What is the standard method used to compute Attrition rate
L
lonewulf
Hi, I am new to this place and the very fact that this forum is very active is itself great.
:confused: Well, I have seen lots of websites give different interpretation of the term Attrition rate. And to add to the troubles, we have this as a process measure.
Anyone ps. tell me what is the standard method used to compute. Is it calculated monthly, quarterly or yearly??
regards,
Bala
Marc
Attrition rate as it applies to what? Employee turnover?
Bill Pflanz
I have done some data analysis work on employee attrition and the numbers came from Human Resources. They did the calculation monthly using the number of people on the payroll and the total number who left through voluntary or involuntary termination, retirement and even death during the month. Since it would be unusual for workers to leave and come back within the same month, it would account for those workers over time but not within a given month. Even in a historical high turnover industry like fast food, weekly attrition seems excessive. If there is very little turnover it probably is not worth tracking.
If you start doing some analysis on attrition, it will be important to also gather information on why they left. Through root cause analysis and corrective action, the idea would be to reduce the number of lost employees. I was looking at employee attrition in order to correllate it with client attrition.
HR usually has some idea on what it costs to replace workers and can be used for the economic value of retaining employees. The next step would be to correllate the attrition rate with the cost of quality which may be significantly more than the recruiting and training costs. Unless an economic value can be placed on the attrition, it may not be a useful process measure. If you are tracking attrition, it may be valuable to control chart the rate to determine what is normal variation, what are special causes and what system changes would be need to achieve a new level of performance.
Bill Pflanz
It's important to distinguish between the terms "attrition" and "turnover." The former generally relates to loss of employees through means other than involuntary termination, such as retirement, resignation and transfer. The latter connotes replacement of one employee with another in the same position. We'll often hear of "downsizing," for example, wherein the strategy is to reduce headcount by attrition--not replacing employees who leave on their own.
Care needs to be taken with the term "correlate" as well. There's a difference between simply comparing two variables in search of a potential relationship and finding a correlation, which suggests a causal relationship between two or more variables. In other words, A and B might happen concurrently or in succession, but that doesn't mean that there's a causal relationship between them.
a measure of attrition that I have used effectively in the past is more along the lines of the time from hire to departure. While this approach provides a better (statistically meaningful) measure of the attrition rate and any trends, it is a lagging indicator (plotting the cumulative attrition % of previous years (or quarters) of hire and comparing the curves along with a mean time to departure for each period provides a comprehensive look at departure rates. For example I once worked on a retention problem for engineers, the baseline data clearly demonstrated that 50% of all engineers resigned within 3 years of hire regardless of their experience, salary, job position or the fact that their 401k matching didn't vest until 5 years. At the 5 year mark, fully 85% of the hires hasd resigned...)
A metric of the % of individuals that depart in any given month provides a good gross indicator that is obviously faster to pick up large changes (but may also be overly sensitive). Nothing ever perfect is it?
toki27
hi! in john castillo... i want to ask you something about on how to compute the man and machine ratio, and headcount... pleas give me some examples.. thank you'
toki27
P Sheet Metal Design: Standard method for designing Electrical Knockouts Design and Development of Products and Processes 7
R What Standard or method to use to measure Bow condition in M6 Bolts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Actual Standard Test Method for Alloy Chemical Analysis? Other Medical Device and Orthopedic Related Topics 3
N Standard Approval for ELISA Method ISO 13485:2016 - Medical Device Quality Management Systems 1
M ASTM F88 Standard Test Method for Seal Strength - Designation F88-09/M88-09 ver 15.1 Reliability Analysis - Predictions, Testing and Standards 6
G How to properly check British Standard threads? 3-wire method and a supermic General Measurement Device and Calibration Topics 39
P A standard method of Dual Dimensioning drawings (Inch/Metric) Manufacturing and Related Processes 5
M Garment Sewing Standard Time Calculation Method Quality Tools, Improvement and Analysis 3
C What is the Difference between Laboratory-developed method and non-standard method? General Measurement Device and Calibration Topics 6
R Gage R&R - Anova Method - Standard Deviations vs. Variances Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
M Gage R&R (Ranges Method) - Reproducibility standard deviation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B ASTM 1895 Method B - Seeking Equivalent ISO DIN Standard Various Other Specifications, Standards, and related Requirements 1
A Is there a standard on tolerances of substances ? Medical Device and FDA Regulations and Standards News 0
SABRINA DJILALI SAIAH Implementation of the ISAS-MEDIA 9001 standard in a TV channel ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B European Harmonized vs IEC standard IEC 62366 - Medical Device Usability Engineering 2
D Which ISO Standard to purchase? ISO 13485:2016 - Medical Device Quality Management Systems 7
C Standard -Machinist Handbook Customer Complaints 4
N EN 813, EN 12277, EN 1497 - Testing some harness prototypes to an EN standard Various Other Specifications, Standards, and related Requirements 0
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
S Shore A hardness Tester Acceptance Criteria Standard Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
Sidney Vianna What ISO Standard (under the TC 176) supports the UN Sustainable Development Goal #10? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 11
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q EN ISO 13485:2016/AC:2018 - AC:2018 being stated in the applicable harmonized standard listing Other ISO and International Standards and European Regulations 1
J SAE J1739 standard IATF 16949 - Automotive Quality Systems Standard 2
Marcel DS LV 123 - BMW, AUDI, Mercedes Standard VDA Standards - Germany's Automotive Standards 1
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
Y UL 1998 Standard: software classes Software Quality Assurance 0
G What to do with correction factors overlooked by an accredited standard (6.4.11)? ISO 17025 related Discussions 5
G Copy of withdrawn ISO 9001:1994 Quality Management Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Anonymous16-2 SOP (Standard Operating Procedure) Numbering Document Control Systems, Procedures, Forms and Templates 7
Ed Panek Compliance with Standards? When a standard is updated/revised CE Marking (Conformité Européene) / CB Scheme 3
Skooma Deburring and Tolerances - Is there a Standard for deburring or removing material? Manufacturing and Related Processes 3
B Purchasing AS9100D Standard in Japanese AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
O In addition to the standard, what other ISO 13485 sources do people recommend? ISO 13485:2016 - Medical Device Quality Management Systems 5
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
M Informational RoHS Standard - EN 63000:2018 to replace EN 50581:2012 Medical Device and FDA Regulations and Standards News 11
D Recent changes to ISO 14971 - SOP required for managing standard revisions ISO 13485:2016 - Medical Device Quality Management Systems 1
P Cenelec updated standard information CE Marking (Conformité Européene) / CB Scheme 1
S Is there a standard for sample size during R&D phase Other ISO and International Standards and European Regulations 18
N Program or application for standard time measurement in industry from video surveillance? Human Factors and Ergonomics in Engineering 1
