What is your Cost of Poor Quality (COPQ)?
captainmajid
A thread on an American Society for Quality web site addressed the topic of the cost of poor quality (COPQ). It was opened when one group member posted, “The cost of poor quality in manufacturing companies ranges from 5 percent to 35 percent of sales. What has your company done to reduce this cost?” His query generated a number of responses, among them:
What is the practical use of reporting COPQ as a percentage of sales? Sales revenue can be affected by many other factors than Quality. For example, I would guess that COPQ/Revenue has gone up enormously in the oil industry over the last year. Has quality got worse? Has the quality of Blackberry products declined over the last decade? Surely a more meaningful way to report COPQ would be as a percentage of total COQ [cost of quality]; by which I mean: Total COQ = cost of prevention + cost of appraisal + internal cost of failure + external cost of failure.
I like the idea of a trackable metric COPQ/TCOQ because it could work for manufacturing/sales/service (including laboratories). But since COPQ is essentially internal failure + external failure, arithmetically wouldn't you end up with essentially something like 1/Prevention + Appraisal?
The question was, “What has your company done to reduce
cost of poor quality?” How does knowing that your company's COPQ is 20% of your company's sales help you understand where you are relative to other companies and why is that helpful?
It's a metric used to help top level management make a decision. If management sees the metric and decides to attempt to increase sales to cover for poor quality, well, that's why companies go out of business.
At the end of the day, it's a decision making tool that should not be used in a vacuum. When briefed effectively, it can be used as a powerful tool to help sway top management to invest in critical quality improvement initiatives.
I decided to join the conversation and posted.
normzone
Do any of the forum posters actually have an active system where this is tracked and reported? I could use a good model - I've lobbied for such a system in my current environment, but I seem to be the only one who can get excited about it.
Tyler C
I may be off base here, but I don't really see what this formula would tell you, other than some numerical value of the cost of quality. This would have a lot of potential to raise questions such as "what does that tell us?" and may be seen as something that doesn't add any value to the QMS.
I would change this formula to create a model that tells me whether or not I am spending too much money on COQ, not enough, or just right. For example, I would change this formula to:
COQ=(cost of prevention + cost of appraisal) - (internal cost of failure + external cost of failure).
If the cost of failure is potentially a million dollar a year customer, and your cost of prevention and appraisal is minimal, this would give you a negative number, telling you this could be a high risk and you may want to consider increasing your cost of prevention and appraisal. However, if the cost of failure is minimal, yet you are spending thousands on prevention and appraisal, perhaps that money could be better spent elsewhere (this would give you a high positive number). The closer to zero you are, the better ROI you should receive.
If done correctly, I could see this becoming a model that could satisfy the ISO9001:2015 Risk-Based Thinking requirement while actually adding some value to the company and the QMS.
Thoughts?
Access2hc
I agree with Tyler C.
in practice, the numbers will be challenging to obtain AND validate, and it would really have to be an elephant in the room, and done a bit on the stealth for something substantial to be revealed as COPQ. Unless the company culture is completely open and honest, having attention to the exercise typically reveals sandbagging or fudging with numbers to try 'stay still and hope the problem goes away on its own"
perhaps a bit cynic here but just tampering with reality. hope it helps
Cheers,
Ee Bin
Access2hc
Well, "modern" thought is that the COQ is counterproductive. By modern I mean that Motorola (and many others of course) threw out the 'prevention' cost because it only drove the pencil heads to argue that quality improvements were not cost effective - something that Motorola disproved in the eighties. Plus what all do you put in preventive costs? All of the basic things we do to design a quality product or capable process? Buying the right kind of equipment? Training our people? Design reviews? Tolerance stack up analysis? Contracts with your suppliers?
This is today's quality professionals advocate for calculating the Cost of POOR Quality.
Normzone: my organization has tackled a fairly accurate COPQ system in the past. It didn't really help us. What did help was getting people to experience the costs of failures for themselves. We had to get people to see beyond their little world and see the cost to the whole system. We also had to utilize the Toyota Production System approach to seeing the 7 wastes, which no accounting system can see. Once we started requiring crossfunctional teams and having leadership personally lead Problem solving efforts we achieved a turnaround in attitudes towards quality. cold COPQ numbers never had that effect.
