What is the purpose of using AQL (Acceptable Quality Level) for Sampling?
Adam G
Can someone explain me what is the purpose of using AQL? Surely i miss something here.... Having sampling plan AQL 1.0 i have 95% probability that i will accept lots defective in 1% and this is the maximum defectiveness i agreed with supplier.
But if supplier will ship lot defective in 25% most probably my sampling plan will also accept that batch.
So AQL in general is not securing customer but Supplier. If that's the case then isn't it better not to use sampling plan at all? Then i have 100% probability i will accept 1% defective lot ;)
What is understand secures me as Customer is LTPD but that's quite different story and different sampling plan...
H
hvast_
everything depends of level AQL. AQL it is only conventional method of control, which more protect cost whether keep quality level of raw material provide by supplier.
Front point of view customer you can't allow to 100 % control material from your supplier- I believe that you know.
From Quality point of view will be better than we can control 100%, but you know- it's related with cost which give additional value.
In my opinion AQL it is only compromise between cost and quality, between supplier and customer.
BR/ Tomasz
C Purpose of using different Distributions to solve Reliability Problems? Reliability Analysis - Predictions, Testing and Standards 2
Q Using Class 3 used Electronic Devices for Training purpose ISO 13485:2016 - Medical Device Quality Management Systems 1
Z Using Different Forms For One (same) purpose Document Control Systems, Procedures, Forms and Templates 2
T Using Cpk for the purpose of determining sample size/frequencies Capability, Accuracy and Stability - Processes, Machines, etc. 2
M What is the purpose of authorizing the lab activities ISO 17025 related Discussions 1
dgrainger Informational Draft for comment - "reclassification of products without an intended medical purpose" EU Medical Device Regulations 6
placebo_master What is the difference between "Fitness for Purpose" and "Calibration/Verification"? General Measurement Device and Calibration Topics 6
dgrainger Informational DRAFT - Common specifications for the groups of products without an intended medical purpose listed in Annex XVI. EU Medical Device Regulations 0
Dan Pare Density Column setup for Measuring General Purpose ABS General Measurement Device and Calibration Topics 0
T Intended purpose for devices that might not fit the IP criteria EU Medical Device Regulations 0
B Nasal Saline Solution for Irrigation purpose classification EU Medical Device Regulations 0
A Intended Purpose on device label EU Medical Device Regulations 7
M ISO 13485 for general purpose disinfectants? ISO 13485:2016 - Medical Device Quality Management Systems 9
A Records required for ISO 9001 clause 7.1.5.1 - Fitness for purpose of the monitoring and measurement resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A A purpose of a Stage 1 audit - Off site document review Registrars and Notified Bodies 3
A Audit purpose - case study - What is the role of SQE in such case? General Auditing Discussions 3
A True purpose of doing EST (Electrical Safety Test) on medical device Other Medical Device Related Standards 3
T Informational What is the purpose of Internal Audits? Internal Auditing 27
K QMS Improvement - Analyze the systemic weaknesses of the QMS for improvement purpose Quality Tools, Improvement and Analysis 6
K Difference between intended purpose and intended use of the device EU Medical Device Regulations 9
J Purpose of Reference Section in SOPs Document Control Systems, Procedures, Forms and Templates 6
SK13485 Can a literature alone be used for the purpose of Clinical Evaluation of a device? EU Medical Device Regulations 6
E IATF 16949 Cl. 7.1.5.1 - Documented information as evidence of fitness for purpose IATF 16949 - Automotive Quality Systems Standard 3
R Auditing Fitness of Purpose for Monitoring and Measuring Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Are dermal fillers & PDO sutures for aesthetic purpose under CE MDD? EU Medical Device Regulations 6
somashekar Electronic data Back-up procedure, for Medical device QMS and regulatory purpose. ISO 13485:2016 - Medical Device Quality Management Systems 4
P Purpose of calculating Ta, Tb & R Square in Linearity Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Purpose of calculating Uncertainty value in calibration study Measurement Uncertainty (MU) 5
Q IEC 60601 for Non-Medical Research Purpose Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D UV Absorption Test - What is it's purpose and what specifically is it looking for? Other Medical Device Related Standards 10
A ISO/IEC 20000 Toolkit For Academic Purpose IT (Information Technology) Service Management 6
L What is, and the purpose of, ISO STATS recording ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
x-files Hardcopy and Electronic Forms for same purpose vs. Naming and Numbering System Document Control Systems, Procedures, Forms and Templates 1
N How to qualify (IQ, OQ, PQ) a multi-purpose equipment ? Imported Legacy Blogs 1
V The Purpose of Basic Dimensions on Prints APQP and PPAP 6
Q Beginner's Understanding - The Purpose and Applications of QMS/ISO Standards Philosophy, Gurus, Innovation and Evolution 12
J How to qualify (IQ, OQ, PQ) a multi-purpose equipment ? Qualification and Validation (including 21 CFR Part 11) 5
S Logo Marking for Marketing purpose - ISO 9001, ISO 14001 and OHSAS 18001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
P What is the latest version of ISO 10021 used for Certification purpose? Other ISO and International Standards and European Regulations 3
N Export & Import of Unapproved Device in USA for Service Purpose Only 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C Purpose of the Quality Manual for an Organisation Quality Management System (QMS) Manuals 4
M TS 16949 Clause 7.5.1.8 - Special-Purpose Tools or Measurement Equipment IATF 16949 - Automotive Quality Systems Standard 2
A FDA: Label Requirements for General Purpose Reagents IVD 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S What is the purpose of ON HOLD Labels Food Safety - ISO 22000, HACCP (21 CFR 120) 5
Q How to write Statement of Purpose for a Law School Admission Career and Occupation Discussions 9
C FDA Approval Process for Device that can also be used for Veterinary Purpose 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
R Can some one share JIS B7502/7507 or DIN862 with me for study purpose? General Measurement Device and Calibration Topics 2
C What is the Purpose of or Requirement for having a Gage Glossary? IATF 16949 - Automotive Quality Systems Standard 2
P What is the purpose and use of Chart Stickers Labels? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Auditor suggested company find a higher purpose for Internal Audits ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
