What is the most appropriate MSA (Measurement System Analysis) Study
Calibrator24
We have a weighing scale in our company that was being used to count devices. This weighing scale was calibrated thru comparison with standard weights. The actual application required the user to configure this scale to convert it's function from weighing to counting. Since the devices naturally have variations on weight, error on the actual counts cropped up. The customers were complaining if there were shortage and the company doesn,t want to have excesses in the shipment either.
Can we correct this problem thru the use of an MSA study? what would be the best study to undertake if we want to have an accurate counting instrument? and how it should be done? Any insight? Thanks.
Stijloor
We have a weighing scale in our company that was being used to count devices. This weighing scale was calibrated through comparison with standard weights. The actual application required the user to configure this scale to convert it's function from weighing to counting. Since the devices naturally have variations on weight, error on the actual counts cropped up. The customers were complaining if there were shortage and the company doesn't want to have excesses in the shipment either.
Can we correct this problem through the use of an MSA study? what would be the best study to undertake if we want to have an accurate counting instrument? and how it should be done? Any insight? Thanks.
Any MSA Experts who can help?
Thank you!!
Stijloor.
The Specialist
Whilst not a specific method for MSA, I do have a couple of suggestions…
Firstly,
Whilst conducting your calibration trials on the weigh-scale, have you also conducted eccentricity and repeatability trials?
Secondly,
Calculate the max. no. of items you can weigh collectively, before the accumulated potential tolerance is greater than that of the minimum accepted weight of an individual unit.
e.g. you will increase the accuracy if you weigh fewer units in your bulk load... by preventing the possibility of the accumulated total upper and lower tolerances (weight) from being greater or lower than that of a single unit.
K
keithljelp
A MSA is not going to help you. The MSA will only tell you if your measurement system is capable and you all ready know it is not since you are getting inaccurate counts. It is simply a matter of the resolution of the scale you are using. The scale must have a resolution 10X smaller that the variation in the weight of the parts you are trying to count. You can sometimes use 5X smaller.
Example:
If the part's weight varies by plus or minus .5 gram then a scale with a .5 gram resolution will not always give you an accurate count. You do not know how the microprocessor was programmed. Does it round up or down or truncate??? You would need a scale that can resolve to at least a .1 grams and .05 grams would be better. The scale must also have a maximum load that is greater than the total weight of parts you wish to count by at least 20%.
If the scale is located in shipping be careful of wind currents. They will affect a scale.
Hope this helps,
Keith
bobdoering
Stop X-bar/R Madness!!
We have a weighing scale in our company that was being used to count devices. This weighing scale was calibrated thru comparison with standard weights. The actual application required the user to configure this scale to convert it's function from weighing to counting. Since the devices naturally have variations on weight, error on the actual counts cropped up. The customers were complaining if there were shortage and the company doesn't want to have excesses in the shipment either.
Here's the problem, it's not the scale's fault the product varies. Typically, a Gage R&R would use the same parts, which means it will not collect the variation you are experiencing and the scale will look great - but you will still have rejections. Calibration will have little to do with your problem (although it needs to be calibrated.)
You need to look at the problem as a product capability issue. If your carton has 1000 parts and each part is supposed to weigh 20 grams, then the scale should weigh out 20,000 grams per lot. To have an error of 1 part - based on part variation - the variation of the individual parts would only have to be .02 grams each. So, you need to look at the per piece weight capability over several lots (because that is where the variation will be the most) to see if weigh counting will even work. Also, for lighter parts, even dunnage weight variation can make a huge error in part counts!
