What kind of instrument that must be calibrated?
BradM
Welcome to the forum!
If I understand your question you are wondering which instruments need to be calibrated and which ones don’t.
Basically if the values form the instrument “matter”; they have quality impact, then I would consider verifying that instrument.
Did that answer your question?
John Predmore
I will offer a few examples of instruments that "matter".
If an instrument is used to determine some characteristic of quality of the product,, accuracy is important, and the accuracy of the instrument is likely to change over time, your customer will probably want the instrument calibrated. This includes instruments which measure dimensions, weight, electricity, chemical characteristics, and so on. My company uses a chemical analyzer which measures pH, and we verify the accuracy before use using purchased standard reference fluids. Verify before use is an acceptable alternative method to annual calibration in our quality management system. Some people may call this calibration, but I call this verification.
If an instrument measures a characteristic which controls the production process which determines the quality of the product,, accuracy is important, and the accuracy of the instrument is likely to change over time, your customer will probably want the instrument calibrated. This is includes temperature of a oven where temperature is important to product quality, for example. My company uses a drying oven with a conveyor which has a digital temperature readout. If there is a large amount of material going into the oven, the operator may turn the oven up a few degrees to a higher temperature, so there is no one target set temperature. The product quality test can tell the operator whether the material is fully dry or not. It is not possible to make bad product quality by making this drying oven too hot. So the temperature on the digital readout is not used to control product quality, it is only used as a guidance value, My company has decided the temperature sensor on the drying oven is not calibrated, because we do not use the temperature to determine product quality, there is a separate test that determines product quality, including whether the material is fully dry. If an outside auditor asks questions about the drying oven, we have documented our reason why this oven is not calibrated.
dwperron
Another explanation is that if you are reporting results then the measurement matters and the instrument needs to be calibrated.
So if you say you the package holds 100 g of a substance your scale needs to be calibrated
If you say that your product meets specifications then the instruments used in verifying that need to be calibrated.
So if you sell machined parts with tolerances your equipment that measures them must be calibrated.
If there are requirements on your process then the instruments must be calibrated.
So if a powder must be used in an area with humidity under 35% your instrument must be calibrated.
I What kind of wine best complements the Friday that you close out your external audit findings? Opinions are welcome. Coffee Break and Water Cooler Discussions 12
I What kind of information needs to be in a calibration record? General Measurement Device and Calibration Topics 25
L Document review is a kind of verification? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
A Why I get a different kind of regression equation when I do the same data in a differ Using Minitab Software 7
C IATF 16949 : 2016 - How put in place a Containment for this kind of Major NC IATF 16949 - Automotive Quality Systems Standard 14
T Is Sorting a kind of Rework? IATF 16949 - Automotive Quality Systems Standard 3
R What kind of Objective Evidence - AS9100 Cl. 7.1.6 - Organizational Knowledge AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Mixed Reality - What kind of possibilities can you imagine? Coffee Break and Water Cooler Discussions 1
J What kind of Tool and Gauge in IATF 16949 Clause 8.5.1.6? IATF 16949 - Automotive Quality Systems Standard 1
V What kind of audit for a production transfer? Internal Auditing 3
A What kind of test is described in subclause 56.3(c) of IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
J What kind of beauty/skin products should 20-25 year olds use Coffee Break and Water Cooler Discussions 1
N This is my kind of flow chart ;) Funny Stuff - Jokes and Humour 5
W What kind of data is expected for a PPAP Material Analysis Report IATF 16949 - Automotive Quality Systems Standard 7
D Template for the kind of naming convention on my test setup Manufacturing and Related Processes 2
K What kind of people are suitable for Quality Management? Career and Occupation Discussions 12
J What kind of a visual aid is this? Document Control Systems, Procedures, Forms and Templates 10
C What kind of information you provide when conducting QMS Orientation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
H What kind of training would you recommend to start on the process improvement world? Training - Internal, External, Online and Distance Learning 8
Marc Interrupted Sleep Might Be the Best Kind Coffee Break and Water Cooler Discussions 2
V What kind of Data should support Fit/Function Characteristics? APQP and PPAP 1
D What kind of ISO 14000 do I have to use on this Company? ISO 14001:2015 Specific Discussions 9
E What kind of questions will you ask on a quality quiz? Misc. Quality Assurance and Business Systems Related Topics 8
J Which kind of medical equipment must comply with IEC60601-1-8? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
B What kind of insulin syringe is this for? ISO 8537:2007 Section 8, Table 1 Other Medical Device Related Standards 1
M FMEA for Drilling Process - What kind of failure can happen during drilling process? FMEA and Control Plans 8
N ISO Standards Applicable to Our Kind of Work? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Are Withdrawal and Recall a kind of Control of Nonconformity? Food Safety - ISO 22000, HACCP (21 CFR 120) 5
Y Halogen Free - What kind and type of plastic resins contain Halogen? RoHS, REACH, ELV, IMDS and Restricted Substances 3
P Is a Production Plan a kind of Document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Jim Wynne My Kind of Job Funny Stuff - Jokes and Humour 3
D What kind of DMR must a Medical Importer have? Other Medical Device and Orthopedic Related Topics 8
J Kind of Changes that affect the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J Internal Auditor Training - How much training and what kind of training Internal Auditing 18
S Which kind of document is the Quality Policy? Document Control Systems, Procedures, Forms and Templates 42
S What kind of certification do we need in our medical equipment company? World News 11
W What kind of materials should I prepare for passing ISO IEC 60601-1-4 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
A APQP and Food Products - Applying APQP to the production of a new kind of milk APQP and PPAP 3
S Strategy for implementation Lean Six Sigma - What kind of research? Six Sigma 4
G What kind of documents shall be prepared by a Multidisciplinary approach? IATF 16949 - Automotive Quality Systems Standard 1
H No Final Inspection - Can this kind of a policy meet ISO 9001 requirements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
L What kind of Gage R&R is needed for a Pull Test Machine? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
I Appearance Approval Report (AAR) - For what kind of product is AAR applicable? APQP and PPAP 5
E Machine Set-Up Sheets for More Than One Kind of Equipment FMEA and Control Plans 15
SteelMaiden What kind of corrective action is this? Lead based paint in childrens' toys Nonconformance and Corrective Action 13
Q Improvement Initiatives - what kind of meetings or activities are relevant? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
F Help: What kind of doc is this and that? Document Control Systems, Procedures, Forms and Templates 2
S What is IMDS? Does Any kind of other thing other then four wheel manufacturing? RoHS, REACH, ELV, IMDS and Restricted Substances 3
ScottK Realistically - What kind of DPMO and sigma for a $5.00 part? Six Sigma 30
Jen Kirley A rather different kind of Union story World News 3
