What is the Standard Tolerance for Concentricity?
AmQC01
I need help finding information on:
  • What is the standard tolerance for concentricity?
  • Where to find this information?
Thank you,
AmQc01
Re: Standard tolerance
Where is the concentricity specification coming from? Can you give us more information about your concern?
Michael_M
Are you looking in the title block or notes area of the print? Usually that is were an unspecified tolerances would go.
Outside of that, it changes based on customer. One of our customers basic concentricity call is .005 (unless stated otherwise) while another is .002 and I have seen them out to .010 (but not in a long while).
AmQC01
This is coming from our customer. The print shows no dimensional call out for the hole to the o.d. of the part. There is also no call out in the tolerance block. I wasn't sure if there was a standard call out ( such as AMSE or DIN ISO).
Thanks for the help and any further help you can give me.
AmQc01
AmQc01
If there's nothing on the print or other specifications, there is no requirement. If you feel that there's something off-center that might be a problem, you might want to talk it over with your customer.
Joelbear5
The drawing is not fully defined. If there is a standard it needs to be referenced somewhere on the drawing, most likely in a general note or the title block.
Stijloor
AmQc01
Another reason why there is a need (required by ISO 9001) to determine and review customer requirements. As Jim stated, if there is no reference to a (GD&T) standard, than there is no requirement.
Also, in the USA, concentricity is in 99% of the cases the wrong application. For coaxiality concerns on stationary parts think Position. For dynamic (rotating) parts think Runout or Total Runout.
Contact the customer, discuss what actually they want, and get it in writing!!
Stijloor.
J Plastic Rod Straightness Tolerance Standard - 12' Bars of 3/8" Round Acetal Delrin Various Other Specifications, Standards, and related Requirements 3
BradM Pipettes - Using ISO 8655 standard tolerances instead of manufacturer's tolerance General Measurement Device and Calibration Topics 27
F Who knows DIN 1755 standard tolerance for brass tubes? Various Other Specifications, Standards, and related Requirements 0
J What is DIN 6930 m standard?? We have a print with measurements without tolerance Various Other Specifications, Standards, and related Requirements 9
A Is there a standard on tolerances of substances ? Medical Device and FDA Regulations and Standards News 0
SABRINA DJILALI SAIAH Implementation of the ISAS-MEDIA 9001 standard in a TV channel ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B European Harmonized vs IEC standard IEC 62366 - Medical Device Usability Engineering 2
D Which ISO Standard to purchase? ISO 13485:2016 - Medical Device Quality Management Systems 7
C Standard -Machinist Handbook Customer Complaints 4
N EN 813, EN 12277, EN 1497 - Testing some harness prototypes to an EN standard Various Other Specifications, Standards, and related Requirements 0
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
S Shore A hardness Tester Acceptance Criteria Standard Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
Sidney Vianna What ISO Standard (under the TC 176) supports the UN Sustainable Development Goal #10? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 11
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q EN ISO 13485:2016/AC:2018 - AC:2018 being stated in the applicable harmonized standard listing Other ISO and International Standards and European Regulations 1
J SAE J1739 standard IATF 16949 - Automotive Quality Systems Standard 2
Marcel DS LV 123 - BMW, AUDI, Mercedes Standard VDA Standards - Germany's Automotive Standards 1
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
Y UL 1998 Standard: software classes Software Quality Assurance 0
G What to do with correction factors overlooked by an accredited standard (6.4.11)? ISO 17025 related Discussions 5
G Copy of withdrawn ISO 9001:1994 Quality Management Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Anonymous16-2 SOP (Standard Operating Procedure) Numbering Document Control Systems, Procedures, Forms and Templates 7
Ed Panek Compliance with Standards? When a standard is updated/revised CE Marking (Conformité Européene) / CB Scheme 3
Skooma Deburring and Tolerances - Is there a Standard for deburring or removing material? Manufacturing and Related Processes 3
B Purchasing AS9100D Standard in Japanese AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
O In addition to the standard, what other ISO 13485 sources do people recommend? ISO 13485:2016 - Medical Device Quality Management Systems 5
B ASTM E18-2020 - Rockwell testing standard changes? General Measurement Device and Calibration Topics 2
M Informational RoHS Standard - EN 63000:2018 to replace EN 50581:2012 Medical Device and FDA Regulations and Standards News 11
D Recent changes to ISO 14971 - SOP required for managing standard revisions ISO 13485:2016 - Medical Device Quality Management Systems 1
P Cenelec updated standard information CE Marking (Conformité Européene) / CB Scheme 1
S Is there a standard for sample size during R&D phase Other ISO and International Standards and European Regulations 18
N Program or application for standard time measurement in industry from video surveillance? Human Factors and Ergonomics in Engineering 1
K Question on whether IEC 60601-2-62 standard is applied IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
B Clause 5.1.12 of Technical Standard IEC 62304/A1 IEC 62304 - Medical Device Software Life Cycle Processes 5
M Viable count Measurement ISO Standard Other Medical Device Related Standards 1
I When exactly was "competence" added to the ISO-9001 standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S Managing specification changes on standard parts purchased through trading companies Document Control Systems, Procedures, Forms and Templates 2
MDD_QNA QR Code Standard ISO/IEC 15417:2007 - Does anyone use it? Other Medical Device Related Standards 3
S Average and standard deviation of Cumulative Data Statistical Analysis Tools, Techniques and SPC 5