D When is MSA (Measurement System Analysis) appropriate on a custom built gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
J The appropriate Attribute MSA for Automatic Visual Inspection Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Starting an MSA study - How to decide which is appropriate or required Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
N ISO 19011:2018 - 5.4.2 "...audit program should engage in appropriate continual development..." Training - Internal, External, Online and Distance Learning 4
A ISO 13485 - Clause 8.3.3 appropriate actions in response to nonconforming product ISO 13485:2016 - Medical Device Quality Management Systems 2
E What are appropriate deviations for a LHR/DHR? (Medical Device Company) Manufacturing and Related Processes 3
S When is ISO 13485:2016 6.4.2 Contamination Control appropriate? ISO 13485:2016 - Medical Device Quality Management Systems 11
C ICP versus AA: How to determine appropriate specification for assay method verification Qualification and Validation (including 21 CFR Part 11) 1
K Please help identify appropriate statistical treatment Statistical Analysis Tools, Techniques and SPC 13
A Electric terminal crimping machines - Is SPC appropriate for this process? Manufacturing and Related Processes 4
Le Chiffre Is ISO/IEC 27001 appropriate for most small businesses? IEC 27001 - Information Security Management Systems (ISMS) 2
W EU GMP Annex XI - What is an "appropriate QMS"? Other Medical Device Related Standards 2
F Appropriate Control Chart Statistical Analysis Tools, Techniques and SPC 5
N Taking exception to REACH Requirement - Appropriate Language REACH and RoHS Conversations 4
Q When does the FDA deem something "where appropriate"? 21CFR820.30(g) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
Y "As appropriate" in ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 20
S What is appropriate PPM level for a Plastic Injection Moulding Supplier Quality Tools, Improvement and Analysis 4
D What is the appropriate way to write a conclusion from a % contribution result? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
R Why customer satisfaction is not appropriate regulatory objective in medical device? ISO 13485:2016 - Medical Device Quality Management Systems 8
C What is the most appropriate Bioburden Test Method for Surgical Gloves ISO 13485:2016 - Medical Device Quality Management Systems 10
Q Writing appropriate ISO 13485 Audit Report Findings Internal Auditing 15
J Lean Appropriate KPIs for a Distribution Centre Lean in Manufacturing and Service Industries 1
I Is ARIMA (Time Series Analysis) Model appropriate for this Dental Research? Using Minitab Software 4
L Most appropriate Auditor to check the FMEA & PCP of a Manufacturing Process IATF 16949 - Automotive Quality Systems Standard 5
J Appropriate In-Process Monitoring Frequency for 2X per day Change Set-Up. Statistical Analysis Tools, Techniques and SPC 3
C Appropriate ways to address Competency? Generic vs Specific ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Appropriate use of the REF symbol in IVD kits and kit components Other Medical Device Related Standards 2
somashekar What is D&D Output for appropriate information for Production? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M 8.2.4.2 Appearance Items - When Masters for Colour, Grain, etc are not appropriate? IATF 16949 - Automotive Quality Systems Standard 6
D General Guideline for an appropriate Sample Size for measuring Cp and Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Appropriate Statistical Methods to set up an Alert/Warning Limit Quality Assurance and Compliance Software Tools and Solutions 15
B What is the Appropriate Sample Size for a Customer Survey? Customer Complaints 5
J Appropriate Test Environments for In-Glass Liquid Thermometer Calibrations General Measurement Device and Calibration Topics 2
R How to select appropriate standards for Multi-Functional Physical Therapy Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
T Appropriate Lean Six Sigma Green Belt Project Proposal? Six Sigma 10
I ASQ CQT Exam - Appropriate study time and best resources recommendations Professional Certifications and Degrees 8
T Determining the appropriate Sample Size using an AQL Table Inspection, Prints (Drawings), Testing, Sampling and Related Topics 29
B Appropriate Standards for Food Packaging Adhesive Manufacture Food Safety - ISO 22000, HACCP (21 CFR 120) 7
O Can anyone recommend appropriate standard for Reliability Testing of Cables Other Medical Device Related Standards 3
C What is the appropriate DPPM for to be used In-Process Inspection Other Medical Device Related Standards 2
S Pp/Ppk & Cp/Cpk - Which is appropriate for Long/Short Term Study? Statistical Analysis Tools, Techniques and SPC 20
J Ethics Training and Policy appropriate for an ISO 17025 Testing Laboratory ISO 17025 related Discussions 4
K Recommendations for an appropriate Recorder used at low temperature (Below 500?F) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M z Test vs. F Test - The most appropriate for comparing the Variances Statistical Analysis Tools, Techniques and SPC 3
B Appropriate ISO Clauses reference in Procedure Manual ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
somashekar Hazardous Waste: Is this an appropriate interpretation Miscellaneous Environmental Standards and EMS Related Discussions 1
G Appropriate Processes for Information Security Management System (ISMS) IEC 27001 - Information Security Management Systems (ISMS) 7
N Which is more appropriate Regular or Short Run control charting? Statistical Analysis Tools, Techniques and SPC 8
M Two situations where it is appropriate to add further Hazard Audits to Internal Audit Occupational Health & Safety Management Standards 8
B Appropriate Statistical Analysis Technique question Statistical Analysis Tools, Techniques and SPC 4
