (1 - 0) = Cp
If the process average is centered anywhere else, then the absolute value of the quantity M - mu is greater than zero, making k also greater than 0. Suppose k is 0.30 for a process. Then the Cpk index for this process is only 70% of the Cp index.
Cpk =Cp (1 - 0.30) = 0.70Cp
So in one way, k measures how much potential capability is lost due to poor centering. In the above example, Cpk could be increased by 30% if we could center mu at M.
Watchcat FDA will not tolerate fraud…meaning what, exactly? Other US Medical Device Regulations 8
QIE FDA 21 CFR Part 11 "Meaning of Signature" Other US Medical Device Regulations 6
Mikishots Definition Defined - Definition and meaning of "defined" Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
H Meaning of Annex II, excluding point Clause 4 conformity CE Marking (Conformité Européene) / CB Scheme 4
T Supplier monitoring - The meaning of "8.4.2.4 " Customer disruptions IATF 16949 - Automotive Quality Systems Standard 1
E SPC for Dummies - The correct meaning of all the graphs Statistical Analysis Tools, Techniques and SPC 3
E Definition Integrity - The meaning of the word INTEGRITY in ISO 13485 Control of Records Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
E Definition QUALITY 4.0 - Somebody here could explain the meaning of Quality 4.0? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
F EU Definition of Labeling or the meaning of the MDD (Medical Devices) EU Medical Device Regulations 7
N What is the meaning of Suspended in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M OEE - The meaning of the single number Quality Tools, Improvement and Analysis 12
C Meaning of "direct diagnosis" (Annex IX, Rule 10) EU Medical Device Regulations 6
G What is the exact meaning of Single Fault condition? EU Medical Device Regulations 4
S ECR - meaning of "Control Item Affected: Yes or no" IATF 16949 - Automotive Quality Systems Standard 1
Ajit Basrur Do you know the meaning of these words ??? Coffee Break and Water Cooler Discussions 4
W UL standard for Lead wire - meaning of UL numbering, AWG#, no. of conductor, etc Various Other Specifications, Standards, and related Requirements 1
N Agile 9.3.1 Relationship Searches - Meaning of Message Manufacturing and Related Processes 1
S Scenario to illustrate the meaning of CAPA Nonconformance and Corrective Action 7
E AS9100 Section 7.6 - What is the meaning of "check method"? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
B AS 9100C sec 8.2.4 - " Recognized Statistical Principles" meaning AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M 7.6.2 Revisions following Engineering Changes - What is the right meaning? IATF 16949 - Automotive Quality Systems Standard 4
S Surface Profile of a Hole - The meaning of the tolerance in the provided drawing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
M ISO 9001 - 7.5.5 - Meaning of Identification and how it helps Product Preservation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Stijloor The meaning of "Gibby." Coffee Break and Water Cooler Discussions 10
I ERP acronym has double meaning in our company Internal Auditing 6
M Suitability and Meaning of PED (Pre-Established Dispositions) to Quality Objectives IATF 16949 - Automotive Quality Systems Standard 2
A What's meaning of T series for a bolt or nut? Supplier Quality Assurance and other Supplier Issues 3
J Definition Performance - The Meaning of Performance in TS 16949 Clause 7.4.3.1 Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 7
kedarg6500 What is the meaning of "define/defined" in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
M Design and Development: What is the right meaning? IATF 16949 - Automotive Quality Systems Standard 6
J What is the meaning of "Repair" as in TS 16949 Clause 6.4.2? IATF 16949 - Automotive Quality Systems Standard 3
J ISO 14155:2011 - The meaning of the term "Should" EU Medical Device Regulations 8
M The Statistical Meaning of "Muddy Middle" - Statistics Terminology Statistical Analysis Tools, Techniques and SPC 6
R What is the meaning of "Highest RATED Current" in Protective Earth Impedance Test? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
S What's the meaning of "Quality Management System Requirements" in 7.4.2 (c)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Meaning of Business Management System in IRIS (International Rail Industry Standard)? Various Other Specifications, Standards, and related Requirements 4
S What's the meaning of 'methods' in 4.1(c) ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
S Meaning of n-1 in Standard Deviation Quality Tools, Improvement and Analysis 12
H What's the meaning of this paragraph from AS9100B: 'Page31----7.6 f)? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
H What's the meaning of "a minimum 95% reliability target"? General Measurement Device and Calibration Topics 14
Q Definition FRACAS - What is the meaning of FRACAS Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
J What's the meaning of word "map" (Map these requirements with your implemented QMS)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
K Definition Correlation - The meaning of correlation and and its application in data analysis Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
P What is the meaning of your Elsmar Cove Forum User Name? Coffee Break and Water Cooler Discussions 58
B Definition Competence - What is the meaning of Competence? ISO 9001 Clause 6.2.2 Competence Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 13
P 8.2.3.1 - What is the meaning of this text? IATF 16949 - Automotive Quality Systems Standard 10
R The meaning of %StudyVar opposed to %Contribution Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
S CE Mark - What is the meaning of CE or CE0050(text inserted here) CE Marking (Conformité Européene) / CB Scheme 3
V Team feasibility commitment : meaning of efficient material handling techniques ? APQP and PPAP 1
D Supplier commitment acceptance of orders verified and managed - Meaning AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
