Re: What is the Minimum Regulatory Requirement for Record Retention of DHR by Supplie
You should define the life time of your product in order to define the retention time of your records.
If the quality of the supplied items can be assured by records obtained at incomming inspection (inspection test results, supplier CoC / CoA) and spported by supplier qualification data you are at less risk with not having supplier DMRs available. These records should therefore also be retained for the lifetime of your product.
If not, you must request your supplier to retain their DMRs according to your own retention schedule.