Tyler C
I see your point Bev D. In your example they were probably using the traditional COQ=Prevention + Appraisal + Internal Failure + External Failure where I am suggesting breaking the good and the bad up and compare to each other.
My counterpoint is that when figuring COQ, you are figuring the COPQ along with the COGQ (cost of good quality) and comparing them in my above example. The above example is more of an estimation or projection of results (plan).
If the projected cost of poor quality outweighs the cost of good quality, maybe you should spend more on good quality to reduce the actual cost of poor quality. If the projected cost of good quality heavily outweighs the projected cost of poor quality, you may be able to afford to cut some costs in regard to good quality (do).
Remember, the risk definitions also includes positive opportunities. If you can cut good quality costs without actually jeopardizing your quality and spend that money on marketing for example, you could increase business. This is also a risk that should be considered. Of course, you would want to monitor to see if the projections matched reality and check for things such as an increase in potential quality issues along with how much business is being brought in through the expanded marketing. Run the formula again but with actual data instead of projected data (check).
Then, make adjustments as appropriate (act).
ASQ has a decent example of what should be included in all aspects of the traditional formula.
Thoughts? Keep in mind, this is not based on actual experience with this model, rather just thoughts around the subject. I may find that I could be 100% wrong when it comes to actual practice.
Also, could you share some examples of how you got people to experience the costs of failure for themselves?
rap36case
I am an accounting graduate student now and looking into use of COQ tools in Quality Systems. I was a quality manager in manufacturing. I have read Jack Campanella's book on Quality Costs.
Does anyone know of use of COQ in the Medical Device Industry?
qcman
Registered Visitor
I thought I would bring this thread back up since it deals with a question I have. Our COQ is nothing more than a number that seems to be ignored here by most. I am reviewing this now to determine if we need to make changes to it so its actually useful or drop it all together. The question I have for those using COQ is do you include Quality Department staff salaries in prevention?
I don’t use COQ, only CO Poor Quality when I calculate a COPQ cost.
As for your question: The ‘rules’ for COQ place Quality personnel in either appraisal or prevention. It depends on what the Quality department staff are doing. If they are inspecting product, performing audits, reviewing change orders or administering controlled documents, etc. they go in appraisal.
Arguably if they are dealing with correction actions, or developing/training quality system procedures like change assessment, new product development, etc. then they go into prevention.
However, lets think about what prevention is: it really is any activity related to ‘doing it right the first time’. So MSAs, Design reviews, creating fixtures and jigs that hold a part correctly, mistake proofing, good mold design, change assessments, checking your math, writing code, designing products, etc. is preventive. In other words ALL activities in an organization go into 1 of the 4 categories. This is why preventive costs have gone out of favor. Too many people can reduce preventive costs - which provide a short term boost to the bottoms line - that only serve to increase all of the other costs related to poor quality. So it really isn’t a cost so much as it is an investment...
