What kind of chart to detect WHEN a in-process NC is about to occur?
Hybrid
It must be possible to detect when a machine is due wear and tear that causes burrs, draglines, tool changes. What kind of chart should i be using to keep track of these things? I have about 3 months of data that i jotted down as time went by and now with downtime id like to get the ball rolling on something. Any help?
What does your data look like? if it is tool wear you will typically have a 'sloping' trend - slowly up or down. Here are 3 references for these charts:
Sarkar, Ashok; Pal, Surajit, “Process Control and Evaluation in the Presence of Systematic Assignable Cause”, Quality Engineering, Volume 10(2), 1997-1998.
Wheeler, Donald, “Can I Have Sloping Limits?”, Quality Magazine, May 1999
Selden, Paul H., “Using SPC to Cure Sales Heartburn”, SPC INK, 1999 #1
Also see Bob Doering's blog regarding tool wear charting in the resources section. You will need to click on the orange download button to get the blogs...essentially he places the control limits at the inner 75% of your tolerance limits. Easy to calculate and it works.
If your data is 'flat' and then catastrophe occurs - you need to calculate the number of runs before a bad run. you would do this over ~20 sets of runs. I would set the limits just before the 'quickest' number of runs to failure. Alternatively you could calculate the mean and standard deviation of the number of runs to first failure and use the mean - 3SD to set the limit of number of runs until you change out the tool. (you should monitor the charts and adjust the limits as needed) There are other more sophisticated (complicated) methods available for this based on 'reliability' and 'maintenance' statistics. However I have found that in most cases the simpler ways are better as they are quick and easy to understand.
Steve Prevette
Deming Disciple
Good post by Bev. In addition, consider there are three phases to the generic "life" of an item - burn-in, steady failure rate, and burn-out. AKA the bathtub curve. Bathtub Curve - an overview | ScienceDirect Topics
A control chart of failure rates (1 over time between failures) is useful. Time to Repair, and Reliability Rate (Up time divided by Unplanned down time) are also useful. There are many tools for assessing reliability and repairability of equipment out there, in addition to Bob's tool wear calculations, depending on what model fits your situation.
N This is my kind of flow chart ;) Funny Stuff - Jokes and Humour 5
Antonio Vieira New(?) kind of control Chart? Pre-Control Chart Statistical Analysis Tools, Techniques and SPC 16
M What kind of instrument that must be calibrated? General Measurement Device and Calibration Topics 3
I What kind of wine best complements the Friday that you close out your external audit findings? Opinions are welcome. Coffee Break and Water Cooler Discussions 12
I What kind of information needs to be in a calibration record? General Measurement Device and Calibration Topics 25
L Document review is a kind of verification? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
A Why I get a different kind of regression equation when I do the same data in a differ Using Minitab Software 7
C IATF 16949 : 2016 - How put in place a Containment for this kind of Major NC IATF 16949 - Automotive Quality Systems Standard 14
T Is Sorting a kind of Rework? IATF 16949 - Automotive Quality Systems Standard 3
R What kind of Objective Evidence - AS9100 Cl. 7.1.6 - Organizational Knowledge AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Mixed Reality - What kind of possibilities can you imagine? Coffee Break and Water Cooler Discussions 1
J What kind of Tool and Gauge in IATF 16949 Clause 8.5.1.6? IATF 16949 - Automotive Quality Systems Standard 1
V What kind of audit for a production transfer? Internal Auditing 3
A What kind of test is described in subclause 56.3(c) of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
J What kind of beauty/skin products should 20-25 year olds use Coffee Break and Water Cooler Discussions 1
W What kind of data is expected for a PPAP Material Analysis Report IATF 16949 - Automotive Quality Systems Standard 7
D Template for the kind of naming convention on my test setup Manufacturing and Related Processes 2
K What kind of people are suitable for Quality Management? Career and Occupation Discussions 12
J What kind of a visual aid is this? Document Control Systems, Procedures, Forms and Templates 10
C What kind of information you provide when conducting QMS Orientation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
H What kind of training would you recommend to start on the process improvement world? Training - Internal, External, Online and Distance Learning 8
Marc Interrupted Sleep Might Be the Best Kind Coffee Break and Water Cooler Discussions 2
V What kind of Data should support Fit/Function Characteristics? APQP and PPAP 1
D What kind of ISO 14000 do I have to use on this Company? ISO 14001:2015 Specific Discussions 9
E What kind of questions will you ask on a quality quiz? Misc. Quality Assurance and Business Systems Related Topics 8
J Which kind of medical equipment must comply with IEC60601-1-8? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B What kind of insulin syringe is this for? ISO 8537:2007 Section 8, Table 1 Other Medical Device Related Standards 1
M FMEA for Drilling Process - What kind of failure can happen during drilling process? FMEA and Control Plans 8
N ISO Standards Applicable to Our Kind of Work? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Are Withdrawal and Recall a kind of Control of Nonconformity? Food Safety - ISO 22000, HACCP (21 CFR 120) 5
Y Halogen Free - What kind and type of plastic resins contain Halogen? RoHS, REACH, ELV, IMDS and Restricted Substances 3
P Is a Production Plan a kind of Document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Jim Wynne My Kind of Job Funny Stuff - Jokes and Humour 3
D What kind of DMR must a Medical Importer have? Other Medical Device and Orthopedic Related Topics 8
J Kind of Changes that affect the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J Internal Auditor Training - How much training and what kind of training Internal Auditing 18
S Which kind of document is the Quality Policy? Document Control Systems, Procedures, Forms and Templates 42
S What kind of certification do we need in our medical equipment company? World News 11
W What kind of materials should I prepare for passing ISO IEC 60601-1-4 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
A APQP and Food Products - Applying APQP to the production of a new kind of milk APQP and PPAP 3
S Strategy for implementation Lean Six Sigma - What kind of research? Six Sigma 4
G What kind of documents shall be prepared by a Multidisciplinary approach? IATF 16949 - Automotive Quality Systems Standard 1
H No Final Inspection - Can this kind of a policy meet ISO 9001 requirements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L What kind of Gage R&R is needed for a Pull Test Machine? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
I Appearance Approval Report (AAR) - For what kind of product is AAR applicable? APQP and PPAP 5
E Machine Set-Up Sheets for More Than One Kind of Equipment FMEA and Control Plans 15
SteelMaiden What kind of corrective action is this? Lead based paint in childrens' toys Nonconformance and Corrective Action 13
Q Improvement Initiatives - what kind of meetings or activities are relevant? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
F Help: What kind of doc is this and that? Document Control Systems, Procedures, Forms and Templates 2
S What is IMDS? Does Any kind of other thing other then four wheel manufacturing? RoHS, REACH, ELV, IMDS and Restricted Substances 3
