What is the minimum sample required for Performance Evaluation for IVD ?
belemsanchez
please, I have a doubt, when you make a performance evaluation, whats is the minimun number of samples? are 20 samples in IVD?
Thanks a lot
rangani_rj
Hi
Though I am not expert in Statistic, I have some idea based on my research work in post-graduation that there is not like ?minimum sample size in statistic?.
You have to first define which test is appropriate for your study (ANNOVA, Dunn?s test etc). Sample size depends on multiple factor. First It depends on which power of statistical significance you want for your particular test (like p<0.001(99% positive outcome and one negative), P<0.005(95%)).
Further it will also depend on which type of test your device is performing. Whether it is detecting rare disease parameter or common parameter. For rare disease parameter your sample will be limited.
What I was doing to determine minimum sample required, I was putting some rough value of sample size and expected positive outcome in statistic software (Biostat) for particular test (Two Way Annova). It shows the acceptance of result with confidence interval (P value). Another software is Graphic pad Prism. Another simple way ? first define test and then using Excel and rough data determine minimum size of sample with positive result.
This is my research experience, I dont know whether it is applicable for such IVD related regulatory work or not.
As someone who does this a living - there is no minimum sample size. It all depends on your (desired) label claim for Sensitivity and Specificity, the significance and power desired, whether or not your test will use different types of samples (whole blood, plasma, serum, tissue, fecal, urine etc.) and the need for diversity of disease variants (such as geographic stratification).
It will also depend on the type of analysis your regulatory reviewer prefers...latent class, baysian, clopper-pearson...
rangani_rj
I was reading regulation on IVD and found that common technical specification (CTS) directive for IVD (2002/364/EC) have already mentioned some requirements for performance evaluation (specificity, sensitivity, population selection, specimen type etc) in table 1 to table 10 according to IVD devices (Blood groupin, Virus, Genotype).
Have a look on this directive if you are still searching for sample size.
M Minimum sample size - Guidance and statistical rationale Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
N ETO Sterilisation Validation - EO Residual Minimum Sample Requirement ISO 13485:2016 - Medical Device Quality Management Systems 2
D What is the minimum Sample Size for Weibull Analysis Reliability Analysis - Predictions, Testing and Standards 12
J Minitab Sample Size Calculation: 1 Sample t vs Minimum Sample Size for Means Using Minitab Software 3
D Minimum Size of Control Sample in Medical Research Lab Work Statistical Analysis Tools, Techniques and SPC 2
R What is minimum sample size to calculate Cp? Statistical Analysis Tools, Techniques and SPC 9
D LiPo battery minimum requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Search function minimum length Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 3
Q Capability study with a minimum spec Statistical Analysis Tools, Techniques and SPC 8
L Significant Production Run - How 300 was determined to be the minimum quantity APQP and PPAP 2
Marco Bernardi MMC & LMC modifiers and CMM measuring techniques like diameter least squares and circularity or minimum/ maximum diameter Calibration and Metrology Software and Hardware 5
shimonv Minimum 60601 requirements for a clinical trial IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Minimum Supplier Certifications for Food Supplements Food Safety - ISO 22000, HACCP (21 CFR 120) 4
J What is the minimum standard for automotive component traceability? Manufacturing and Related Processes 2
M Applicability of IEC 60950-1 Table K2 - Minimum clearances between circuits Various Other Specifications, Standards, and related Requirements 0
M Characterization Testing - NO acceptance criteria, no minimum performance requirement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
K Is minimum repair or replace guarantee period for medical devices in EU the same as consumer guarantee law of 2 years? EU Medical Device Regulations 5
S Designing the experiment with minimum run Statistical Analysis Tools, Techniques and SPC 0
JoshuaFroud Change Control - Minimum Requirements and Unhappy Staff ISO 13485:2016 - Medical Device Quality Management Systems 16
J IATF Minimum Automotive Quality Management System Requirements for Sub-Tier Suppliers IATF 16949 - Automotive Quality Systems Standard 12
F Regulatory Compliant Quality Management System - Bare Minimum EU Medical Device Regulations 2
S What is the minimum pressure differential required for ISO Class 8 Clean Room? ISO 13485:2016 - Medical Device Quality Management Systems 3
somashekar ISO 13485 plus ISO 9001:2015 will now attract a minimum 2 day upgrade audit ISO 13485:2016 - Medical Device Quality Management Systems 9
J Minimum staff per 21 CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Is there a minimum industry standard for PpK ? Statistical Analysis Tools, Techniques and SPC 8
K What are the minimum requirements for Process Validation (Software)? ISO 13485:2016 - Medical Device Quality Management Systems 5
C Battery Powered Beauty Products minimum Legal Certifications Requirements CE Marking (Conformité Européene) / CB Scheme 7
D Minimum requirements/experience/qualifications to be head of quality Career and Occupation Discussions 6
R Minimum Essential Receiving Inspection (M.E.R.I.) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S What is the minimum samples required for Customer Survey? Quality Manager and Management Related Issues 3
J Minimum number of parts to do an attribute gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
I Minimum and Maximum Validation Batch Size Requirements Qualification and Validation (including 21 CFR Part 11) 3
A Minimum Number of Parts for Attribute (Go / NoGo) Data Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Minimum documents required by AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
N Minimum Design factor for CE Marking for machinery CE Marking (Conformité Européene) / CB Scheme 2
G Why for a Shewhart chart the minimum feasible value for APL is 2401 units? Statistical Analysis Tools, Techniques and SPC 8
A Minimum Testing Requirements for a Clear Protective Equipment Barrier (Class II 510K) Other US Medical Device Regulations 1
V Critical Characteristics - Capability for a Minimum Specification APQP and PPAP 11
BradM What is the minimum size chamber for mapping? ISO 13485:2016 - Medical Device Quality Management Systems 2
Q Minimum Organization Structure to support TS16949 IATF 16949 - Automotive Quality Systems Standard 5
Q Minimum content required in a Quality Manual as per ISO 9001:2008 Quality Management System (QMS) Manuals 6
A ISO 13485 Supplier Monitoring Minimum Requirements Supplier Quality Assurance and other Supplier Issues 3
T New Packaging Line Performance Qualification (PQ) - Minimum Test Times ? Qualification and Validation (including 21 CFR Part 11) 3
F How to calculate the minimum Value of Mass needed for Scales Calibration? General Measurement Device and Calibration Topics 6
W ITAR (International Traffic in Arms Regulations) Minimum Requirements or Shalls Other ISO and International Standards and European Regulations 9
JoCam Equipment Guarding - Safe Distance - Is there a specified minimum distance? Occupational Health & Safety Management Standards 6
F How to Calculate Cpk with only a Minimum Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 11
H SOP containing Minimum Requirements for Master Production Record US Food and Drug Administration (FDA) 1
S What is the 10d in the owner's manual for a balance's minimum weight? General Measurement Device and Calibration Topics 5