J COST OF POOR QUALITY IATF 16949 - Automotive Quality Systems Standard 5
S Cost of Poor Quality (CoPQ) - Scrap element of calculation includes lost margin? Misc. Quality Assurance and Business Systems Related Topics 7
M Reducing Cost of Poor Quality - Your opinion requested Quality Manager and Management Related Issues 14
S Difference between COQ (Cost of Quality) vs COPQ (Cost of Poor Quality)? Misc. Quality Assurance and Business Systems Related Topics 8
M Which metric is better for Cost of Poor Quality (COPQ)? Quality Tools, Improvement and Analysis 17
R Development Rejection Costs in COPQ (Cost of Poor Quality) Calculations Misc. Quality Assurance and Business Systems Related Topics 6
1 Cost of Poor Quality form or template wanted Quality Tools, Improvement and Analysis 1
S COPQ (Cost of Poor Quality) Vs PONC (Price of Non Conformance) - Explanation wanted Quality Manager and Management Related Issues 5
M Cost of Poor Quality Reports IATF 16949 - Automotive Quality Systems Standard 15
K Generic worksheet for calculating Supplier Chargeback and Cost of Poor Quality (COPQ) Supplier Quality Assurance and other Supplier Issues 2
N Personnel COPQ (Cost of Poor Quality) Quality Manager and Management Related Issues 6
S COPQ (Cost of Poor Quality) - Can we add Premium Freight? Misc. Quality Assurance and Business Systems Related Topics 6
S COPQ - Cost of Poor Quality - COPQ course for non-financial people Misc. Quality Assurance and Business Systems Related Topics 1
N Identification of COPQ (Cost of Poor Quality) aspects Quality Tools, Improvement and Analysis 2
H Cost of Poor Quality (COPQ) - All returned/defective parts (plastic) are recycled Training - Internal, External, Online and Distance Learning 7
Manix Cost of Poor Quality (COPQ) and Reputation Quality Tools, Improvement and Analysis 25
I High COPQ (Cost Of Poor Quality) from Our Quality Department IATF 16949 - Automotive Quality Systems Standard 7
S New Auditor wants Mould tool repair bill included in Cost of Poor Quality! IATF 16949 - Automotive Quality Systems Standard 18
S Is there any standard for "Cost of Poor Quality" (COPQ) by ISO Various Other Specifications, Standards, and related Requirements 5
J Cost of Poor Quality (COPQ) - Iceberg picture Quality Tools, Improvement and Analysis 4
P Acronym COPQ (Cost of Poor Quality) and COQ (Cost of Quality) - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 26
L TS 16949 Clause 5.6.1.1 - Cost of "POOR" Quality vs. Cost of Quality IATF 16949 - Automotive Quality Systems Standard 4
S Audit finding - "Cost of Poor Quality" reporting - Confidentiality Issues IATF 16949 - Automotive Quality Systems Standard 13
C Building a Home and Cost of Poor Quality Coffee Break and Water Cooler Discussions 14
S How to Calculate the Cost of Poor Quality (COPQ) Quality Tools, Improvement and Analysis 54
G COPQ (Cost of Poor Quality) System to Drive CI (Continuous Improvement) Project? Misc. Quality Assurance and Business Systems Related Topics 3
M TS 16949 Clause 5.6.1.1 - Cost of Poor Quality - How can I track CoPQ? IATF 16949 - Automotive Quality Systems Standard 5
J COPQ - Cost of Poor Quality - Seeking recently published data on COPQ Misc. Quality Assurance and Business Systems Related Topics 4
S Cost of Poor Quality (COPQ) - What are the TS 16949 Requirements IATF 16949 - Automotive Quality Systems Standard 1
B Location of Work Instructions and Cost of Poor Quality - TS 16949 IATF 16949 - Automotive Quality Systems Standard 11
P Cost of Poor Quality (COPQ) in the Hotel Industry Service Industry Specific Topics 3
CaliperJim Cost of Quality calculation Quality Tools, Improvement and Analysis 4
A AS9100D new certification cost?? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
marmotte MDD legacy until 2024 - EUDAMED, role (and cost!) of the EC Rep EU Medical Device Regulations 6
R Cost per test tool/formula Oil and Gas Industry Standards and Regulations 1
N Guidance - Cost of Good Quality Misc. Quality Assurance and Business Systems Related Topics 2
C Budgetary cost to obtain ASME NQA-1 Quality Program Certification Quality Management System (QMS) Manuals 0
C ISO 19227 Validation Cost Other Medical Device Related Standards 2
B Lowest cost way to pass Lead Auditor exam ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
optomist1 Automotive News The Cost of Inspecting In Quality IATF 16949 - Automotive Quality Systems Standard 7
S IEC 62304 - Software verification cost IEC 62304 - Medical Device Software Life Cycle Processes 3
michellemmm What is the Cost of six sigma certification? Six Sigma 10
B Include cost of quality (and other wastes) in an ISO 9001 system? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
F FDA-registration and inspection cost 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Estimated cost for MDR certification Other Medical Device Regulations World-Wide 8
I Reducing CE marking cost using manufacturer test reports CE Marking (Conformité Européene) / CB Scheme 5
E How much a bioequivalence study will cost in the UK Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
A Cost effective thread gaging with ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
